E90 335xi E90 335xi is offline
Car: 2011 BMW 335xi Sedan
Default FBO minus intercooler - what map to run? - 04-28-2015, 01:52 PM
Current mods are in my sig. Running approprimately E30 with 94 pump gas on map 5 and Steve has confirmed logs look good. Re-attached them here for reference (1st 3 pulls were for tuning). I'll be bumping up to E40 once I finish this tank of gas.
Getting a kitten-free ** installed this weekend too, so I'll have FBO except for the intercooler. No meth kit either.
What map should I run? When is it appropriate to run maps 2 or 7? Is it safer to just always run map 5?
2011 E90 335i xDrive 6MT
BMS JB4 ISO 5_9, FF wires, VRSF CP, GFB DV+
CHECKERED's Avatar
CHECKERED CHECKERED is offline
ex deus machina
Car: E92 N54 335i
Default 04-28-2015, 03:19 PM
Map 5 looks best
Garage Queen: Audi S4 4.2L V8, Vortech Supercharger, Bilstein PSS9 Coilovers, Sway-bars, RS4 brakes and rear BBK, Fast Intentions - Full Exhaust, 505AWTQ 0-60: 3.8s
Daily Driver: E92 335i N54: complete part out - let me know of any parts you need:
https://www.n54tech.com/forums/showthread.php?t=55650
tke344 tke344 is offline
Car: E90 LCI N55
Default 04-29-2015, 05:32 AM
The ethanol makes IAT much less important. I run a very aggressive tune with the stock FMIC, just ~E40 and my timing isn't affected.
Weehe Weehe is offline
Default 04-29-2015, 05:54 AM
Can't say that is really true. It may help a little since it burns cooler, but with back to back pulls your IAT will still clime and timing will be pulled if it goes high enough. But map 5 is what you should run.
Default 04-29-2015, 11:05 AM
Thanks guys.
Can someone explain why map 5 is best, and what the purposes of maps 2 and 7 are?
Default 04-29-2015, 11:20 AM
Map 2 is FBO with 93 octane. Map 7 is FBO with E40+ or race gas. Since you are between those, Map 5 is best because it will auto tune to your hardware and fuel. So you will get out something between map 2 and 7.
yanivvv yanivvv is offline
Car: M235i
Default Map 5 - 08-16-2015, 11:37 PM
How much time does it take to map 5 to adapt ?
Default 08-17-2015, 04:42 AM
You need to do 3 3rd gear pulls to redline.
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 08-31-2015, 11:02 AM
Off topic, but looking at your sig I saw GFB DV+ and had no idea what that was. Thanks to Google, now I want one. Does it simply take the place of the stock diverter? I didn't think you could upgrade it because it was built on the turbo. How tough it it to get to and replace? I kinda like my BOV sound, will I really lose that?
Thanks,
Troy
2011 335i xDrive ///M-Sport LeMans Blue Navigation iDrive 15% Tint N55 E90 - BMS Intake, Le Mans Blue Grilles, Le Mans Blue Rear Diffuser, Alpina B3 TCU Flash, Misc Coding, Matte Black Badge, Gloss Black Exhaust Tips, Blue Calipers*, VRSF Charge Pipe*, Cyba Scoops*, JB4 ISO 5.5, Sport Oil Cooler Valve, FlexFuel (Fuel Rail Pressure) Wires, GoFastBits DV+, Ethanol Content Sensor - No problems up to E70 fuel mix
* Painted 7251 Cobalt Blue Metallic - Matches LeMans Blue
Default 09-02-2015, 01:25 PM
Thanks,
Troy
I didn't do the work myself, I leave that to the pros... hehe. So I can't comment on how much of a PITA it is, but it does take a few hours since you have to drop the water pump and I believe there was some sort of liquid flush also needed.
I ordered mine off eBay I think because the price was right. Just make sure you order part # T9356.
You can download the install instructions from the GFB website but they're not N55-specific.
