Iaintslow's Avatar
Iaintslow Iaintslow is offline
Default Oil analysis what you guys think? - 07-03-2019, 09:44 PM
My first report for this car with high copper and iron but 0 lead ? Can it be main bearing with 0 lead?
I replaced valve cover and gasket twice during oil use with use of silicone , also had had synapse bov leaking with no filter on it , this bov is wide open during idle apparently . i got all these fixed after i noticed it maybe 2 weeks later after i got the car. Also had new turbos installed.
TimboBlackkers TimboBlackkers is offline
Car: '08 135i MT
Default 07-08-2019, 06:41 PM
How many miles on the engine?
Car: '08 135i MT
Default 07-08-2019, 11:10 PM
High copper in the oil isn't a problem in itself, it won't promote wear or anything.
However it can be a sign of worn bearings. At that mileage I wouldn't be surprised if the main and rod bearings are worn.
As for the Iron content I don't know.
Just treat the car as you normally would and get another analysis done at your next interval. I'm sure the motor is fine.
