(#1476)
Default 05-18-2015, 08:29 PM
They are ignored. I'd set all to 0 to avoid confusion in the future.
1forI 1forI is offline
Car: 135i N55
Default 05-18-2015, 08:43 PM
Ah. I learn something new every day. Thanks!
Let us know when you figure out another trick for us non-bef guys : )
tboudre's Avatar
tboudre tboudre is offline
Car: 2011 BMW 335xi E90 N55
Default 05-19-2015, 11:17 AM
I just loaded 5.8 @ Lunch, can't wait to try it out to see my fuel trims!
The N54 ISO has a Notes.txt file that lists FUD, FUA parameters. Is ours the same, or will we get a Notes.txt file?
Default 05-20-2015, 09:44 AM
Nothing published for the N55.
Weehe Weehe is offline
Wanted to note also. I think my flashers are going off well before the oil temp is reached. Was watching the gauge and it didn't move till 3-4minutes of driving after the flashers went. Il need to get the digital reading next time.
chrisgarcia8000 chrisgarcia8000 is offline
Car: 335
Default 05-24-2015, 12:06 AM
My car got a check engine light crusing on the interstate running the Cobb flash with jb4 in 4/2 mode with the 5.8hex loaded. Fuel is e50
diesel3443's Avatar
diesel3443 diesel3443 is offline
Default 05-24-2015, 06:35 AM
FYI, my boost limiter for 3rd gear was set to 1 after the upload of 5_8, was wondering why 3rd gear logs felt slow lol.
2011 E90 335i 388 whp/475wtq on E50
E90 335xi E90 335xi is offline
Car: 2011 BMW 335xi Sedan
Default 05-26-2015, 11:30 AM
Seems like 5_8 is a bit buggy compared to 5_7... maybe it's best to stick to 5_7 for now unless you absolutely need fuel trims for logging?
2011 E90 335i xDrive 6MT
BMS JB4 ISO 5_9, FF wires, VRSF CP, GFB DV+
AGO 530's Avatar
AGO 530 AGO 530 is offline
Car: 11' N55 E90
Default 05-26-2015, 11:37 AM
Are you running the 5_8?
'11 E90 MSport / BMS : JB4 - Stage 2 ISO, ********, Intake, OCC, Low Temperature Thermostat / ETS 5" FMIC / Evolution Racewerks CP / Swift R-Spec Springs on Koni Yellow's.
Default 05-26-2015, 11:50 AM
No I've stuck to my 5_7 after reading the last couple pages here.
diesel3443's Avatar
Default 05-26-2015, 12:06 PM
Being able to see fuel trims is worth it to upgrade it. I have been running 5_8 and the car feels amazing once I took off the boost limiter in 3rd gear
AGO 530's Avatar
Car: 11' N55 E90
Default 05-26-2015, 12:24 PM
Thanks for the update; headed to the parking lot, laptop in hand!
Default 05-27-2015, 06:51 PM
So I'v noticed that my timing, no matter the RPM or boost, is a flat 6* now. Did something change in the new firmware? I recently was running 100% E85, but switching back to E60 and showed no difference in timing. Previously on E40-E60 my timing would increase as rpm increased and boost decreased to 11+*. This no longer happens in map 5 or 6.
Default 05-27-2015, 07:22 PM
Sounds normal if using a back end flash. If not may just be octane or intake temp related.
Default 05-27-2015, 07:25 PM
I am not running a BEF, i know the large turbo BEF targets a flat 6*. I also am not octane limited as I was running straight E85 and decresed it to E60 incase it was lack of fuel related. Also, im running a 7" IC and temps are right at 100 for short pulls.
Could it have something to do with the new All AFR and Duty Bias adustable values?
Default 05-27-2015, 09:13 PM
No the DME sets the base timing curve. So if its set lower then boost is higher, octane is lower, or some other factory is causing it to do so. I wouldn't worry much about it. The N55 makes maximum power around 5-6 degrees anyway.
///N55Power's Avatar
///N55Power ///N55Power is offline
Car: 2012 BMW 135i
Default Terry please check my Log - 05-28-2015, 10:14 AM
Here is a Map2 log i did today. First one too. Just looking to make sure I did it right. Anyone able to take a look and give me some feedback?
carguy138 carguy138 is offline
Car: 2011 e90 335xi 6mt
Default 05-28-2015, 08:06 PM
Couple questions. The settings you say to run on the first page, is this with or without flex fuel wires?
Also the instructions state to change the default waste gate position to 80 but its 60 on the screen shot. Lastly on the flex fuel wire install it states to set fuel open loop to 50 but the screenshot says 70.
Long story short i have iso 5.8 with flex fuel wires installed and looking for confirmation of the correct settings to start with.
Default 05-28-2015, 08:39 PM
You'd need to post your log to the support forum for review.
Default 05-28-2015, 08:40 PM
Doesn't really matter much either way on those two settings. Open loop 70, DWP 60, are the current defaults.
BostonShant's Avatar
BostonShant BostonShant is offline
Default 05-29-2015, 06:34 AM
I'm pretty sure I know the answer to this but just to play it safe. We still don't have individual timing on each cylinder for the n55 do we?
2011 135i - N55 - JB4 ISO - FBO + Meth + Corn
VTT JB Stage 2 with VTT Forge DV and VTT N55 Waste Gate Upgrade
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
diesel3443's Avatar
Default 05-29-2015, 06:51 AM
^^^not yet. Still crossing my fingers. With as much attention that the n55 is now getting I am hoping it wont be too long
Default 05-29-2015, 06:53 AM
That would be sick. I don't want to get ahead of myself but I could really use 6 cylinder timing, NLS, ** fix and top speed delimiter lol. I feel so greedy typing all that.
Pump Gas
60' ... 1.850
1/8 MPH ... 98.06
1/4 ... 11.735
Trap ... 122.71
diesel3443's Avatar
Default 05-29-2015, 08:25 AM
Don't feel greedy, I want it too! And I am sure we aren't the only 2 haha
Newguy123's Avatar
Car: 12' 135i
Default 05-29-2015, 09:47 AM
well S55 just got 6 cyl logging so hopefully that trickles down to N55
18 Glacier white RS3
#PURETURBOS
#FUELIT
