(#451)
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 11-27-2016, 06:55 AM
Originally Posted by LeMansBeauty
Need some help here guys. I'm a newbie to this. Tried last night to flash the dme. Went to update zusb to flash the ppk. I'm mevd17, so I should be zusb # 8647156 to flash ppk. However I don't have that zusb number when I look for it in the list, all I have are 868xxxx. I can't put it in manually because I get error 704 I think it was. I have the newest spdaten file v60. So what am I missing?
8647156 was qualified for the US 135is (03/10-12/13.) 8684958 is a later revision which can be found in SP daten v60.0.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
LeMansBeauty LeMansBeauty is offline
Car: 2012 135i
Default 11-29-2016, 07:14 PM
Thank you!!! So out of curiousty.. would 8684956 be the eu revision then?
Car: 2009 BMW 335i
Default 11-29-2016, 08:34 PM
Yes.
kschafer2598 kschafer2598 is offline
Car: 2011 BMW 135i Vert
Default 12-27-2016, 07:36 PM
Hi All, new to BMWs and trying to get through using this software.
How do I tell what ECU type I have? From the chart on this topic I either have MEVD17 or MEVD126. Its for a 2011 135i.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 01-02-2017, 09:41 AM
2011 will def be MEVD17. Which also mean you can use a MHD stage 1 map for a low cost, with the ppk advantages but more power and user options.
Car: 2011 N55 135DCT
Default 01-02-2017, 09:47 AM
Def mevd 172 and 98g0b
Default 01-02-2017, 12:08 PM
Thanks! I haven't heard of the MHD tune yet, where can I find more information?
2011 135i Convertible
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 01-03-2017, 10:19 AM
[QUOTE=LeMansBeauty;509314]
https://play.google.com/store/apps/d...hd.flasher.n55
http://www.e90post.com/forums/showthread.php?t=1318714
Default 01-05-2017, 10:47 AM
[QUOTE=MHD;514923]Cool! Can you tell me if there is a way to do this without an android phone? I have a Nexus 5 and I don't think OTG works correctly on those devices.
KevinC39 KevinC39 is offline
Car: 335i 6MT RWD
Default 01-05-2017, 12:32 PM
No, you need an Android phone or tablet. People have done it with 40 dollar best buy tablets. Why wouldn't it work on a Nexus 5? Quick Google search of Nexus 5 OTG makes it seem like it would work. I did it with a Google Pixel without a problem.
Default 01-05-2017, 01:07 PM
I'll try it out on my device, but OTG support for the Nexus 5 appears mixed.
In any case like you said I can always get a different device.
Default 01-10-2017, 03:04 PM
Update: I was able to try it out, the OTG cable works fine. The app seems great, fantastic work guys.
Haven't purchased maps yet, but thinking about it.
Only issue is that the ECU connectivity seems spotty. One day, it worked fine and was able to read codes. Next day, I couldn't communicate at all. Waited a day, and it worked again. Seems temperamental, but I can probably blame the OBD cable for that.
fryj00's Avatar
fryj00 fryj00 is offline
Car: 2011 e92 n55 xDrive 6MT
Default 01-10-2017, 03:10 PM
FYI, my first OTG cable was ****. I had all manner of inconsistent behavior including connectivity problems. I'd look there before replacing the OBD cable.
2011 E92 N55 xDrive 6MT
Fiekie135i Fiekie135i is offline
Car: bmw 135i coupe n55
Default 01-16-2017, 05:36 AM
Has anyone flashed a model newer than 02/2012? I have a 05/2012 and have done as much research as i can, but I am told my car can't be flashed without an FSC code? please help
Default 02-02-2017, 05:17 AM
flashed ppk successfully, but wont accept it.. throwing error code 3671, can anyone assist with this?
Default 02-02-2017, 05:25 AM
I car was 03/2012 it cant be flashed. It was said many times.
Abdul Abdul is offline
Default 02-08-2017, 09:04 AM
Soo guys.. i need know your Help! How can i calculate the ZUSB Number which one i need for the flash??
8618483 is my "Teile-Nr" with 98G0B
i will flash 98d0b with the Kit !
Some helpful instructions ??
Genma Genma is offline
Default 02-12-2017, 05:33 PM
Is getting the latest sp-daten files required for the PPK flash?
2012 N55 135i
bradsm87 bradsm87 is offline
Car: E90 LCI 335i
Default 02-13-2017, 03:02 AM
If you want the latest PPK ROM for your specific car, absolutely. You can find the latest one using the kmm_ATSH file.
Default 02-13-2017, 05:26 AM
How can i update exactly what i want ?
Car: E90 LCI 335i
Default 02-13-2017, 04:01 PM
It's a tricky process and I'm a bit stuck for time at the moment but in summary, you need your production code (eg mine is PM76) plus your option codes (such as 205 - automatic transmission). Practice by searching for your current stock ZB number in the kmm_ATSH file and find thelist that applies to your exact car that contains your current ZB number. Next find that vehicle list but with "NPOW" option as well. The last ZB on that list should be the latest PPK for your car.
ovohugo ovohugo is offline
Car: 2012 135i
Default 03-02-2017, 09:45 PM
Anyone in socal that can do it for me?
Silto Silto is offline
Car: 135i e82 n55
Default 03-13-2017, 10:41 PM
Hey, my car is a 2010 built 135i from Germany.
I know, that the software have been updated by dealer.
It's E89-13-03-504 atm.
That means, that PPK isn't possible, right?
Thank you guys!
Cheers
Ichiban Ichiban is offline
Car: 135i DCT
Default 03-15-2017, 11:14 AM
Thank you guys!
Cheers
it's fine, you can still flash it.
pkpkpk2 pkpkpk2 is offline
Car: 335i e92
Default 04-24-2017, 07:37 PM
Can someone flash for me remotely? or point me the directions?
