DSCOFF's Avatar
DSCOFF DSCOFF is offline
Car: 335i coupe N54
Default 2F7B oil pressure switch plausibility - 09-01-2017, 06:18 AM
I get this code popping up from time to time. And it's not accompanied by any other codes.
Anyone know the cause? Is it related to bad ground issues ?
Tx
DSCOFF's Avatar
Car: 335i coupe N54
Default 09-03-2017, 02:05 AM
No one?
E9xjake E9xjake is offline
Car: 09 335xi
Default 09-11-2017, 05:20 AM
Did you ever figure this out? I got that code too and my car runs like crap out of no where but mine came with other codes
@e9xjake 09 E90 335xi 6MT
JB4|BMS BEF|Doc Race w/PTE6266|VRSF CP w/Tial BOV|VRSF 7" IC|Fuel It! Stage 2 Bucketless|E40|
Car: All of 'em
Default 09-11-2017, 05:42 AM
Do you have a modified oil circuit? Are you running extra coolers or anything?
What brand and weight oil are you running?
DSCOFF's Avatar
Car: 335i coupe N54
Default 02-11-2018, 12:27 AM
Yeah just using the liquimoly 5w-40 and I change it every 3500km since Im running 100% E85.
It came on today again but no discernible symptoms from the motor.
Ive had this code for as long as I can remember.. it just may need replacing the switch..
vwetish's Avatar
vwetish vwetish is offline
Car: BMW 335I / VW 2.0T
Default 11-20-2018, 11:13 AM
Did you solve this issue?
