(#26)
morkusyambo morkusyambo is offline
Car: 328i
Default 04-01-2015, 04:37 AM
Originally Posted by RobX3
I've never heard of TMC. I assumed brand x was one of the many others stateside here. Since we are on the subject, Is what they are claiming for OBD flashing legit? This is the first I have seen any company or individual claim they have one for sale to an end user. Terry?
Registered Users
Default 04-03-2015, 10:49 PM
Terry a question I have is, are these Dyno ran at the stock level of the bms stage1 without increasing it to more psi ? I was told somewhere that BMS Stage1 comes at 3.5 psi where afe scorcher comes at 4.5 if im not mistaken.
PumpGas is on 91 or 93 octane?
For those wondering about the EWG vs. pneumatic here is an old Stage1 test done some time ago on a 100% stock EWG 328i. We'll test "BRAND X" on the same car down the road as well. And expect similar results.
Default 04-04-2015, 09:23 AM
The default on the new Stage1 is 4.0psi. And it can be adjusted using a BMS DATA cable to as high as 6.5psi if you want. The pump gas was 4.0 and race gas 6.0 in the runs above, IIRC.
Registered Users
Default 04-04-2015, 08:28 PM
Are there any MPG improvement on BMS Stage1 ?
I've heard my friend that had JB4 saw some improvement while driving in the highway decently.
I am tempted to try it but not enough funds and the current tune has been good since before Winter.
Default 04-04-2015, 08:36 PM
No none of the N20 tunes can provide any MPG improvement. Not your current tune, not the Stage1, and not even the JB4. Certainly not the Stage1 tunes.
Car: 328i
Default 04-06-2015, 09:08 AM
Is the stage 1 boost for the S55 adjustable up to 6psi as well? If so, what octane would you recommend running at 5 or 6 psi? I have access to standard 93 octane with @ 10% ethanol.
Default 04-06-2015, 09:20 AM
For the S55 you'll need a full JB4 to run higher power levels than Stage1 offers.
Registered Users
Default 05-06-2015, 07:38 PM
Shop was under construction nd moving so they finally got to us the Corrected: STD and Smoothing 5 graphs
Default 05-17-2015, 08:53 PM
Just get a BMS DATA cable and datalog it on map 0 (stock) and map 1 (tuned) and we can do a basic evaluation based on that.
Default 05-17-2015, 09:06 PM
Stage1 is not upgradable to a JB4, cable is on our website, and there is a 3rd party apple interface that is compatible.
Default 05-17-2015, 09:41 PM
It's in the N54 section under 3rd party interfaces.
BIGBOYQ's Avatar
BIGBOYQ BIGBOYQ is offline
Default 07-03-2015, 07:37 AM
I am supprised - on the graphs - as My Z4 N20 seems to produce more power and its not using race gas?
using the same logs I also got these results as well.
I have included weight of car, full 3/4 tank of fuel and myself
Enclosed is the logs files
Registered Users
Default 07-03-2015, 04:14 PM
What is Virtual Dyno?
Maybe could be also your car weighs less? better tires? etc
BIGBOYQ's Avatar
Default 07-06-2015, 02:38 AM
What is Virtual Dyno?: Software that I export the logs from the JB4 to to create an Virtual Dyno Grapth.
Maybe could be also your car weighs less? better tires? etc- you input weigh specific for the car and also size of tyers
This is why I have posted the log files, for an expert opionion
Registered Users
Default 07-14-2015, 08:00 AM
thank you
Registered Users
Default 07-14-2015, 08:49 AM
@Terry , is it true the JB4 now does not need to tap into wiring ? (New Version)
Also, how much RaceGas was in the tank at the time of the Dyno?
I have a friend with a BMS Stage1 who is going to let me borrow and i want to Dyno & test my 1/4 with it. Since I already did with my RaceChip but isn't 6+ psi on a stock car too much for SoCal temps?
Registered Users
Default 11-07-2015, 05:14 PM
@Terry
Anymore testing with the N20/N26?
Have you seen any improvement of ********* on the N20? or disadvantage?
fast4d fast4d is offline
Default 03-07-2017, 02:14 PM
Can I use stage one (4psi) on N20 using 91 octane gas?
Default 03-07-2017, 06:08 PM
Yes
