Jus2sikwitit Jus2sikwitit is offline
Car: E92 335i XDrive MSport Coupe
Default E series n55 jb4 went haywire - 06-13-2018, 09:20 PM
Driving today out of nowhere i get christmas light on the dash my radio navigation screen goes black my wipers turn on signal stays on...steering wheel is still responsive as well as brakes as normal and at the end of it all i get a coolant temperature symbol on my dash i pulled over shut the car off turned it back on and everything appeared to be normal but the jb4 pulled all these codes can someone help...i checked my coolant level it was fine my waterpump was running i tested it with the bleed procedure and even my charging system light went on but when i restarted the car it went away and hasnt come back on battery voltage has been going between 13.8 and 14.3 volts so all appears normal i just dont know what to make of all these codes the jb4 app gave me.
32d5
32d7
32d6
32d3
3886
3792
3847
378f
3446
00f1
All have no description next to them pleae help
Could a short circuit in the jb4 due to loose or dirty connection cause these issues? A lot of the codes dont even exist in the list for the n55 and the ones that do exist for the e92 n55 are for waterpump and battery voltage which after checking seem to be running fine. No lights voltage is where it should be waterpump is running fine thermostat is opening and closing. I just dont see how all these issues can occur out of nowhere when i have a less then 5k waterpump thermostat and battery on the car
E92 LCI, N55, JB4, MHD W/BEF, CAI
Last edited by Jus2sikwitit; 06-13-2018 at 09:38 PM.. Reason: Missing information.
Alturiak's Avatar
Alturiak Alturiak is offline
Enthusiast
Car: 2011 E92 335i
Default 11-12-2018, 11:00 AM
Did you ever get this resolved? I got the same exact thing over the weekend... occurred while I was testing map7 on E50 and there was a boost spike that caused my hpfp to crash...
I'd love to know whats going on though
Default 11-12-2018, 11:35 AM
Check your alternator first
Alturiak's Avatar
Enthusiast
Car: 2011 E92 335i
Default 11-12-2018, 11:38 AM
When I checked it with one of those meters at autozone they said the alternator was doing fine... What about the alternator would cause this issue?
Default 11-12-2018, 12:06 PM
My voltage regulator was on the way out i started having over voltage issues. That over voltage can damage other sensors and electrical parts. If i was you i would change the alternator or even just the voltage regulator (inside alternator) to start. What ignition coils are you running?
Alturiak's Avatar
Enthusiast
Car: 2011 E92 335i
Default 11-12-2018, 02:24 PM
The alternator seems like a pretty expensive job to do... thinking I'll start with the voltage regulator. Did you replace your alternator and voltage regulator altogether?
I'm running Delphi replacement coils with less than 5k on them...
Alturiak's Avatar
Enthusiast
Car: 2011 E92 335i
Default 11-12-2018, 02:26 PM
Also I'm running a Pure Stage 2 with E50, trying to get map7 to work without shutting my car completely down lol
Default 11-12-2018, 10:35 PM
Record a log, and lookup the code descriptions in the N55 code PDF to get a feeling for what is going on.
Alturiak's Avatar
Enthusiast
Car: 2011 E92 335i
Default 11-13-2018, 02:56 PM
Here are my codes after the event happened:
3106 ******* ******** installed (ignore)
32D5 - not listed on pdf
32D7 - not listed on pdf
32D6 - not listed on pdf
32D3 - not listed on pdf
3886 - System voltage: Voltage too high
32D9 - Vehicle speed, plausibility: Minimum speed in
coast mode not reached
3847 - not listed on pdf
378F - BSD message from electric coolant pump:
missing
38A4 - Intelligent battery sensor (IBS): Communication
fault
3446 - BSD message from the oil condition sensor:
missing
Attached is the log from when it happened as well. I've already got a voltage regulator on order. Any idea what's going on? These events only happen during WOT...
If you need any other info just let me know
Alturiak's Avatar
Enthusiast
Car: 2011 E92 335i
Default 11-13-2018, 03:02 PM
And for reference here is the last log prior to that run several weeks ago, in map 2 where everything looked okay to try map 7
