sales@vargasturbotech's Avatar
sales@vargasturbotech sales@vargasturbotech is offline
Car: N54, N55, S63, S55
Default VTT Stage 3 x ABR Punisher Built Motor - 03-05-2015, 01:49 PM
The "Punisher" built motor from ABR Houston arrived yesterday. This thread will document the installation, and results as we this project progresses. we want to give a HUGE thanks to Alex over at ABR, one of the best guys in this platform to work with.
Since the production kits are nearing completion rather than continuing to test the limits of the stock motor we will be putting the first Stage 3 kit on this built motor with our GTX2867 option into the shop car. Once we get it all installed, and tested we will then be move onto the new Garrett GTX2871's which have 1100BHP worth of flow.
Things are going to get very interesting!
VTTPunisher1 by VargasTurboTech, on Flickr
VTTPunisher2 by VargasTurboTech, on Flickr
VTTPunisher3 by VargasTurboTech, on Flickr
VTTPunisher4 by VargasTurboTech, on Flickr
sales@vargasturbo.com
Vargas Turbocharger Technologies
N55 World Record: 11.4 ET / 123MPH,
477WHP / 509WTQ
N54 Stock Frame (100% E85) World Record: 645WHP / 654WTQ
N54 (ACN 91 octane only) World Record, Stock Motor: 573WHP / 537WTQ
Peter @ Pure's Avatar
Car: F20 M135i
Default 03-05-2015, 01:54 PM
Nice. Looking forward to your findings.
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Default 03-05-2015, 01:56 PM
This is so exciting!!!
Default 03-05-2015, 02:49 PM
What are the specs & price on the new motor?
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 03-05-2015, 03:02 PM
Sub'd
cmiggz's Avatar
cmiggz cmiggz is offline
Car: 2008 BMW 335i
Default 03-05-2015, 05:00 PM
interesting should be fun. first to 1k whp
Evil///M's Avatar
Evil///M Evil///M is offline
Car: 335i/e36m3
Default 03-05-2015, 05:28 PM
This is going to be AWESOME!
weebles weebles is offline
Default 03-05-2015, 08:08 PM
More info on the motor specs plz!
rwalker rwalker is offline
Default 03-05-2015, 09:08 PM
kicking stage 3 down the road a bit more?
extreme-eg extreme-eg is offline
Car: Toyota 86
Default 03-06-2015, 01:23 AM
Interested to see your results on the twin GTX2867R's. I'm just wondering if the GTX2871R has the potential to be a mismatch as is the case with the GTX3076R.
On the GTX3076R the turbine wheel can't support the increased flow from the compressor wheel so on paper it can support more hp but in practice there is very little power gain at the expense of some spool. The X2867R seems like a great combination of spool, power and physical size so it may just be the perfect solution...
Steve 335i Steve 335i is offline
Car: 2009 BMW 335i
Default 03-06-2015, 11:01 AM
Built stroker motor? Sounds interesting
2009 E90 335i
Evil///M's Avatar
Car: 335i/e36m3
Default 03-06-2015, 11:23 AM
Just wondering, is it the same compression as a stock motor?
swat's Avatar
swat swat is offline
Car: 07 335i
Default 03-06-2015, 12:41 PM
I wish someone would just find the limits of the stock motor already. It has yet to crater or anything, even with the 900HP kit by motiv, whats to say it would at over 1000?
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Default 03-06-2015, 01:09 PM
It can blow up at 400whp and probably last a few runs at least at 900whp for all we know. But sooner or later they all blow up at higher power levels.
swat's Avatar
Car: 07 335i
Default 03-06-2015, 01:36 PM
Well yes that's obvious. I just meant when tuned properly and taken care of, what is the limits?
jeison33 jeison33 is offline
BoostingSix
Car: BMW 335i
Default 03-07-2015, 07:33 AM
Alex at abr knows his stuff . Im guessing this motor is 14 -16 k.
infliktyd135i's Avatar
infliktyd135i infliktyd135i is offline
Car: 09 135i
Default 03-07-2015, 11:04 AM
But won't you have the same knock sensor problems that terry is having on his built motor?
Default 03-09-2015, 10:32 AM
Below is a bit more info about the motor, we'll continue to update this thread as the installation and testing develops. If you have any further questions about the specifications or an interest in getting a similar build for yourself please direct your inquiries to info@abrhouston.com
3.1 liter stroker
9.5:1 compression
JE custom pistons
Proprietary ABR I beam connecting rods
ABR head and main studs
CNC ported cylinder head that outflows a similar competitor
Oversize Manley stainless intake and Iconel exhaust valves
477WHP / 509WTQ
Tony@VargasTurboTech's Avatar
Tony@VargasTurboTech Tony@VargasTurboTech is offline
Car: Anything with a Turbo
Default 03-10-2015, 05:55 AM
I have to 100% disagree with you, the GTX3076 is one of the most potent combinations Garrett has offered, and its been proven over and over to flow slightly less than a GTX3582R, while spooling much better. Here they both are tested on the street and the dyno, not exactly paper racing. The GTX3076 spools over 500RPM faster than the GTX3582R, and makes the same power up top. Garrett does not just throw together combos on paper, they test everything. The GTX3076R is not in any way a mismatch, the results prove it. I have no doubt the GTX2871's will be a great turbo once they become available, we will test a set.
http://blog.perrinperformance.com/ga...omparo-part-2/
Tony@Vargasturbo.com
www.Vargasturbo.com
Making the world happier one turbocharger at a time
Car: Toyota 86
Default 03-10-2015, 06:49 AM
I guess its dependent on how tolerant the engine is to backpressure and how important turbine flow is to the overall equation (engines with high VE). For example the Honda VTEC engines (which are my background), do not tolerate backpressure and require a lot of turbine flow/capacity. On this platform the GTX3076R isn't able to produce much more power than the regular GT version due to hitting the flow limit of the turbine wheel (lower than the 600whp rating)
This is partly the reason why Garrett introduced the GTX3576R which delivers excellent results.
On the other hand the VW TFSI engines tolerate backpressure remarkably well and on this engine the GTX3076R is a popular choice and works well.
I believe Garrett will be releasing a GTX2971R shortly which will have the old GT3071 turbine combined with the Billet 71mm exducer comp wheel.
Good luck with your testing
Default 03-10-2015, 06:56 AM
Well if you want to talk different motors, then yes different turbos will have vastly different results. You did not specify a motor, you lumped all GTX3076R's into the category of a mismatch, which it is not. I would go with a 3076 over a 3576 all day in a street driven application as good spool is more important to me than every last top end hp. The 29 series turbos should be interesting, but they will most likely be a ways off. Also the N54 tolerates BP better than almost any motor we have seen, we have run them up to extreme levels of BP with no real ill effects. We will see how the testing goes, with a few different turbo choices.
www.Vargasturbo.com
Default 03-18-2015, 01:33 PM
477WHP / 509WTQ
Default 03-18-2015, 01:59 PM
The bottom pic, is actually the old motor, and old stage 3 parts, we will be putting the production parts on the New motor in the next day or two and will get you guys some updated pics! It wont be too much longer now!
www.Vargasturbo.com
HeavyMetalRocker's Avatar
HeavyMetalRocker HeavyMetalRocker is offline
Car: BMW 335i e90
Default 09-01-2015, 01:57 PM
Any updates on this motor man?
Optigrab Optigrab is offline
Car: 08 135i 6AT
Default 09-01-2015, 02:19 PM
If Tony makes 1100 whp this is going to turn into a transmission solution thread lol
