RickiBobbii RickiBobbii is offline
Car: 2009 335xi
Default FS: Random N54 Engine bay components - 04-03-2015, 02:40 PM
Came off of 09 535i but interchangeable. I did an engine swap and these parts were still on the donor engine. All working order.
Oil Cooler
Intake manifold
Throttle Body
Starter
Water pump and Thermostat with housing
wiring harness for most of the above
i have coil packs and injectors also but am keeping some if not all, let me know if you need a couple though
MAKE OFFER- PHOENIX ARIZONA AREA
757-715-2522
"If you ain't first, you're last!"
SMOKEYWOKEY SMOKEYWOKEY is offline
Car: 335i E90
Default 04-03-2015, 03:19 PM
how much would you sell the injectors for? and coil packs
Fast335i's Avatar
Fast335i Fast335i is offline
Car: 07 BMW 335i
Default 04-03-2015, 03:39 PM
Can I put the oil cooler on my 07? Mone did not come with it....
2007 BMW 335i...M2 exhaust...Macht Schnell **'s...VRSF 7" FMIC...MM Performance inlet system.....VRSF Chargpipe with Tial BOV....MFACTORY LSD....MHD e60. Wedge tunING.........RB Stealths......N20 Tmap upgrade.....Steve Stage 2 450......H&R Race lowering springs...MT ET Streets 265/40/18 rear.....NGK 5992
Car: 2009 335xi
Default 04-03-2015, 03:40 PM
All of them? Maybe like 325 shipped 300 picked up.
Car: 2009 335xi
Default 04-03-2015, 03:45 PM
After doing a little digging, What I have is the oil filter housing to run the oil lines to the oil cooler. So I imagine you could use that and fab up an aftermarket oil cooler to those lines.
Car: 335i E90
Default 04-03-2015, 04:46 PM
would you just sell 3 of the injectors
SomeRandomDude SomeRandomDude is offline
Car: 2008 135i
Default 04-03-2015, 11:53 PM
Water pump and thermo best price?
chris0325's Avatar
chris0325 chris0325 is offline
Car: 08 335xi coupe
Default 04-04-2015, 04:07 AM
Do you have the air intake ducts that guide the air to the snorkel?
2008 Monaco Blue 335xi e92 JB4 DCI (sold)
2010 Alpine White 135i e82 JB4 g5 ISO,VRSF 7"FMIC, MMP Inlets and Outlets, BMS 3" ********* **'s, BMS 1.5 METH KIT CM10, Walbro Inline 255, 100% e85
Car: 2009 335xi
Default 04-04-2015, 01:03 PM
115 shipped
Car: 2009 335xi
Default 04-04-2015, 01:07 PM
I can do like 300. Shipped or picked up?
Car: 2009 335xi
Default 04-04-2015, 01:08 PM
Yea I do, I can pull mine since I don't need them anymore.
Car: 335i E90
Default 04-04-2015, 08:08 PM
give me a price on all 6 injectors shipped to 89031 Las Vegas PM.. I'll take them off your hands
Car: 2009 335xi
Default 04-04-2015, 08:40 PM
$230
Car: 335i E90
Default 04-04-2015, 08:44 PM
just to make sure I should be able to just hook them up right or do I need to code and reprogram them
Car: 2009 335xi
Default 04-04-2015, 08:46 PM
All years should not need recoding.These are oem bmw n54 injectors.
Car: 335i E90
Default 04-04-2015, 08:49 PM
perfect, since it's too late and tomorrow postal office is closed can we do everything on Monday? send you payment over PayPal
Car: 2009 335xi
Default 04-04-2015, 08:51 PM
I can ship Monday no problem but if somebody pays before you then first come first serve.
Car: 335i E90
Default 04-04-2015, 08:56 PM
no problem sounds good to me.. what's your email to your PayPal
Car: 2009 335xi
Default 04-04-2015, 08:58 PM
Pimptme@Yahoo.com
Car: 335i E90
Default 04-04-2015, 09:19 PM
I'll probably just send payment over tomorrow morning, I'll let you know before I do
Car: 2009 335xi
Default 04-04-2015, 09:21 PM
Sounds good
Car: 335i E90
Default 04-04-2015, 09:22 PM
what's the part numbers on the injectors? just to make sure
Car: 2009 335xi
Default 04-04-2015, 09:24 PM
Idk I'm not home
Car: 335i E90
Default 04-04-2015, 09:26 PM
Idk I'm not home
when you get a chance can you let me know what they are
e90tiag335i e90tiag335i is offline
Car: 2010 335i
Default 04-04-2015, 09:32 PM
Just a fyi. All injectors need to be coded when replaced. You may get buy but it won't be running as well as it could.
JB4, PT5858 ST, 3.5" exhaust, VMR V710, KW V3 coilovers, Wavetrac LSD, AKG subframe and diff bushings- Hybrid Ovations, Jehnert Doorboards, IDMax15 and 2 Arc Audio 1200.6 amps, white gauge cluster
