PR3CI5N335i's Avatar
Need4Speed
Car: 2010 E90 335i M-sport
Default 09-25-2015, 04:23 PM
In order to use this kit do I need to have the Fuelit in tank sensor or does your kit come with everything I would need?
str8shot str8shot is offline
Car: N54 135i
Default 09-29-2015, 08:39 AM
You still need the fuel-it sensor install kit (es-1).
This is an alternative to their $129 JB4 only analyzer.
2008 Montego Blue 135i Coupe // Sport Package // JB4 G5 Iso in passive mode with custom e30 MHD tune // Bluetooth e85 content analyzer with JB4 integration // Walboro 255 inline pump // BMS downp|pes // VRSF 7" FMIC // ER charge pipe // Turbosmart BOV // Injen intake // M-Factory SMFW // F10 550i clutch // Vorshlag camber plates // Hotchkis FSB // Turner adjustable drop links // AST 5100 coilovers // Hawk HPS pads // Ti backing plates // Stoptech stainless lines // Turner 15mm front spacers
Car: N54 135i
Default 10-02-2015, 02:31 PM
Shipped a couple more kits in all flavors (bluetooth, JB4 only, and with the gauge).
Tried out the red gauge - it looks pretty sharp. It's going to look pretty rad behind the buyers vent:
bigdnno98's Avatar
bigdnno98 bigdnno98 is offline
Car: e92 335i
Default 10-02-2015, 04:12 PM
When you say, "This will display your ethanol content over pin 15 of the JB4 harness (typically used for meth flow). You can then view your ethanol content via gauge high jacking", are you talking about the JB4 displaying the meth flow in the dash? So instead of meth flow in the dash it'd be ethanol content? So this method isn't necessarily necessary? Is it possible to log the ethanol content in the JB4 interface?
2011 335is DCT, FBO
Nordic335IM3's Avatar
Nordic335IM3 Nordic335IM3 is offline
Car: BMW 335I N54
Default 10-03-2015, 05:30 AM
To get meth and E gauges at the same time in the JB4 interface, would it be posibble to log meth on pin 15 and E via bluetooth?.. (if the JB4 app was coded to it)
Logan's Avatar
Logan Logan is offline
Car: E90' 335i
Default 10-03-2015, 06:29 AM
i run meth with E85(a E55 Mix).how can i incorporate the both.Example I would like to either read ethanol content on fuel gauge or just use a digital gauge.Would like to know what kit is needed to do both.Not interested in bluetooth thanks.
Hassanchop911's Avatar
Hassanchop911 Hassanchop911 is offline
Car: E92
Default 10-03-2015, 03:14 PM
This is suppose to connect to iOS jb4
Car: 2007 e90 335i
Default 10-05-2015, 01:27 AM
If I buy your gauge do I still need the Eca? Does your gauge connect straight to the ethonol content sensor?
2007 e90 335i
rmz rmz is offline
Car: 2008 E90 335xi/AT
Default 10-05-2015, 05:19 AM
A few quick questions.
I would purchase the:
From you:
1. Basic ECA
2. Bluetooth Add-on
3. Harness Kit
Others (unless you sell these too):
1. Continental EC sensor
2. OEM fuel line + 2 quick connects and some clamps (oem style, like one of the pics you mounted)
Is the underlying data stream on the Bluetooth connection open (not-encrypted)? (When I connect with (Android)BluetoothSocket(), I can extract ECA/fuel temp etc) ? I ask because I want to use the ECA output in my own (personal) apps I write for my car/phone integration tinkering.
Thx!
Car: N54 135i
Default 10-05-2015, 06:53 AM
Correct. Gauge highjacking is just one of the ways you can view your Ethanol content. You can also use the JB4 interface.
Car: N54 135i
Default 10-05-2015, 06:56 AM
You would not be able to log both.
The Ethanol via bluetooth is completely stand alone from JB4 and doesn't need to plug into it.
The pin is there to connect to JB4 if you wish, but you would not be able to do that if you're running meth into JB4. The share the same input pin, and it's a limitation of JB4 at this time.
However; ethanol content is pretty static once you're filled up, so there's not much to log. You could manually annotate your file name with your E content if you wanted it recorded.
Car: N54 135i
Default 10-05-2015, 06:58 AM
Yes - the ECA is still required. It converts the sensor signal into voltage for the gauge. The gauge would plug into the pin on the ECA normally used for JB4 input.
Car: N54 135i
Default 10-05-2015, 07:01 AM
From you:
1. Basic ECA
2. Bluetooth Add-on
3. Harness Kit
Thx!
At this time I could sell you the ECA, harness, and bluetooth add on. I do have some basic authentication involved with bluetooth, but I would be happy to make you a one-off that would be a clear and un-encrypted data stream. It wouldn't work with my app, however.
You could flip between my app and yours using the un-encrypted bluetooth data by updating the firmware via USB. I could include both for you.
Hit my up over IM and we'll discuss it further.
Car: N54 135i
Default 10-08-2015, 03:47 PM
Two more kits shipped out!
ECA with gauge, and an ECA for use with the P3 vent gauge.
Red looks sharp. Way better than blue IMO.
Default 10-09-2015, 05:38 AM
So for any of these kits to work, one has to spend 100 bucks or so on the fuel it es-1 kit first, then an additional amount on any of your kits. I'm assuming your kits do not come with the continental analyzer?
2007 e90 335i
Hexon turbos
Trebila Custom tuning
Car: N54 135i
Default 10-12-2015, 10:02 AM
My kit is the content analyzer.
You do need a way to install the continental flex fuel sensor. The fuel-it ES-1 kit is probably the cheapest option.
What I'm making is a grass roots alternative (at a fraction of the cost) to their $129 JB4 only analyzer, which you also have to buy on top of the ES-1 kit as well.
I also have options like bluetooth and a stand alone gauge.
I6+TT=FTW's Avatar
I6+TT=FTW I6+TT=FTW is offline
Car: 2007 E90 335xi
Default 10-13-2015, 09:23 AM
Either I skipped the answer or am confused.
As a Cobb/PTF user without a JB4, how the hell can I use the fuelit sensor and your bluetooth analyzer without owning a JB4? Am I missing something?
Moving into winter I would really like to know what's in the tank, since "E85" can be as low as E70 in the winter months.
Thank you much.
2007 Jet Black E90 335xi /PTF-Cobb/E50/FuelitS2/5" Stepped FMIC/Synapse BOV and Charge Pipe/Black 19x8.5/245s all around/and more
Car: N54 135i
Default 10-16-2015, 02:51 PM
You would get the Bluetooth kit or the gauge kit.
They are totally stand alone and don't need to plug into jb4.
Bluetooth would display your content on an android device via my free app in the play store.
Car: N54 135i
Default 11-17-2015, 03:46 PM
All orders shipped out. More ready shortly!
dreyo27 dreyo27 is offline
Car: 2007 335i 6mt
Default 11-22-2015, 12:45 AM
I been trying to contact you on e90post. Have you had a chance to ship my order out yet?
Car: N54 135i
Default 11-23-2015, 02:29 PM
It should be there tomorrow. I sent you a refund for all the profit from this one due to the slow turn around via paypal. I just got too inundated with my regular job.
Sorry.
Car: N54 135i
Default 11-25-2015, 03:30 PM
Have a new display I'm trying out. This will work in conjunction with JB4 and or bluetooth (the previous display used the same voltage output as JB4).
The previous display read analog voltage in .01 increments for each percent of ethanol. For example - 1 percent ethanol would read as .01 on the display, 50% ethanol would read .50, etc.
This particular display uses a digital input, to display an exact reading from the sensor. Because of this, it doesn't suffer from any inaccuracies due to voltage fluctuation.
It's a little bit larger, and a few dollars more, but should provide for much more reliable readings.
This is compatible with any of the ECA's I've sold using three of the four twisted pair wires I had added that were reserved for future use, along with a new firmware that can be loaded via USB.
alvinhobh alvinhobh is offline
Car: 07 BMW 335i Coupe
Default 11-25-2015, 09:47 PM
Hey,
I have a BMS Meth kit installed on the car, and I believe I am using pin 15 to read the meth flow, can package A be used with jb4 using another pin?
thanks
07 335i e92 - money pit
noorj's Avatar
noorj noorj is offline
Car: Cobalt SS
Default 11-25-2015, 10:53 PM
How much for the full kit with screen and for bluetooth (not for JB4), and with the continental ethanol content sensor?
J. Dub J. Dub is offline
Default 12-02-2015, 10:03 AM
This is a neat deal. Subscribed.
