fordnox fordnox is offline
Car: e92
Default Map6 HowTo - 07-26-2018, 04:01 AM
Hey Guys.
I wanna give map 6 a try.
where should i start and what Settings should i use?
attached find logs of map 3
Stock m240i xDrive. No EWG and FF wires
BR
F87 M2C
Antec800 Antec800 is offline
Car: 340ix
Default 07-26-2018, 04:15 AM
I think you need ewg wires to change anything in map 6
Renato B58 Renato B58 is offline
Car: Bmw M140i
Default B58 map6 high afr - 08-02-2018, 10:46 PM
Hey guys
Im pretty neew to forums so not to sure how it works, anyway let me have a bash
I have a M140i just fitted jb4 and ewg, car also has **,and bms intake on map6 it seems its running quite high AFR car was tuned with 30l 95oct and 3l e100 eth, well thats what the tuner recommended, is there any setting on map6 i can look at and what mix to run will past in the logs car ran 12.96 on dragy and made 306kw 706nm BUT i dnt think map6 is tuned rite
Bullitt1841's Avatar
Bullitt1841 Bullitt1841 is online now
Default 08-04-2018, 12:09 PM
Originally Posted by Renato B58
Hey guys
What are your Map 6 boost settings? It looks like it's just an additive PSI (something less then 10, otherwise above 10 equals absolute).
Your high AFR is completely normal and fine since it is only during shifts. Once you are in gear and under power the AFR is fine.
Update your firmware to V9. If you can't do that, change Future Use D (FUD) to 64. That way you can log timing on all cylinders.
You could probably add more ethanol if you add the FF wires. Timing could be slightly better.
Car: Bmw M140i
Default 08-06-2018, 04:56 AM
Thanks 4 the reply here is the settings maybe u can see something
Car: Bmw M140i
Default 08-06-2018, 04:59 AM
so they have the boost tapered off can i run high boost levels with more eth round 30%mix say 26psi without ff wires
Default 08-06-2018, 09:46 AM
No, even 22 PSI is a lot to be running, even down low in the RPM like that. You're only targeting 14 PSI at redline.
The way it's tuned is probably fine for that ethanol mixture. But it's preference if you want a lot of torque down low or more HP through redline. I can run 17 PSI all the way to redline and I like the way that feels.
Car: Bmw M140i
Default 08-06-2018, 10:44 PM
thanxs
so what would you recommend, sorry for all the Q&A
NotSoStock's Avatar
NotSoStock NotSoStock is offline
Not So Stock
Car: M3 E92 (MT) / M240i (ZF)
Default 10-23-2018, 07:41 AM
Fala Renato! Você chegou a medir o 100/200?
Have you measured your 100/200 kmh?
I´m starting to work on my map6 now.
I just got with pump gas 95 Ron 9.8s. (MAP5)
Eventuri Intake
JB4
M240i
L. Felipe - @NotSoStock
