(#351)
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 05-03-2016, 07:05 PM
Originally Posted by fordnox
i made it through my files...
N55 MT EU
refered to Matrix i Need Zusb:8639162
in Sp Daten 53 i found for the needed ZUSB
Prog Data Set:8618483A.0pa
Data Data Set:B8639163.0da
should be 8G0B
Yes, that's correct. ZB number 8639162 is program version 8G0B.
but how is it refered to my actual ZUSB?...in my case 8615750
Sorry, I'm not sure what you are trying to ask.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
fordnox fordnox is offline
Car: e92
Default 05-03-2016, 10:34 PM
Mhm! I want to flash this ppk flash to mine!
But i have already 8615750 (2013) on my dme!
Can i flash the 8639162?
F87 M2C
Car: 2009 BMW 335i
Default 05-03-2016, 11:22 PM
Yes, 8639162 is a newer ZB number than the one you have.
Car: e92
Default 05-03-2016, 11:53 PM
thank you alot....
i appreciate it...
another question...i think a few guys here want to Flash back to this ZUSB...
HOW can they do it?....am i right that with the files i mentioned in my previous posts allow an expert Flash, so the dme will accept the files?...- or is this downgrade Progress for every DME ZUSB which is on the car unique...?
for example...
35 MT EU want PPK.....
Needed is 8639162
they Flash these files
or am i completley wrong in my way to think:D
(sry for my bad "desctiption"....)
F87 M2C
Car: e92
Default 05-04-2016, 04:36 AM
I made it duration: 2min
Sound perfect!
Cant feel the power, but so ****ing nice sound
F87 M2C
Car: 2009 BMW 335i
Default 05-04-2016, 08:30 AM
thank you alot....
i appreciate it...
for example...
Needed is 8639162
They should inquire here:
http://www.n54tech.com/forums/showthread.php?t=39115
Sound perfect!
Glad it worked out for you.
keyap keyap is offline
Car: N55 135i
Default 05-06-2016, 11:25 AM
Sound perfect!
Glad you got it sorted
[B]
E90 335xi E90 335xi is offline
Car: 2011 BMW 335xi Sedan
Default 05-06-2016, 11:30 AM
How is the sound so different for you guys?
All I notice is a few extra burbles when the rpms go down, and that's only if the windows are open. With the windows up, it sounds the same - at least from inside the car.
2011 E90 335i xDrive 6MT
BMS JB4 ISO 5_9, FF wires, VRSF CP, GFB DV+
vespa's Avatar
vespa vespa is offline
Car: 2011 335i
Default 05-06-2016, 12:36 PM
The sound difference is quite noticeable if you park the car in a tunnel and have a friend kick the pedal like a spaz while you press your ear directly against the tailpipe.
Default 05-06-2016, 01:40 PM
LMFAO, ok thanks... people really should stop over-embellishing stuff on E90 Post.
The first time I found out about the golf-tee mod (can flap forced open), they made it seem like my car was gonna sound like a Ferrari.
Car: N55 135i
Default 05-06-2016, 01:45 PM
My car sounds like a Ferrari!
[B]
Default 05-09-2016, 07:35 AM
Anyone successfully flash an N55 xDrive E90?
My car was done with ZUSUB 8639128, completed successfully with no errors (took about 1hr), and now I have misfires under moderate/heavy loads even at low boost (under 10 psi) and regardless of what map JB4 is set to (even happens on maps 4 and 0).
It's a Canadian car and VIN was checked - it's the US model (as opposed to EU). So I'm pretty sure we flashed the right ZUSUB.
What could be the problem?
N55_SD N55_SD is offline
Car: 2011 135i
Default 05-17-2016, 01:28 PM
Was anyone able to screenshot or download the instructions prior to them disappearing?
I am guessing you use Winkfp, select ecu, update Zusb with provided number. Code the car, loads twice to 100%. Use NCS to send an empty text file saved as .man extension( havent got the understanding this part yet) to clear any errors.
US 2011 e82 6 MT
MEVD17
97V0B
Zusb 7629774
need to use zusb 8639164 ?
Any helpful links or really anything would be awesome, I ve read so much I am just trying to piece it all together. Not feeling confidant with my understanding right now.
Car: e92
Default 05-18-2016, 01:53 AM
look for alpina Flash diy....same procedure...
with NCS u must Flash a empty file to the named ecu...same as coding the frm. but the .man file must be emtpy...
F87 M2C
OneMoreAlex OneMoreAlex is offline
Car: 12' 335i xDrive
Default 05-23-2016, 08:21 PM
Wondering if anybody could help me...
I just successfully did the Alpina B3 Flash, now I'm trying to do the PPK flash but I can't find the right ZUSB...
My car is a 2012 N55 335i, according to INPA my DME shows 8639012 which I'm guessing is MEVD17. I'm using SP Daten v58.1. I couldn't find 8639128 which i know the numbers have changed, anybody find the new one yet?
Any advice I'd appreciate, Thanks!
Car: 2011 N55 135DCT
Default 05-24-2016, 09:31 AM
Hi you cant be v58. It would be sp daten v53. So youle need to make 100% shure.
Default 05-24-2016, 04:17 PM
100% sure it's v58.1 don't know where you got that information from?
Default 05-26-2016, 03:04 AM
Once you flash PPK do you have to set the JB4 to BEF-mode (option 4-2)? Or keep running it in normal mode (option 4-3)?
Assuming you don't have a BEF of course.
Thanks.
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 05-26-2016, 05:45 AM
I would keep running in normal mode. 4 - 2 is for high load BEFs. I wouldn't consider PPK high load.
Here's a very good explanation of what this setting actually does... http://www.n54tech.com/forums/showpo...8&postcount=18
Default 05-26-2016, 08:37 AM
Default 05-30-2016, 08:10 AM
For continuity... the misfire problem was resolved by replacing my 1-year old spark plugs.
EB89 EB89 is offline
Car: N55 335i 2011 e92
Default 06-21-2016, 11:05 PM
Ive been reading through this thread and im a little unsure.
I have a 2011 N55 335i DCT
I had the PPK flashed onto my car recently, massive increase in pops and gurgles.
I had been running the JB4 ISO 5.10 and have just removed it.
Can someone tell me, what are the flashing options with a COBB AP V3 that will not remove the pops and gurgles from the PPK flash I already have?
Can I run the OTS COBB Flashes? or the BMS BEF? Or nothing
Cheers
sd306 sd306 is offline
Car: 2011 e92 N55 335i Coupe M-Sport
Default 06-29-2016, 08:56 AM
Originally Posted by Hailpersia
Flashing part is easy to understand, but can someone clarify the "send an empty .man to 62bmo" please, in detail. Does that mean load 62bmo in ncsexpert and literally code a empty .man to it? thanks
Yes code an empty .man to it. I was so confused by this as I had never coded. If you dont know what this means check this guide out and you will understand: http://codinge90.com/ncs-expert-basic-understanding/
jonbloom jonbloom is offline
Car: BMW 135i DCT
Default 07-02-2016, 11:28 AM
Hi all,
I've got a 2012 135i with the DCT. I attempted to flash the PPK, but something went wrong and the car threw codes for essentially every model. I've reverted back. Can someone help me with some remote work?
jsanchez335 jsanchez335 is offline
Car: 2007 BMW 335i, E90
Default 07-13-2016, 11:11 AM
Has anybody ever did a PPK flash on a 135i with a ROM of 9EIOB? Or has anybody ever heard of that Rom? Last 7 VIN VM13239
