codesx codesx is offline
Default BMS WMI, Inline fuse - 07-20-2019, 09:14 AM
Quick question!
Apologies all.
My phones search option doesn't work here. It opens and closes the search box. I have read the pdf and looked in the stickies briefly.
I'm just wrapping the WMI up... finally!
One question. (I'm N54)
The pdf says the inline fuse will go between the FSB red wire [already to same power source as the JB4] to the pump and pump.
I'm not following the above sentence correctly.
Where does the inline fuse interject for the N54?
Thanks!!
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
NGK 5992 Plugs @ .020
Maintenance:
Default 07-20-2019, 10:03 AM
OK. Found my answer in a post I read from Terry.
"Fuse I prefer to have between pump and FSB, but can also be attached between power source and red."
Given it's optional, I also like the idea of it strictly between the FSB and PUMP, in the event my red gets grounded somewhere (under rear seat, etc)
TMAP: 3.5 barr
xHP Stage 3 (v2.0)
VRSF CP | HKS BOV
RB PCV Valve
Maintenance:
