(#2476)
mobilefitt's Avatar
mobilefitt mobilefitt is offline
M3 Eater (m3eater)
Car: 07 E90 Non Sport...Sleeper
Send a message via AIM to mobilefitt
Default 05-31-2011, 03:13 AM
sounds like a torrent love affair. I had a similar set up, new the guys that worked on my car, tipped them well. I was that much more livid when these same guys that I thought were my friends let some jack ass upload the lag infested software of a few years back. I was pre 2.92 be design for over 2 years before they neutered my car. . This guy then crashed the dealership computer on my car, couldn't reset the adaptions and called me up with it stuck in a fast idle saying, can you come pull your tune out for us? BTW that will be $500 for a DME reprogram that, oh by the way, everyone here knows you didn't want!.
JB4 15ohm w/ FSB & CM10, ETS-FMIC, Evolution Race Works charge pipe, Forge DVs, AR *********, Injen dual cones, DIY catch can-vent to atmosphere, Koni FSD,TSW Donnington 18's, Bridgestone Potenza 760 Sports.
pbonsalb pbonsalb is offline
Car: 2002, Bavaria, E39 528i, E36 M3, E61 535xit
Default 05-31-2011, 04:44 AM
While Map 0 on a JB4 is the stock map, would the presence of the JB4 even in bypass mode interfere with a dealer reprogram and expose itself that way?
EnjoixE92 EnjoixE92 is offline
Car: 2011 335is DCT
Default 05-31-2011, 05:12 AM
Sad sorry man and pbonsalb, I think the same. I placed it on map 0 when i brought it in. they didnt even find my tune. my bud who works there ask if i had a tune. were real close so no worries.
mobilefitt's Avatar
M3 Eater (m3eater)
Default 05-31-2011, 09:02 AM
No way to detect just yet at the dealership unless they open up The ecu.
eckodog1 eckodog1 is offline
Boost Rat
Car: 2007 335i
Default 05-31-2011, 02:13 PM
Do not leave JB4 in for reprograms. The stock ECU will not recieve the info and dealer will waste many man hours trying over and over again. This happened me, the dealer didnt care it was there, they even uninstalled and reinstalled it to reprogam. They were just pissed that they wasted man hours and shop reprogramer for 2 days before i told them. Just take 45 minutes and yank it out, save the risk/headache.
'07 335i step. JB4, raceland ********.
Default 05-31-2011, 02:50 PM
As long as its on map 0 there should be no issues. Myself and hundreds of customers have updated that way. But safest thing to do is remove it if you are concerned.
Boost Rat
Car: 2007 335i
Default 05-31-2011, 03:15 PM
Ya, i thought that would be the case also. But they tried for two days after my new fuel pump recall and were about to order an ECU under warenty. Then they unhooked it and all was good. I will try again next time I go for a reprogram.
2Slow's Avatar
2Slow 2Slow is offline
Velocity Challenged
Car: 2007 335i AT
Default 05-31-2011, 06:29 PM
Hey T, what goodies are planed in your next bag of tricks/firmare update?
Default 05-31-2011, 06:30 PM
Been pretty busy lately, lol. Should have a new alpha firmware ready for testing later this week.
Originally Posted by InTheWorks
1) Adjusted heavy part throttle wastegate mapping to reduce part throttle oscillation.
2) Corrected bug allowing effective PWM limit to be raised an additional 0.4%.
3) If the "mode" option under settings is set to any value greater than 0 user settings will not be reset to default during firmware uploads. Useful for those with custom mapping, etc.
4) Enabled methanol mapping additive and overflow failsafe for user definable map 6 as well as map 3.
5) Fixed bug with map 6 lower rpm boost values not saving.
6) Fixed bug with false 2ABC code triggered at very high elevations of 10,000'+
7) Added support for VC2/CMGS FSB by setting FutureUseD to 100, and JB4 direct FSB by setting FutureUseD to 99.
8) Changed unused "FpSafety" user adjustable to "FpMapping" adjustable now used for fine tuning fuel pressure. A value of 0 disables fuel pressure mapping. A value of 90 matches the previous setting and is the new default.
9) Moved disabling adaptive FFPID from FutureUseD=99 to FutureUseD=98.
10) Adjusted laptop steering wheel commands to only function if FutureUseD=1 is set disabling normal steering wheel controls.
11) If FutureUseD = 7 then "Exp1" displays water temperature in F.
12) Added alpha "max cool mode" feature. Enable with menu 6 option 1. Disable with menu 6 option 2. Water pump and fan will run at 100% duty when water temperature is between 160 and 202 degrees F. At 203 degrees F the DME ignores the fan command but appears to continue to overrun the water pump. We'll keep working on finding a way to extend the fan range upward to make the feature more useful.
13) If FutureUseD = 77 then in addition to DB9/4 being used for the nitrous trigger KMH is also logged under Exp1.
14) Added WaterTemp, EGT,and AFR options to gauge hijacking. Note EGT is read from factory DME and more study is required to determine if there is any useful application for it as a gauge.
15) Changed menu 2 for fuel gauge only options and added menu 7 for oil gauge only options. Allowing independent configuration of 7 parameters on each.
doogle's Avatar
doogle doogle is offline
Car: BMW 135i
Default 05-31-2011, 06:39 PM
Does this mean you will be selling a new meth kit without the VC2/CGMS but with the new failsafe?
tofu tofu is offline
Car: 335i e92
Default 05-31-2011, 06:40 PM
"Adjusted heavy part throttle wastegate mapping to reduce part throttle oscillation."
2Slow's Avatar
Velocity Challenged
Car: 2007 335i AT
Default 05-31-2011, 07:49 PM
Looking forward to 4) and 7)!
timhatimay's Avatar
timhatimay timhatimay is offline
Default 05-31-2011, 08:02 PM
I've noticed the last few days that at some point during every trip the turn-signals light up for just a moment then go away. I haven't linked it to any sort of behavior. I also have the P3 Cars V2 Gauge...Anyone see this?
Thanks,
Tim
Default 05-31-2011, 08:04 PM
No idea if the V2 gauge is fully compatible with the JB4 as they both use the CANbus. But that would be my first suspect if odd things are happening.
Default 05-31-2011, 08:47 PM
Yes, we will offer a kit or two with the FSB only.
SlicktopTTZ's Avatar
Turbo Lover
Car: 300zx TT, 1M
Default 05-31-2011, 08:49 PM
At what temp do the water pump and fan normally run at 100%, if ever?
Default 05-31-2011, 08:58 PM
Takes quite a bit of temp normally. > 240 IIRC.
HaZe_X HaZe_X is offline
Car: 2011 335is
Default 05-31-2011, 09:28 PM
Installed my JB4 on my 335is today, car only has 190 miles on it. I only tried Map1 for a few <4500rpm pulls, wow, what a difference. I set it back to map0 though while Im still in break in.
Stupid me forgot to update to 4/22 firmware though, so Ill have to go through everything again tomorrow
2011 335is Le Mans Blue l Black Interior l Convenience Package l iDrive l Heated Seats l Manual Trans l JB4 l BMS DCI l AWE BOV
Order Date: 4/12/11
Delivery: 5/30/11
DarkPhantom DarkPhantom is offline
Default 05-31-2011, 11:07 PM
No USB routed through the glove box?
Car: 2011 335is
Default 05-31-2011, 11:30 PM
I intended to, but I was so excited once I installed it I forgot to do that also, lol. Atleast me doing it again will give me extra practice
Order Date: 4/12/11
Delivery: 5/30/11
Default 06-01-2011, 04:28 AM
Thanks,
Tim
If it is happening near redline, it is the shift light. The steering wheel control guide says it can be turned on or off, but I have not tried yet. I have the February update JB4 and get the shiftlights on my auto trans left in D.
cotmfk cotmfk is offline
Car: 335
Default 06-01-2011, 11:29 AM
Terry, with the coming onslaught of people with RB turbos, is there any chance for an RB turbo specific map? One no meth? Or is there another route we should be using? Thanks!
elsabor67's Avatar
Enjoys Retirement
Car: 09 135i with M-sport Pkg
Default 06-01-2011, 11:55 AM
Finally Maxcool........
Did some more logs today and will be sending them in very soon.
Turbo Lover
Car: 300zx TT, 1M
Default 06-01-2011, 01:01 PM
i freaked my friends out with that too.
just2sxy just2sxy is offline
Default 06-01-2011, 01:05 PM
where did u get that maxcool firmware?? i neeedddd !!
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
