Car: 2011 N55 135DCT
Default 2011n55 135 dct roled back from 98g1b to 98g0b. - 05-02-2016, 07:56 AM
Hi just to let you all know it can be done. My friend and i managed to do it successfully. And cobb got loaded. Using Winkfp
Newguy123's Avatar
Car: 12' 135i
Default 05-02-2016, 08:51 AM
interested in this for sure as my dealer flashed the dme at my last visit without me knowing to 98g1b.
18 Glacier white RS3
#PURETURBOS
#FUELIT
Default 98g0b - 05-02-2016, 08:59 AM
What is ure ecu hardware number and Software zusub current. Can u give me that info.
Also what is ure ecu family
fordnox fordnox is offline
Car: e92
Default 05-02-2016, 09:21 AM
so there is hope for pp Flash too if dealer updated the car?
F87 M2C
Default 98g0b - 05-02-2016, 09:40 AM
Yes there is
Newguy123's Avatar
Car: 12' 135i
Default 05-02-2016, 09:54 AM
ECU MEVD172
i dont have the current SW ZUSUB.
#PURETURBOS
#FUELIT
keyap keyap is offline
Car: N55 135i
Default 05-02-2016, 10:03 AM
@ JacquestN55 - great work. You're going to be in demand now
JB4 | BMS OCC | N20 TMap | Fuel-It! PI | AIC6 PI Controller | Fuel-It! Fuel Lines | Fuel-It! Stage 2 LPFP | Continental In-line E Sensor | ER Charge Pipe | Pure Stage 2 Turbo | Pure High Flow Inlet | GFB DV+ | Richter C'less D/Pipe | Berk Race Full Exhaust | MFactory Pro Helical LSD (75% Bias Ratio) | eDiff Disabled Via Coding | MFactory Solid Diff Bushes | Diff Lockdown Bracket | Custom 98G0B BEF | NGK 5992s (0.020")
Newguy123's Avatar
Car: 12' 135i
Default 05-02-2016, 10:05 AM
Yes there is
are you in the US?
#PURETURBOS
#FUELIT
Default 98g0b - 05-02-2016, 10:17 AM
No im from South Africa.
Default 05-02-2016, 10:21 AM
I can flash it back. As long as you have the sp daten file on your laptop and can connect to the car. I am from South Africa.
808AWD325xi's Avatar
808AWD325xi 808AWD325xi is offline
Ballin' out of control.
Car: 2009 BMW 335i
Default 05-02-2016, 01:01 PM
Glad it worked out for you.
Alpina B3 Flash/BMS OCC/ER CP/ETS 5/HKS BOV/M3 Control Arms/OFT
kingjulian kingjulian is offline
Car: 2010 135i DCT Lemans Blue / Lemon
Default 08-22-2016, 06:05 AM
Was just thinking about how to do this, is it just a matter of selecting the correct zsub number from the .HIS file then working back through older datens finding the 'pre-dated' zsub?
Or is that an oversimplified view?
2010 135i DCT (Le-Mans Blue/Lemon)
2003 E46 M3 SMG (Estoril Blue/Black)
2003 E46 330d Saloon (Silver Grey/Grey)
Default 08-22-2016, 06:09 AM
No its not so easy. The ecu hardware number has changed. So you will need to change back to the correct hardware number and then also the zusub
katsooba's Avatar
katsooba katsooba is offline
Car: 135i N55 DCT
Default 09-26-2016, 06:58 AM
hi
i currently have on my laptop spdaten 54 55 and 57
what zusb should i flash to have a good supported rom on my 2010 135i n55 dct EU?
135i N55 / KW V3 / CP-E charge pipe / CP-E 5" ** / CP-E 7" FMIC / JB4 S2 / MHD / K&N inbox / Custom made 3.25" catback / Tons of other mods
