Toome's Avatar
Toome Toome is offline
Car: 2012 BMW E92 335i M-Sport
Default 10-09-2017, 09:29 PM
Originally Posted by Steve @ BMS/Fuel-It!
Here is a link to the DB tuning thread.
http://www.n54tech.com/forums/showth...ghlight=tuning
Thank you. I will play around with that.
Just loaded up the Pump BEF tonight and went out and took a few logs. How do they look?
12 E92 335i 6AT - Alpine White M-Sports Package
Mods - | JB4 ISO | BMS Pump BEF | BMS Intake | VRSF Kittenless D0wnpipe | VRSF CP | VRSF 7 FMIC | Alpina Flash | Euro Headlight Switch | Avant Garde M359 | Michelin PSS
Toome's Avatar
Default 10-10-2017, 01:56 PM
Seems like there are massive timing corrections.
Default 10-10-2017, 08:11 PM
Make sure your traction control is off. Timing is low at tip in and improves. If TC is on, that may be why, otherwise it may be that map 2 is a bit aggressive. I'd do a log on map 1 and see if it improves.
Toome's Avatar
Default 10-10-2017, 10:14 PM
TC was off. Why is map 2 targeting 17.5 PSI? I thought it was only supposed to target 14 PSI. Does the BEF alter the JB4 map selection boost targets?
Toome's Avatar
Default 10-11-2017, 05:00 PM
Here is a log of map 1. Boost targets seem a bit more reasonable but WGDC is still pinned at 100 at the top RPM's. Is there any way to change the BEF boost targets to match JB4 only boost levels?
Default 10-11-2017, 06:52 PM
A BEF alters the boost targets.
Stock turbo maxes out at about 11psi up top.
Toome's Avatar
Default 10-11-2017, 08:37 PM
I see. What do you think is the best BEF for my application with a stock turbo?
Also is there anywhere where the boost target values are defined for each BEF?
Default 10-12-2017, 04:19 PM
I'd start with the pump flash running an E20 mix.
Toome's Avatar
Default 10-12-2017, 04:29 PM
E20 mix and map 1?
