(#276)
Bergstrom Bergstrom is offline
Car: 335i Convertible 07
Default 10-05-2014, 12:02 PM
I measured the backlash and it was well within spec. If i didnt do it wrong that is!
measured it two times with the diff out between.
Strange because no one seems to have to use shims.
The sound isnt whistling really i cant explain it. At the same time as the LSD install i fixed a broken vacuum line to the exhaust flap. But today i heard that the flap is creating all kinds of strange of noises. It rattles at idle and reving it almost whistles. Could be that creating the nolse. Because before i fixed the line. That little flap made the whole convertible rattle like something was loose..
Also i found that people replacing the diff bushings to powerflex sometimes get a similar sound of resonance which the oem seem to absorb which the harder aftermarket bushing instead seem to amplify.
My car is also i convertible and i have over time developed the feeling of every small vibration gets resonated through the chassis.
dubbedown's Avatar
dubbedown dubbedown is offline
Car: 2013 135is DCT
Default 10-05-2014, 12:17 PM
You're right, whistling isn't really the sound I would describe it as if it were truly a backlash issue. It's more of a whine than whistle.
But noise coming from exhaust flap wouldn't happen from backlash issue. You said you heard whistling only on deceleration, and I'm assuming you mean gas off pedal not brakes being applied. Me thinks backlash too tight...
Just curious what gear oil did you use?
Recaro | Volk | AST | Vorshlag | Quaife | Stoptech | Active Autowerke | BMW Performance
Click here for my track videos
Default 10-05-2014, 10:51 PM
After some driving i found that i believe i hear something when driving low speeds, i can't hear it at higher speed.
Almost more like a resonating sound, lower frequency. When letting the gas pedal off i can only hear it from certain speeds. Say 50km/h. But sometimes i there is not sound, more like it's rpm and speed based.
Go higher than city driving and the noise is no more.
I used the standard Castrol 75-90 for without modifiers. Is there a better one?
najin23's Avatar
najin23 najin23 is offline
Car: 335i CDV
Default 10-16-2014, 07:31 AM
MFactory, what is the total lockup on your lsd?
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
MHD BMS hybrid E85 BEF,
3.5 bar,
E45,
Fuel-it! Stage 2 standard,
FBO,
Synchrotech(MFactory),
Bimmerlife R8 coils,
N20 plugs(0.020")
MFactory MFactory is offline
Car: BMW E92 M3
Default 10-16-2014, 08:48 AM
Helical LSD's don't lock, rather, they are in a constant state of torque bias between the left/right wheels depending on traction.
The maximum torque transfer to one side is 75%
najin23's Avatar
Car: 335i CDV
Default 10-17-2014, 08:51 AM
thanks
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
Hujan Hujan is offline
Car: E89 Z4 35i
Default 10-29-2014, 08:47 PM
The gear whine is a direct result of the harder bushings, which translate that resonance into the cabin instead of absorbing it. It's is most prominent on deceleration.
I got it on my E92 M3 the moment I upgraded to delrin/aluminum diff bushings on the OEM diff with no other changes to the diff other than the bushings.
Dietcoke Dietcoke is offline
Car: 08 135i
Default 10-29-2014, 08:57 PM
Originally Posted by trebila
well, I have a small pumpkin (2008 135i AT), I used to have the ball bearings with the stock differential ...
Also had the big ball bearings (japan) in my small AT diff. I think BMW went to the taper bearings from hungary in late 2008 year
08' 135i - Cobb Custom E70, FBO, suspension stuff.
(OLD) 11 Camaro SS - 10.20@135 naturally aspirated @630rwhp.
trebila's Avatar
trebila trebila is offline
Default 10-30-2014, 06:58 AM
my 135i AT is from 06/2008.
Default 10-30-2014, 09:05 AM
I presume the "small" and "large" housings are interchangeable? Swapping a 3.08 carrier from our 2009 E92 MT over to our 2008 E82 automatic.
trebila's Avatar
Default 10-30-2014, 09:20 AM
no, I think that if you want to swap small and large housings, you have to swap the shafts too.
Spxxx's Avatar
Spxxx Spxxx is offline
Default 12-22-2014, 05:23 PM
correct, def different lengths
135droptop's Avatar
135droptop 135droptop is offline
Default 12-26-2014, 07:25 PM
I know this is an old post but I'm getting my LSD installed with these same bearings. Hope it goes as well as yours.
Default 12-27-2014, 02:18 AM
Yes, it was quite a straight forwards installation, no need to hand it away.
We later on concluded that the sound was from the stiffer bushings, so be prepared for that.
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 08-21-2015, 01:30 PM
thread revival
anyone figured out what bearings to get on a 135i DCT?
did not find any info on this
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
trebila's Avatar
Default 08-21-2015, 01:43 PM
You should ask directly Stephen (MFactory).
treehouse treehouse is offline
Default 08-22-2015, 05:02 PM
I have a Mfactory sitting waiting to go in, but everything I read, said to re-use the stock bearings unless damaged during removal.
techwhiz techwhiz is offline
Default 08-24-2015, 04:44 PM
Yes.
I had mine installed at a local gear shop.
Reused the bearings, just new seals.
najin23's Avatar
Car: 335i CDV
Default 08-25-2015, 08:40 AM
If they damage the bearing during removal, I really don't know where you could get the replacement. So be careful
Getting there:
'07 E92 6mt,
MMP stage3 hybrid,
MMP Inlet/Outlet,
3.5 bar,
E45,
FBO,
N20 plugs(0.020")
