tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 08-04-2015, 01:12 PM
Originally Posted by Steve @ BMS/Fuel-It!
I checked the E90 and the tips did not come off easily. I'll have to investigate more tomorrow to see if they can be "persuaded" and if so, how difficult it is.
Let me know if you figure out a way to get the E90 tips off... without a torch...
Ando @ BMS's Avatar
BMS Customer Service
Car: bmw 335i
Default 08-05-2015, 11:26 AM
What an awesome product! I hope it would fit the M4!!
Default 08-05-2015, 05:16 PM
Originally Posted by Jera Jakerz
I suspect then there is a warranty? Like if in a year I notice methanol damage I can replace them?
They are exhaust tips so we expect them to get beat up. Not much of a warranty offered unless something is an obvious manufacturing defect.
endless_435's Avatar
endless_435 endless_435 is offline
Car: 435xi
Default 08-14-2015, 09:14 AM
Got mine just the other day, tried installing these badboys but they dont seem to fit the MPE....
The inside clamps are made to secure to a smaller diameter pipe than what came with my MPE as you can see in the pics.
Looks like im hooped, and they are so nice
Mike_L's Avatar
Mike_L Mike_L is online now
Anti-Social
Car: 2017 X3 xDrive35i
Default 08-18-2015, 08:00 PM
****! Those would have been perfect on my car. Can't use them now though since my ***** are cut.
Mike Levy
2021 M550i - On hold due to lack of allocation
2017 X3 xDrive35i
2018 Equinox LT 2.0T
durty sexn55 durty sexn55 is offline
Car: n55
Default 08-22-2015, 08:35 AM
I like it
2011 E82,n55 ,6mt
Stage 3+ Clutch and alumni fly wheel
Vrsf down pipe
Vrsf charge pipe
Vrsf fmic "5 inch
Jb4 , fuel flex wire and Bluetooth connection
New water pump and thermostat
Bms air intake
Meth kit cm10 60/40
E85 50/50
Stage 2 fuel pump
Pure stage 2
Ecs Lightweight Front and rear Brake Rotors brake pads
New o2 sensor
New transmission oil MTL red line
Motor oil MoTul 8100
Roundrockcrawler's Avatar
Roundrockcrawler Roundrockcrawler is offline
Car: 2011 BMW 335i
Default 09-29-2015, 08:25 AM
I'm for a set of tips for my E90 if they are produced
(ADMIN UPDATE) E9x 335 Tips located here: http://www.burgertuning.com/exhaust_...1_E92_E93.html
2011 335i /S
BMS N55 intake
BMS JB4
Cobb Charge Pipe
Ceramic Tint
54Tuning 3.5 ********* DP
ETS INTERCOOLER
Mike_L's Avatar
Anti-Social
Default 10-06-2015, 01:38 PM
Is that a Golf with a BMW badge?
EDIT: Oops, never mind. Just noticed you said it was an F20 135. We don't get those in the US. Only hatchbacks we get are the F34 and F36.
Mike Levy
2017 X3 xDrive35i
Peter @ Pure's Avatar
Car: F20 M135i
Default 10-06-2015, 02:28 PM
Yes its a real bmw. Faster than stock M3/4/5/6 too those tips add zillion whp
peter@pureturbos.eu
peter@pureturbos.com
peter@protuningfreaks.com
pureturbos.eu
copperman05 copperman05 is offline
Car: BMW M135i
Default 10-06-2015, 03:22 PM
Looking good Peter.
M235i 8AT JB4, EWG, BCS DP, BCS powervalve catback, Wagner FMIC.
alexc93 alexc93 is offline
Car: 6mt N55 135i
Default 11-09-2015, 09:14 AM
Received my set of black tips this weekend. Really nice quality product, fitment was perfect.
I will say, removing the oem tips was harder than i expected but they just need a few really solid hits to get them off. Thanks BMS.
2014 M235i Black Sapphire Metallic / Black Dakota Leather
|| 30% Llumar CTX || IND Painted Front Reflectors || BMW Performance Grilles || Lightweight Front Lip || BMS Exhaust Tips || JB4 || ER Charge Pipe || MPI DP ||
spikiii's Avatar
spikiii spikiii is offline
JB4 addict
Car: powered by JB4
Default 11-09-2015, 06:59 PM
Guys, If i'm planning to put these on the LCI F30 - 340i .. they'll fit right?
the burnt chrome tips look awesome
Default 11-09-2015, 07:37 PM
Our 340 isn't in yet but we expect it this week. And will let you know!
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 11-09-2015, 10:31 PM
Awesome! really want to order them as soon as you find out
spikiii's Avatar
JB4 addict
Car: powered by JB4
Default 11-12-2015, 01:04 PM
So I picked up the 340i yesterday.. very happy. Took it home, black grills in... then went to take a look at the tips.
i'm going to ask a stoopid question... how do i get the factory tips off?
vhawk vhawk is offline
Car: 2016 M235i
Default 11-13-2015, 04:19 PM
Another question:
Does the top of the angle cut exhaust tip stick out further from the diffuser than the straight cut?
Car: F20 M135i
Default 11-14-2015, 12:58 PM
Originally Posted by Element
Are you aware of any way to adjust the exhaust height on these cars? It was a simple task on my old E82, but I can't seem to see a way to do so with the F21.
I've got a 3D Design diffuser and I need to pull the new tips up a bit to make it look better:
Well I guess the problem is the diffuser you have. I guess it looks even worse with the smaller stock tips?
Anyways you CAN fix that. You need to shorten the 2 brackets where it exhaust is hooked up to the underside of the car. Take exhaust off, cut off 1cm (or how much higher you want it to be) and weld back together.
peter@pureturbos.eu
pureturbos.eu
Jason @ BMS's Avatar
Jason @ BMS Jason @ BMS is offline
Administrator
Car: M340i,X5,Raptor,C7 ZR1
Default 12-10-2015, 08:34 PM
Confirmed! Angle cut fit the 2016+ B58 (F30) 140i 240i/iX 340i/ix 440i/ix.
http://www.burgertuning.com/exhaust_tips_for_BMW.html
Default 12-10-2015, 08:48 PM
keyap keyap is offline
Car: N55 135i
Default 01-23-2016, 06:21 AM
Any way to get a set of these for a 2011 E82 135i? Am happy to mod if needed.
[SIZE="2"]UK 2011 - E82- 135i - N55 - DCT
[B]
sc67065's Avatar
sc67065 sc67065 is offline
Car: n55
Default 03-01-2016, 12:44 PM
I've personally fitted a set of the BMS tips to an MPE. A screwdriver used to pre-compress one of the spring clamps enables you to push the tip over the larger diameter pipe.
Unless there is some variation in MPE outlet sizes I don't see an issue.
Is your MPE pipe diameter also 2.5in (63mm)?
Car: 435xi
Default 03-03-2016, 10:14 AM
I thought the same, and I did try to compress the clamps to allow it to slip on more easily but it dint seem to work.
I dont own the car anymore and sold the tips but they would have looked awesome if I could've fit them that's for sure.
NICKTENN's Avatar
NICKTENN NICKTENN is offline
Car: F30 335i Sportline on order
Default 03-03-2016, 12:49 PM
When will the black chrome angle tips be back in stock?
2016 F30 340i M Sport Alpine White, JB4
RIP 2012 F30 335i Sport Line Mineral Gray, JB3/Stage 1
Stock 335i 1/4 mile time
Administrator
Default 03-03-2016, 12:53 PM
Originally Posted by NICKTENN
When will the black chrome angle tips be back in stock? Can they be supplied without the logo?
The BMS black chrome angle cut tips with logo will be in stock in about a month.
lilg1993 lilg1993 is offline
Car: 2007 E93 335i
Default 05-23-2016, 02:51 PM
Anything further about tips that fit on an E9x? or on how difficult it is to get the OEM tips off an E92/E93 (if its even possible at all without completely cutting them)?
