Default G Chassis N63R JB4 - 11-12-2017, 07:17 PM
BMS data cable hard wired directions and software Click here
Maps:
Map0: JB4 disabled
Map1: Additive map, up to 5psi requested over stock
Map2: Additive map, up to 6psi requested over stock
Map3: Absolute map, 18psi peak
Map4: Stock with CANbus active for logging and in dash gauges
Map5: 20psi peak target ramping up towards redline
Map6: Custom tuning map
Map7: Very aggressive unleaded race gas map, will likely require EWG connections added.
Map8: Progressive WMI (water meth injection) mapping
Firmware
To update firmware if you have issues loading change upload timeout to 25, disable Wifi, and place phone close to the JB4 box under the hood while updating.
JB4_G30_N63TU_2_T1:
1) Expanded map options as outlined above.
2) Enabled map switching in dash using BC button to allow toggling between map1, map2, and map0. See video below.
3) Added logic to start testing EWG control so the JB4 can control higher boost targets. Will require you to add in two "N55 EWG" connectors from our site in to the JB4 harness. Still in the development phase so details to follow when complete.
How to update firmware:
For firmware updates if having issues we suggest you turn off WiFi, change upload timeout to 25, and set your phone next to JB4 box under the hood.
sheharyar_rr sheharyar_rr is offline
Car: 2014 335i M sport
Default 11-12-2017, 07:28 PM
FINALLY!!!!!!!!!!!
Did you guys get hands on a car? dyno?
Default 11-12-2017, 08:13 PM
Wasn't able to do any dynos, yet. Just track logs and testing. But dynos will follow sooner or later.
Car: 2010 535
Default 11-13-2017, 02:40 PM
awesome!
SOURCE1064 SOURCE1064 is offline
Car: Daily 08 335I Weekend 05 M3
Default 11-15-2017, 09:49 PM
Awesome! Turning in my F80 M3 this week and picking up a 18 750xi next week. Can’t wait to get a tune in it.
Charlie
2015 ///M3 Black Sapphire Metallic/ Black Extended Leather/ Carbon Fiber Trim
Default 11-15-2017, 10:45 PM
Tempted to buy stage 1 for my M550i, is it worth waiting for JB4+BCM if i'm gonna run 94 Octane?
Default 11-16-2017, 09:21 AM
I think the JB4 is ultimately worth it if you're in to data logging and getting the most out of the car. You could start with the JB4 without the BCM even.
Default 11-20-2017, 12:16 PM
Any time frame as to when the firmware will be released?
Default 11-20-2017, 12:47 PM
For what? Stage1 is out now. For JB4 firmware, email me if you have the hardware already, and we can go through the details.
bhartlage bhartlage is offline
Car: M550i
Default 11-26-2017, 03:04 PM
If I understand correctly, it sounds like the S63TU JB4 will be compatible with the N63TU2 engine in the M550i in the near future with a firmware update. When this is released for the M550i will it be a fully supported JB4 release that doesn't have a permanent CEL? I believe I read in another thread that the JB4 for the N63TU was placed into an unsupported release due to a full time CEL. I just want to validate that the N63TU2 engine in the M550i isn't in the same boat when using the S63TU JB4. I've been holding off on tuning my M550i in hopes of a fully supported JB4 so please advise.
Default 11-26-2017, 06:31 PM
As it turns out the G series uses TMAP sensor tuning rather than MAF tuning for load targets, similar to the N63 and S63TU. So won't be any issue with having to unplug MAF sensors or the related CEL.
Car: M550i
Default 11-26-2017, 07:03 PM
Thanks for the quick response Terry. Please keep us posted on the N63TU2 JB4 release date. Any idea what the TQ/HP gains will be on pump 93 w/out BCM?
Default 11-26-2017, 09:32 PM
He already has a firmware for it, email him. I'm interested in the gains too w/out BCM against Stage 1 which I just got, have yet to install it though
Default 11-26-2017, 10:17 PM
The power gains seem to be similar to the F series N63TU. But we'll get one on a dyno sooner or later. Just difficult to get an apples to apples with the AWD.
Default 11-29-2017, 08:39 PM
Just installed the Stage 1..... HOLY ****!!!!!! Man this thing is scary fast
Default 11-29-2017, 09:34 PM
Default 11-30-2017, 12:10 AM
Stage 1 0-200 run. Spun slightly with skinny winters
Car: 2010 535
Default 11-30-2017, 06:07 AM
I cant wait to see dyno comparisons
Default 12-01-2017, 11:13 PM
Can I bump the PSI up from stock on the stage 1? Using 94 octane here
Default 12-02-2017, 10:52 AM
For Stage1 in theory you can adjust it to +4psi over stock by entering 4.0 under "boost limit" and changing it to map3. But, if making more boost is the goal, JB4 is what you'll want to do.
That reminds me, can you post some photos of your TMAP sensor positions with the wires on? Have another customer who can't find them and I don't have a G series 550 handy to shoot photos for it.
Default 12-02-2017, 03:52 PM
Yeah... that was me asking for pictures, got it installed from a professional, it was indeed on the spot you pointed out and the driver side intercooler was where M5's TMAP sensor
Car: M550i
Default 12-03-2017, 09:24 PM
I installed a JB4 on my M550i yesterday and am very impressed so far. My car pulls much harder from 0 to 120mph and the throttle response has improved significantly. Terry has been great to work with and very responsive to my install questions. I've sent him several WOT logs for validation and all looks good so far. I put together a rough draft install guide for the M550i and passed it on to Terry to finalize and share. I'm very happy so far this tune and plan to dyno soon. I will post results when complete.
Default 12-04-2017, 10:16 AM
The faux-install guide looks great, thanks! I'll add a few tweaks and post it later this week.
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 12-05-2017, 10:10 AM
Sweet, nice to see the 5-series N63TU/2 work continuing.
Want to see how the JB4+BCM work on the new 550i.
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 12-13-2017, 12:21 PM
Anyone dyno'ed the M550 or Used the Dragy Performance Meter yet?
F90 M5 Comp - @BM3Tuning 100-200 5.29s / 60-130 6.1s | @HCP.US
F97 X3M Comp - Tuning Soon!
F80 ZCP DCT Tune Only | @BM3Tuning Stg1+ E85 60-130mph 6.7s
