I M inluv340 I M inluv340 is offline
Car: BMW 340i FBO WMI
Default 01-25-2018, 10:28 AM
I understand what you guys are saying and thank you for the info. I think what people are going to want to know is a PSI recommendation thatís relatively safe. Do we feel pretty good about 20 add? Which is roughly 17-18psi? An actual number would be best.
Everyone running this set up is FBO and pushing x98 through CM10-CM14.
Peter @ Pure's Avatar
Car: F20 M135i
Default 01-25-2018, 11:11 AM
It's your car you run whatever you want. Logic dictates that too much power on lean afr's is not good for the longevity of the engine.
What other people run is their choice. I will have a PS2 on the shop car and I will start running it at 15-16 psi and monitor it for some time. Possibly run 20% E and dual CM7/5 and monitor AFR and DME_BT.
Time will tell if these engines will hold up. It's better to run 15-16 psi on PS2 then to run 19-20 psi on PS1. More power at less boost is always better. Once we find a way to richen AFR it will be like having a new car with the extra power
F21 M140i - 100-200: 6.95
Audi TTRS - 100-200: 4.47 60-130: 5.16
F80 M3 - 100-200: 4.45, 60-130: 5.1
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
Thumbs up 01-25-2018, 12:11 PM
Thank you thatís all I wanted to know
Bullitt1841's Avatar
Default 01-25-2018, 01:08 PM
Trust me, I have no plans on testing the theory. All I'm saying is that no one can definitively state what is "safe" without data. Right now we are just going on previous experience and intuition.
But the safe thing, in my opinion, is to also try and achieve the factory targets. Experience also tells us that running richer and cooling combustion temps will also keep us "safer."
Default 01-25-2018, 01:48 PM
People ask this question all the time. "How much boost can I run?"
Simple answer...we don't know. 18psi may be fine for car A and not for car B. Too many variables, that is why we always ask for logs. CM 10-14 ....I'm assuming you mean dual CM5 or dual CM7's?
Default 01-25-2018, 01:57 PM
Correct. A total of CM10/14
hardparker hardparker is offline
Car: F25
Default 01-25-2018, 05:56 PM
Is the B58 wheel set the same as the compressor and turbine in the N55 stage 2? What are the wheel specs? I assume it's the same upgraded bearing and shaft setup, too. No?
Car: F20 M135i
Default 01-25-2018, 11:45 PM
Yes CM7/5 combo or CM7/7 combo would be fine.
peter@pureturbos.eu
pureturbos.eu
Default 01-27-2018, 11:43 PM
Friend just got a 2014 M6 DCT (stock) did 2 60-130ish runs at 16psi(peak) and went toe to toe. Not bad for conservative boost.
Pure Turbos's Avatar
Pure Turbos Pure Turbos is offline
Default 02-03-2018, 11:29 AM
That's excellent for only 16psi peak! Looking forward to more!
Default 02-22-2018, 09:01 AM
Went to a stand alone meth kit and running CM10 total instead of higher value and just using meth instead of x98. I get M1 at the pump for $2.80 a gallon is it worth ordering 5 gallon drums for $42 vs just using meth? I donít notice much of a difference in logs or feel. Thoughts?
Default 02-22-2018, 02:32 PM
Meth will require more volume than E98, that is the biggest advantage to running E98.
Default 02-22-2018, 07:11 PM
What do you think the efficiency range is of this turbo? Feels like at 16-17 itís still below it.
Default 02-23-2018, 03:20 PM
That would be a question for Pure as we don't have the efficiency charts or anyway to test and verify, especially since we haven't come anywhere close to maxing this turbo out due to the DME limitations.
KrS24's Avatar
KrS24 KrS24 is offline
Car: e92 335i
Default 03-19-2018, 10:51 AM
PI yet?
Default 03-24-2018, 03:16 PM
No point to it until we get the tuning resolved.
Hoosier Daddy Hoosier Daddy is offline
Car: M140i
Default 03-26-2018, 05:34 AM
Steve,
Just require some clarity. So you're currently utilising BMS's meth kit through the JB4 to deliver ethanol? Considering this is a preliminary solution until we can eventually crack why the DME hates us so much? Have you altered the system in anyway? Are you using the stock meth bottle or a fuel cell now?
The gains of this kit are sublime, but long term makes little sense to run the car in this state of tune. Do we know whether the DME looks at AFR, fuel flow or another parameter (or a multitude) before shutting down the throttle?
Mrpink Mrpink is offline
Car: M140i
Default 05-13-2018, 11:53 PM
What do you guys make of this?
https://k8-strasse.com/chip-tuning/b...x-m140i-340-ls
AndreySPB AndreySPB is offline
Car: Bmw 320i lci
Default 05-14-2018, 01:18 AM
In Russia b58/b48 ecu remap is already available.
Car: 335i, 2009
Default 05-14-2018, 08:52 AM
If real, we might be very close to getting new fuel scalers.
M3 F80 2017 Competition & Carbon Brakes
JB4 ||| H&R Sport Springs
X5 50i 2013 ///M Sport
BMS Stage 1
jpsimon jpsimon is offline
Car: 335xi coupe
Default 05-16-2018, 12:52 PM
I emailed K8 Strasse and they confirmed they are able to flash the B58, and thus also got around the fuel cap issues. I had to use google translate to send them the email, but I think it was very clear and they responded like they knew what I was asking. They said they'll be posting more info + dyno on their instagram soon: https://www.instagram.com/k8_strasse/
BSM 340i xDrive (6MT, M-Sport, etc)
datazap.me
Car: 335xi coupe
Default 05-16-2018, 01:01 PM
Others have emailed them as well and got some other info: The flash is done via the OBD port and can take up to 8 hours depending on what is being changed. The flash is currently only being done in Moscow but they intend on expanding to other authorized dealers.
datazap.me
remko3dl's Avatar
remko3dl remko3dl is offline
Car: 440i Coupe
Default 05-16-2018, 02:11 PM
I read on their website that they also offer a remote service via laptop/internet ;-)
Default 05-16-2018, 07:37 PM
That's a step in the right direction...think we'll wait until it's stateside and a little more robust though.
@MHD
Mr Carrots Mr Carrots is offline
Car: M240ix
Default 05-16-2018, 08:10 PM
They told me the fuel pump hardware limit is 430 max HP, and I can believe it since the b58 looks like it uses the same setup as the b48 (same parts inc injectors)
I thought this platform was supposed to use a much better fuel pump than the n55?
