mightbaal mightbaal is offline
Car: 2008 335xi
Default 2008 335xi transmission slips 1-2 sometimes.... - 05-04-2016, 05:55 PM
Well my car has almost 70k now and has the alpina B3 v2 flash and I mean I like power and am running a BEF and map 7 so 20 psi of boost... Some other small mods just did the alpina B3 v2 flash like a week ago and sometimes when it shifts WOT 1-2 it shifts hard sometimes it shifts smooth and sometimes it shifts smooth but rpms jump up right after the shift (slippage). No codes at all. Sometimes it seems like something hops when you downshift hard to like 2nd too. Idk I have a warranty good till 102k but I eould have to switch everything to stock and flash everything back. (VRSF chargepipe VRSF 7 inch FMIC DCI Jb4 Back end flash transmission flash and run it out of E50+ and fill with premium). How hard is a transmission swap on these XI's?
2008 335xi FBO JB4 BMS E85 Backend flash E60 Gas VRSF Chargepipe /w HKS BOV VRSF 7 inch FMIC DCI VRSF DOWNP xHP Stage 3 flashed
PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 05-04-2016, 06:22 PM
Stock DP's and you're running map 7?
SOLD - FBO N54, Pure Turbos stage 2, TFT inlets, JB4/MHD, EOS intake manifold w/PI, Fuel-it stage 3
Car: 2008 335xi
Default 05-04-2016, 06:31 PM
Yea..... XI's are a PITA and I still have a warranty... I know lots of back pressure....
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 05-04-2016, 08:08 PM
Which Alpina ZB number did you flash to your transmission? 7615835 or 7603537?
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
firemanjust1's Avatar
firemanjust1 firemanjust1 is offline
Car: 2008 BMW 335xi
Default 05-04-2016, 08:16 PM
You should be able to remove those mods in 2-3 hrs . I think that would be worth it if they will replace transmission under warranty. I would take it somewhere else for a third party to verify it is slipping then just take it to the dealer for warranty. If you know for a fact that you need a new transmission 6 hrs 3/3 install factory then remod would more than worth it imo.
JB4/G5 ISO ,AR DP,BMS DCI,NGK 5992 BMS Meth kit dual nozzle CM 7 & 5,VRSF 7 IC, Stett chargpipe, E60 mix, 255 Walbro, Bms Race flash. RB turbos , VTT inlets ,BMS OCC, 3.5 N20 sensor, Conti DWS
Car: 2008 335xi
Default 05-04-2016, 09:42 PM
Problem is there is no way the transmission would slip under stock power. Probably going to have to wait till it gets bad before I can take it in.
