(#701)
gsr1416 gsr1416 is offline
Car: 2008 bmw 335i e93
Default 05-30-2015, 08:59 PM
Martial has a BETA version of the ina0s working for 335is models. And I've got 335is JB4 back end maps to test. So you 335is guys out there in the wings drop me a note.
Hi Terry interested in trying backend flash for 335is. ?
Default 05-30-2015, 09:04 PM
Fyi just received d can cable off Amazon and it works perfect! The name of cable is" kcrius d can " it's $25.99.
darkrom darkrom is offline
Car: 135i N54
Default 05-31-2015, 06:46 AM
Which map would be appropriate on a 135i with DCI, midpipes and otherwise stock exhaust, but also running method? Stock primary kitten still there on stock DP. secondary kittens removed with the midpipes. Stock axle back. 7" intercooler.
I'm trying to figure out which map would be good without the dp but still using meth. Haven't ordered my meth kit yet. Need to figure out which map is good. Right now I'm running the pump back end on map 5 with good success.
Shafer Shafer is offline
Car: 2008 e90 335i 6MT
Default 05-31-2015, 12:43 PM
So, JB4 set to Map 0 to disable, and allow OBD comm. But MHD shows Error 6-no cable.
Ignition ON Engine OFF
Cable is the one from eBay Wedge posted awhile back, and others recommended.
OTG cable being used for Nexus phone has been used plenty of times with JB4 Mobile app.
Any ideas?
Stucks Stucks is offline
Default 05-31-2015, 01:31 PM
Any ideas?
is it the green cable or white cable? there have been a lot of people posting about the recent green cables from ebay not working. i ordered both and the white cable from amazon worked, but only after we tried the green cable from ebay and found that it DID NOT work.
Current: 2008 e92 335i coupe.
Default 05-31-2015, 02:16 PM
This one: http://www.ebay.com/itm/K-D-CAN-DCAN...efaultDomain_0
It has a green circuit board, Sticker says MPPS V13.02 on it.
Got a link to the Amazon one?
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-02-2015, 04:01 AM
MHD maps dynos will be performed later but for now, here is a German customers dyno running the Stage 2 93 map, 395whp pump gas only.
Default 06-02-2015, 05:12 AM
yup, thats the "green" one that didnt work!
Heres the one that did work:
http://www.amazon.com/INPA-DCAN-Diag...56+E87+E93+E70
daskoff daskoff is offline
Car: BMW 335i
Default 06-02-2015, 06:44 AM
I bought the same cable referenced here and it didn't work for me on an '08 e90 6MT with a Nexus 7. Still looking for a cable.
Rushan's Avatar
Rushan Rushan is offline
Car: 335i E92 2009
Default 06-02-2015, 06:58 AM
I have mine from Amazon, green board with shielded silver cable and worked perfectly on MHD and on NCS expert to code my digital speed and INPA to read KOMBI
KCRIUS(TM) K+D CAN USB Interface OBD2 Cable Diagnostic Scanner for BMW only https://www.amazon.com/dp/B008KZDDGA..._CwBBvb1CV5BMX
jyamona jyamona is offline
Car: 2010 135i 6MT
Default 06-02-2015, 07:00 AM
Same one I have, works great
bnd's Avatar
bnd bnd is offline
Car: 2008 N54 E92 335xi
Default 06-02-2015, 07:17 AM
+1
I'm trying the amazon KCRIUS cable previously mentioned. It comes from China & has expensive expedited shipping... we'll see.
2008 335xi N54 E92
MHD WedgeBQ
BMS JB4 G5 ISO
BMS Dual Cone
BMS OCC
VRSF 3" DP
VRSF 7" IC
VRSF CP
Tial Q BOV
Fuel-It Stage 2 LPFP
Alpina B3
NGK 5992
DV135i's Avatar
DV135i DV135i is offline
Default 06-02-2015, 08:08 AM
Bought mine from here and it works perfect! http://www.ebay.com/itm/251791648964...%3AMEBIDX%3AIT
swat's Avatar
swat swat is offline
Car: 07 335i
Default 06-02-2015, 08:26 AM
Here:
http://www.one-stop-electronics.com/...&product_id=16
It'll work guaranteed.
Stacked BMS Flash & JB4, Dinan CAI, ER Chargepipe, 7" VRSF Intercooler, VRSF DP's, ER Sport Oil Cooler w/Steel lines, Gunmetal 19" VMR V710's, 335is clutch, Wavetrac LSD, M3 FSB, M3 Front & Rear Control arms, M3 RSB, M3 rear subframe bushings, M3 guide rods
Car: BMW 335i
Default 06-02-2015, 08:54 AM
Originally Posted by swat
I looked at this but am a little gun shy after trying three cables and this is a $100 cable. I emailed them about their return policy and no response (been a day so far) so a little leery of pulling the trigger.
jordan313 jordan313 is offline
Default 06-02-2015, 09:01 AM
That cable works...used it many times to code, do alpina flash, and now mhd flash. Just fork over $100 and get a working cable or gamble with those other cheap cables and waste time.
zero2sixtyZ zero2sixtyZ is offline
Default 06-02-2015, 09:04 AM
Solid numbers. What kind of boost is the stage 2 map expected to hit?
Car: vw passat
Default 06-02-2015, 07:14 PM
when are the new ijeos maps coming out?
csu87 csu87 is offline
Car: 09 335xi
Default 06-02-2015, 07:49 PM
What else is done to the car? FBO?
swat's Avatar
Car: 07 335i
Default 06-03-2015, 06:40 AM
It works. Period. You can fork over the $100 and get a known working cable or you can keep wasting money getting cables that MAY or may not work. You drive a $50,000 vehicle. Do you want to risk getting a cable that may crap out half way through writing to your ECU and brick it? Or do you want a reliable cable that will get the job done?
Default 06-03-2015, 06:55 AM
Correction drive a car that used to cost 50g,now it's 15
Car: 09 335xi
Default 06-03-2015, 07:03 AM
how much have you wasted on the wrong cable? The one from one-stop electronics works. Listen to us.
or you can go here. http://www.cable-shack.co.uk/products.php I got one from them and it works as well
Default 06-03-2015, 07:21 AM
24 bucks and works for me. I originally bought it for inpa but tried for mhd and works
Car: 09 E92 335i
Default 06-03-2015, 12:42 PM
@MHD, got a few questions
- for those of us that have already purchase the $79 license for jb4 backendflash, can we convert it to a full license for flashing the OTS and custom map as well?
- Is it possible that we can pull the OTS files from MHD and make a few adjustment on our own. I personally prefer the linear throttle load request map from BMS, but I am not sure if the MHD OTS maps are linear as well.
MHD's Avatar
MHD MHD is offline
Car: 07 335i AT
Default 06-03-2015, 01:01 PM
18-19 PSI.
The v4 maps came out last Friday.
FBO yes.
