Default BMS N54 / N55 / Diesel Meth Kits - 05-07-2011, 06:32 PM
The WW kit has been released! Simply the easiest and most cost effective way to take advantage of all methanol injection has to offer. I'll update this post with details, a FAQ, and addl information as needed. The WW kit price is $479 and includes everything you need including the pump, bracket, line, fittings, CM10 nozzle, solenoid, FSB electronics, wiring, etc. It installs in minutes, is fully reversible, and keeps your windshield wipers fully functional. This kit is ideal for 33-50% methanol mixtures. For strong mixtures or in very hot climates you'll want to use one of our trunk mount kits instead.
Click here for order info and prices.
The kits are available for the N54 or N55 motors.
The first step is mounting the nozzle.
For the N54:
For 2007-2008 models you can use our replacement meth elbow: http://burgertuning.com/meth_elbow_bms.html
All N54 models can also use our stronger and higher flow N54 charge pipe w/ meth bung which mates to your original style diverter valves: http://www.burgertuning.com/chargepipe_N54_BMW.html
For N54s planning to run higher boost levels we strongly suggest our N54 chargepipe with Tial BOV w/ meth bung: http://burgertuning.com/BOV_Kit_135_335_BMW.html
For the N55:
You'll need our stronger and higher flowing N55 BMS chargepipe w/ meth bung: http://www.burgertuning.com/chargepipe_N55_BMW.html
For BMW diesel motors we don't offer a chargepipe or methanol mount so you will need to drill and tap your original plastic chargepipe with a 1/8" NPT tap kit.
For support or installation related questions email us @ terry@burgertuning.com. Alternatively if you'd like public forum support feel free to take advantage of our support forum. To avoid clutter support requests made to this thread will be moved or deleted.
GbreeE90 GbreeE90 is offline
Default 05-07-2011, 06:35 PM
I want it :D
Default 05-07-2011, 06:41 PM
Is this kit going to come out for sure? If it is im going to wait for it, if not im going to get the CM Pro tank.
Default 05-07-2011, 06:54 PM
Normally our products start as Jason, Jon or I playing around with something until we feel it's to the point that its both functional and fits some need within the market. A quick install meth kit is a need. Is this concept functional? Too early to tell. Still in the playing around with it phase.
Sticky Sticky is offline
Car: M3
Default 05-07-2011, 07:05 PM
Any idea what the activation fee might be?
Default 05-07-2011, 07:06 PM
LOL we're going to a per use charge. You enter your credit card info in the interface and it charges you $1 per minute of wide open throttle. $2 if you're roaming more than 60 miles from your house.
triumph's Avatar
triumph triumph is offline
MY TR6 needs Bimmer power
Car: 07 335i coupé cabriolet
Default Per use charge !! - 05-12-2011, 09:41 PM
That's funny Terry.
I sell software so we have a cpu charge and a CAL charge.
We also do a cloud model so can I get boost from the cloud?
I have a mifi?
LOL
M_M's Avatar
M_M M_M is offline
Car: e91 335i
Default 05-13-2011, 12:00 AM
great news, been waiting for this kind of hood mount kit for quite a long time!
themyst themyst is offline
Super Demigod
Send a message via AIM to themyst
Default 05-07-2011, 07:14 PM
Don't forget the $295 VIN unlock fee!
E90 LCI N54 6AT
Alessandro Alessandro is offline
Car: 335is
Default 05-07-2011, 07:15 PM
lol thats a good one!
Default 05-07-2011, 07:21 PM
For those of you with a 135i we may resurrect our old quick mount. Never bothered making a production quality version but it worked really well in testing. Attaches to the OEM chargepipe in place of the useless air horn. 5 min install tops.
chancejat's Avatar
chancejat chancejat is offline
C63 AMG
Default 07-24-2011, 12:45 PM
any more info on how i can do this? thx...emailed you btw
Default 07-24-2011, 02:14 PM
No. But you just remove the airhorn and figure out a way to mount a meth nozzle in a cap to reattach there.
Vroom's Avatar
Vroom Vroom is offline
Car: 335i 318ti
Default 05-07-2011, 08:49 PM
Nice T.
You don't have the pressure losses from 10-12' of tubing @ 250psi.
Was wondering about losing prime on the pump if it's too high above the tank?
I just bent up a bracket to hang the pump just behind the FMIC. Obviously not a 5 minute install.
Default 05-07-2011, 10:16 PM
Originally Posted by Vroom
Nice T.
The priming may be an issue. Another forum member also tried an engine bay mount setup and had problems with vapor lock at higher meth concentrations, so that has to be evaluated as well. Fortunately it's starting to heat up around here so I should know more on both soon.
Bootay Bootay is offline
Car: e90
Default 05-08-2011, 12:17 AM
I'd definitely buy one.
R1000K3's Avatar
R1000K3 R1000K3 is offline
Car: 335i -07 MT
Default 05-08-2011, 09:00 AM
A solenoid instead of a checkvalve should take care of priming issues. But there is always a risk the pump will be more ore less drained when not used for a while, which may cause a significant delay for the first meth-shoot. It is also important that the tune monitors meth flow before enabling N2O.
Russell @ BMS's Avatar
Car: 2009 335i AT
Cool 05-08-2011, 09:33 PM
+1 Good point. A solenoid will allow a vapor locked pump to re-prime where a check valve will not.
DBFIU DBFIU is offline
Joose Bocks
Car: 135, AT, JB3, DCI...
Default 05-07-2011, 09:22 PM
Replacing the air horn garbage thing with a meth injection point is a great idea. I think that would save people a lot of money, no need to buy chargepipe if all you want is meth.
alpinedevil335's Avatar
alpinedevil335 alpinedevil335 is offline
Car: 09' 335i Sedan
Default 05-08-2011, 10:11 AM
T,
How stout is that area? What material thickness will you use for the bracket?
Default 05-08-2011, 12:25 PM
Originally Posted by alpinedevil335
T,
Seems stout. No idea on the bracket, I'd have a bracket professional design that part if we like the location.
Terrance28's Avatar
Terrance28 Terrance28 is offline
Car: BMW 335i
Send a message via Yahoo to Terrance28
Default 05-08-2011, 11:35 AM
Where is the tank gonna be?
E92 335i Crimson Red|JB3 2.0|Stett Intercooler W/N2o Bung|AFE DCI|Stett Charge pipe W/Meth Bungs|Synapse BOV|Devil's Own Stage1 Kit|Dynotune N2o Stage1 Kit W/Progressive controller & NX noid|ATI Gauge Pod|VEI Boost,A/F Gauge|Cyba Scoops|RR OCC|19" M6 Reps|Aero Lip|Color Matched Grills|Eibach Pro kit|Momo Knob|M3 Spoiler|Carbon8 PD Hood|Vynil Roof|Shadowline Trim|ACS Roof Spoiler|Carbon Interior|MFD M3 skirts|Raceland DP|BMS V3 DP Fix|Magnaflow Race exhaust|
Default 05-08-2011, 02:25 PM
Why not use SS line and tie in the AC compressor somehow?
Default 05-08-2011, 03:24 PM
Got a high speed solenoid here as well. So we can test PWM pump vs. PWM solenoid vs. PWM both!
Our current kits are all PWM kits but maybe this market needs DOUBLE-PWM! BAM!
Default 05-08-2011, 04:45 PM
Wait was that sarcasm? I didnt think you sold any PWM kits?
