(#6226)
robc1976's Avatar
robc1976 robc1976 is offline
Car: 2007 335i
Default 02-14-2013, 05:33 PM
Originally Posted by imageautodetail
sure it was auto correct or what not, but what is a "sadie ith"
damn auto correct!!!
Pyr4t Pyr4t is offline
Car: 1M
Default 02-15-2013, 05:23 AM
Hello,
I tried to find the answer by reading here a lot, but I couldn't find it unfortunately. So, here's the question(s):
I'm driving a 1M and just ordered a G5 as an upgrade to the G4 which is currently installed. I also own a Cobb AP. Most important mods are *** with race cats, midpipes w/o cats, FMIC and intake.
* is there any advantage of using BMS flash (in combination with G5 ISO) instead of OEM flash with this configuration?
* is setting 6 ('G5 ISO w/ BMS Flash, 1M, or 335is') in the interface app the correct default even with OEM flash? e.g. does the wording in the interface mean BMS Flash with 1M or BMS FLash or 1M?
imageautodetail's Avatar
imageautodetail imageautodetail is offline
Car: 335 e90 spt pack 6mt
Default 02-15-2013, 05:32 AM
Originally Posted by Pyr4t
Hello,
id email terry about the bms flash, it is usually for upgraded turbos or high e85 content, but yes, that is the correct selection from the menu, the oem tune on the 1m is stronger than a stock n54 motor
alexim's Avatar
alexim alexim is offline
Car: 1M
Default 02-15-2013, 06:08 AM
Hello,
Are you running e85?? If so, depending on your mix, the flash will be good...
And yes, that is the correct setting on the jb4 interface...
Car: 1M
Default 02-15-2013, 06:25 AM
No, I'm running 93 octane (98 RON) pump fuel. E85 isn't available here unfortunately.
Thanks for the answers so far!
alexim's Avatar
Car: 1M
Default 02-15-2013, 06:34 AM
Then no need for the BMS flash.. It's only for those running larger turbos and/or high levels of ethanol...
Car: 1M
Default 02-15-2013, 06:39 AM
Ok, thanks! I probably just misinterpreted this post from Terry as I'm not using higher octane with 98 RON at all
ncat10 ncat10 is offline
Car: 335
Default 02-15-2013, 10:15 AM
Terry, if i have BMS flash, I must disable open loop auto learning ( FutureUseA = 2 ) ? Or I can just ignore it ?
Default 02-15-2013, 10:17 AM
No let it continue to adjust itself.
nada125 nada125 is offline
Car: 2009 335i
Default Confirm my JB4 updated correctly? - 02-16-2013, 07:13 PM
I just installed JB4 G5 w/ ISO firmware and updated it with GB5_ISO_HEX16B. My screen shot is attached and wanted to make sure it has beeen updated correctly. Does it look correct? Thanks!
N54 TuNeR's Avatar
N54 TuNeR N54 TuNeR is offline
Cool ///Member
Car: E90 SEDAN
Default 02-17-2013, 07:59 AM
My fuel open loop doesnt change,always stays at 80.i did disable it at one time before the flash was installed.how do i know if fuel open loop is auto learning now?i did set all my FU to 0 since the flash been installed for some time now.what happens if fuel open loop is raised to 85/90?does that lean it some?Another thing i notice my wastegate adaptation is at 97,is that considered high or normal.im still on stock turbos.i am using e85 mix too,still with stock lpfp intank.
SOLD
2004 E46 ///M3 MODDED
PRESENT RiDE
2008 E90 SEDAN G5 iSO-FBO FSB-100%METH-DUAL NOZZLES,Fuel iT!Stage 2
buskeyl's Avatar
buskeyl buskeyl is offline
Car: 201 535i M sport
Default Been gon a while.. Need a little help. - 02-17-2013, 10:04 AM
Can't PM Terry to ask, So I'll fire away here.
Terry posted once something about hitting the volume down button while punching it, related to traction somehow. I cant find that post. Does this ring a bell? Can anyone link me to it?
Also, is the latest firmware for JB4 G4 sill the one linked to at the bottom of this this thread? N54_082112.HEX?
Lee
___________________________
  • 2010 535i M-Sport, Sport Package, Premium Package, Comfort Access, Cold Weather Package, Active Xeon, JB4 PNP, DCI
  • 2004 Volvo S60R
  • 1995 Chevy Tahoe - 230K miles, still plugging away
  • 1987 Mazda MX-6 GT 4WS - RIP
e90man's Avatar
e90man e90man is offline
N54ever
Default 02-17-2013, 10:09 AM
Yep that's the latest FW.
I do recall the volume down thing somewhere but don't remember what it's for.
FRNTHVY's Avatar
FRNTHVY FRNTHVY is offline
Car: AW135/E30M3 Junglegym
Default 02-17-2013, 10:28 AM
Looks good from what I have found. I'm not sure if you will get any help though. I posted basically the same question in the support section but also wanted to know if there were other settings to optimize my set up but I never received a reply Good luck.
Sam
Car: 2009 335i
Default 02-17-2013, 11:28 AM
Sam
Thanks Sam! I think it's updated correctly and just checking with those who are more experienced for confirmation. Sometimes my OCD kicks in.
I did a few runs on Map 1 this morning and all is good. Car pulls nicely from 60 to 120 quite quick and smooth. Planning to stay on Map 1 for a bit then switch to Map 5 and just leave it.
mzman mzman is offline
Car: 135i, 944T, M3, MRoad, Miata
Default 02-17-2013, 11:49 AM
Lee
It sounds like you are referring to the first gear boost limit override. If you have first gear limited you can hit and hold either down button on the steering wheel to override it, allowing you to do burnouts for example.
Current Euros:
'08 135i AW/CR -- FBO, E35, WW Meth 40/60 M/W
'95 M3 Blk/Blk -- Cosmos V2 intake, Borla exhaust, 3.5in MAF, 24# Inj., LTW FW, Turner chip, Euro Brakes, Koni S/A's, H&R Sport springs
'88 944 Turbo S SRose/Tan -- Too many mods - 401rwhp/429ftlb
'99 M Roadster AW/Blk -- Stock
Past Euros:
'87 944S GR/Blk -- Exhaust, Intake, throttle cam, coil-overs
drift4's Avatar
drift4 drift4 is offline
Car: E90
Default 02-17-2013, 12:28 PM
where can you find the different firmwares?
Default 02-17-2013, 12:35 PM
6AT or MT?
First post in this thread.
Current Euros:
Past Euros:
Car: 2009 335i
Default 02-17-2013, 12:38 PM
[QUOTE=mzman;249513]6AT or MT?
It's a 6AT.
drm916 drm916 is offline
Car: 08 335i
Default 02-17-2013, 06:36 PM
Very cool. Never heard of that. I will have to try that out on the G5 iso.
Default 02-19-2013, 12:08 PM
Added ISO 17 to the first post.
kev335i's Avatar
kev335i kev335i is offline
Car: E93 335i
Default 02-19-2013, 12:15 PM
Manual transmission cars should set "Auto Shift Reduction" to 0. The setting of 60 is required for automatic (DTC and steptronic) transmissions only.
Still applicable to manual cars i take it?
Mods: JB4 (G5 ISO), Cobb AP V3, Aquamist HFS-4, BMS DCI, AR Design **'s, ETS FMIC, ETS Charge Pipe, HKS SSQV BOV, BMS CDV, BMS OCC & BMS Clutch Stop..... so far!
Default 02-19-2013, 12:28 PM
Yes
Maximum996's Avatar
Maximum996 Maximum996 is offline
Car: 08 535xi
Default 02-19-2013, 01:42 PM
? About hex17, what would be the benefit keeping default wastegate position to fully open when engine is off? Less rattle upon startup, cause that would be great?
Default 02-19-2013, 02:09 PM
That is just how the factory DME does it. So we changed the ISO to mirror their logic. No need to close the wastegates with engine off.
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
