(#976)
Default 05-31-2019, 05:31 PM
To speed it up just email me directly terry@burgertuning.com
razvannwaa razvannwaa is offline
Default 06-03-2019, 11:03 AM
hello guys,i have a problem,i instaled the jb4 antilag on my 135i automatic,and the 2step doesn’t work,rolling launch does work..can you help me?.Thank you
CJ 135i CJ 135i is offline
Car: 2010 BMW 135i M Sport
Default 06-06-2019, 06:51 AM
Try getting new spark plugs. I had the same issue and then I upgraded to 1 step colder NGK plugs and it works like it should now.
andrew.g35.04@gmail.com andrew.g35.04@gmail.com is offline
Car: 335i 2009
Default 06-06-2019, 12:52 PM
Having issues with anti lag activating from a stop it works just fine from a roll just not from a stop
Blackbeautyn54
Default 06-07-2019, 08:53 AM
Can you post the CSV when you're at a stop so we can see why?
Hedge's Avatar
Hedge Hedge is offline
Car: BMW 535I X-Drive
Default 06-07-2019, 09:09 AM
Auto or manual transmission?
If manual, make sure your shifter is pushed into 1st gear.
Remember you also need to hold down the volume button and floor the gas pedal to 100%.
It wont trigger at 90% gotta, floor that sucka.
(((coke)))'s Avatar
(((coke))) (((coke))) is offline
Car: 335i n54
Default 06-11-2019, 09:50 AM
You can run methanol and anti-lag at the same time,
Both at 12 psi to activate together, or can cause error or damage that methanol is pulverizing while it is working the anti-lag?
Thanks terry and great job they do.
vadimlitv vadimlitv is offline
Car: 08 E90 335xi
Default Quick test - 06-19-2019, 07:39 PM
Did a quick test right after install.
Latest firmware
Bef done by Jon Russell (JSRtuning)
Automatic xdrive
2step works intermittent, when I try anti-lag the car stumbles and shuts off.
I'm about to get e85 and test again.
Bef is for e85 anyway.
Let me know why I might be getting these issues.
Car: 08 E90 335xi
Default 06-20-2019, 04:11 PM
Latest firmware
Automatic xdrive
Anti lag works if I undo bit3 under WMI.
I need help of how to fix this.
E90 M335i E90 M335i is offline
Car: 09 E90 335i Msport
Default 06-20-2019, 08:00 PM
Latest firmware
Automatic xdrive
Same issue here
Fredm21 Fredm21 is offline
Car: Bmw 335i 2007 N54
Default 06-21-2019, 12:56 PM
Originally Posted by E90 M335i
Same issue here
What bef did you use?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
BMS WMI with single nozzle ( 10 )
JB4 map 3 w/bluetooth & antiliag
Afe intake filter
BMS intercooler
BMS tranny cooler
BMS Double baffle catch can
MHD BEF Racegas
Precision Raceworks Coil
-Running 91 octane with WMI
Default 06-21-2019, 01:58 PM
When trying antilag+2step when not moving, put it on neutral - brake pressed - rev the car to around 3500 ( make sure mode 8 is at around 4000rpm ) then release gas pedal - press down volume - step back on gas 100%
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Car: 08 E90 335xi
Default 06-21-2019, 03:25 PM
Why do it on neutral if you are trying to launch with both 2step+anti-lag?
I guess just for the cool crackle pop
Default 06-21-2019, 03:37 PM
Exactly, if you want to use the rolling start remove bit3.
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 06-21-2019, 07:30 PM
Race BEF
Default 06-22-2019, 04:57 AM
Race BEF
There is an issue in the race bef ije0s, antilag not working. Terry know’s about it, maybe he forgot to update the flash on the forum. I can provide you the correct race ije0s if you want it pm me your email!
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
iturbo's Avatar
iturbo iturbo is offline
Car: 2009 335i e92
Default 06-30-2019, 06:22 PM
Do you still need to set a 1st or 2nd gear boost limit to use anti lag with the latest firmware??
2009 335i e92 n54 | FBO | JB4 | e85 flash |
blown07's Avatar
blown07 blown07 is offline
Car: 335xi, 335i
Default 07-15-2019, 10:43 AM
Anyone know the easiest way to disable the anti-lag? I find it comes on even if I am on the accelerator and then brake boost. With meth it's not enough load so it stumbles + the delay for full timing to come back on.
Bmartin3831 Bmartin3831 is offline
Car: N54 335i auto xdrive
Default 07-15-2019, 10:51 AM
0 in the 1st gear boost setting?
Default 07-15-2019, 10:59 AM
Wmi table
Disable bit 3
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
blown07's Avatar
Car: 335xi, 335i
Default 07-15-2019, 11:14 AM
Wmi table
Disable bit 3
Thanks ! based on the posts above I was considering trying that
Cheers
blown07's Avatar
Car: 335xi, 335i
Default 07-16-2019, 05:51 AM
Wmi table
Disable bit 3
This didn't work for me. Any other ideas? I guess I can do it in the flash.
Default 07-16-2019, 06:19 AM
Are you really talking about the anti-lag or 2 step?
-07 335i coupe
BMS charge pipe
Turbosmart BOV
VRSF down pipe
Afe intake filter
BMS intercooler
BMS tranny cooler
MHD BEF Racegas
Default 08-03-2019, 12:55 PM
Hi, after installing VTT GC 2.0, outlets, inlets, and recommended BOV spring my anti lag will only build to about 5 psi for a moment then lowers to around 1 or 2 psi and flutters there. It worked fine and would easily hold 10 psi before the new parts. Any idea? BOV spring? No matter what the setting is at it stays just above 0 psi.
iturbo's Avatar
Car: 2009 335i e92
Default 08-06-2019, 07:08 AM
can you still launch with 2 step + anti lag? my car stumbles and stalls when i try? anyone else have this issue
09 n54 AT e85 bef
