Denobd Denobd is offline
Car: 535i
Default fueling experts please help - 07-21-2019, 03:32 PM
good afternoon everyone. i a hoping to get a little help / insite from some of the more seasoned folks on the forum. this is the issue i am having. i have very long cranks when starting the car after its sat for a few hours. also at random times wot and normal driving i get the half engine light and message on the i drive screen that says fuel pump and then my engine shuts down.
these are the codes i get
2AAF- fuel pump plausibility
2A2D- low pressure system
i am trying to post my datazap link for the log but it wont let me. but to me LPFP, and Rail pressures seem to be holding up fine. i think my EKPM is failing. but i am trying to get some other opinions.
thanks in advance for any help.
gunda gunda is offline
Car: BMW 335i E92
Default 07-22-2019, 04:40 AM
Low pressure fuel sensor, goes all the time. I had the exact same symptoms recently, but I also had a nee LPFP & EKPM module. If you notice your LPFP reading is staying stuck at a number then it’s the sensor.
Car: 535i
Default 07-22-2019, 05:00 AM
sensor was just replaced recently.. lpfp number reads from 72- 90 psi thruput the pull. 72 looks to be where i let off the gass to change gears..
Haynpunch's Avatar
Car: 07 E90 335i
Default 07-22-2019, 07:54 AM
Post the csv file in the support section
07 E90 AT - xHP
JB4 G5 - Trebila BEF
FBO
Hybrids
Car: 535i
Default 07-22-2019, 04:49 PM
How do I post the csv file?
Default 07-23-2019, 10:22 PM
Throw up a post in the support section.
Post a log...
Advanced settings— manage files
ludo ludo is offline
Car: E93 335i
Default 01-25-2020, 09:37 AM
Post a log...
I'm also experiencing fuelling issues
Car goes limp without throwing anything on the dash
got 2AAF code
you'll find attached two logs
what do you guys think about it ?
inline6xi inline6xi is offline
Car: 2008 bmw 535xi
Default 01-25-2020, 06:03 PM
have your injectors been replaced? are you running ethanol?
when injector seals wear out and start leaking they will leak fuel into the cylinder while the car is off. this can cause rough starts that you describe.
Default 01-27-2020, 07:18 AM
got 2AAF code
We’d need a jb4 log to evaluate
-moving to support section
