Denobd Denobd is offline
Car: 535i
Default fueling experts please help - 07-21-2019, 03:32 PM
good afternoon everyone. i a hoping to get a little help / insite from some of the more seasoned folks on the forum. this is the issue i am having. i have very long cranks when starting the car after its sat for a few hours. also at random times wot and normal driving i get the half engine light and message on the i drive screen that says fuel pump and then my engine shuts down.
these are the codes i get
2AAF- fuel pump plausibility
2A2D- low pressure system
i am trying to post my datazap link for the log but it wont let me. but to me LPFP, and Rail pressures seem to be holding up fine. i think my EKPM is failing. but i am trying to get some other opinions.
thanks in advance for any help.
gunda gunda is offline
Car: BMW 335i E92
Default 07-22-2019, 04:40 AM
Low pressure fuel sensor, goes all the time. I had the exact same symptoms recently, but I also had a nee LPFP & EKPM module. If you notice your LPFP reading is staying stuck at a number then it’s the sensor.
Car: 535i
Default 07-22-2019, 05:00 AM
sensor was just replaced recently.. lpfp number reads from 72- 90 psi thruput the pull. 72 looks to be where i let off the gass to change gears..
Haynpunch's Avatar
Car: 07 E90 335i
Default 07-22-2019, 07:54 AM
Post the csv file in the support section
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 535i
Default 07-22-2019, 04:49 PM
How do I post the csv file?
Default 07-23-2019, 10:22 PM
Throw up a post in the support section.
Post a log...
Advanced settings— manage files
http://www.fuel-it.biz/
e92 AT 335xi 2.0
Doc Race Kit 6062
