(#126)
tunanocrust tunanocrust is offline
Car: 07 335i MT
Default 04-03-2019, 11:21 AM
Building one of the Mfactory diffs. Large housing with a 3.08 Ring gear (07 335i coupe, Manual, Vehicle Build date 09/06).
Was hoping someone could provide the following tolerances;
- Backlash
- Bearing Preload
I've done some searching and found a couple different tolerance suggestions for Backlash but not much at all on Bearing Preload.
MFactory MFactory is offline
Car: BMW E92 M3
Default 04-03-2019, 11:32 AM
If you give our shop a call, they should be able to assist: 909-592-5933
MFactory / YCW Engineering (LSD's, Gears, Flywheels, Clutches, Driveshafts, Axles) - www.teammfactory.com
YCW Suspension (Mid-Range Coilovers) - www.ycwsuspension.com
SWIFT Springs Europe (Exclusive Distributor) - www.swiftspringseurope.com
SWIFT Springs Asia (Exclusive Distributor) - www.swiftspringsasia.com
theobjectivist theobjectivist is offline
Car: 2008 535i
Default 04-06-2019, 08:10 AM
can you confirm options for a 535i 6 speed?
I need a built diff sent to me first and then I send my core back. Is it true that these are custom units only, and with elevated pricing?
Car: BMW E92 M3
Default 04-06-2019, 12:45 PM
You would need to give our shop a call regarding cores/built diffs: 909-592-5933
Default 10-27-2019, 05:33 PM
Sounds like the transmission. What are the codes thrown?
Car: BMW E92 M3
Default 10-28-2019, 08:15 AM
