Default 10-22-2013, 05:04 PM
Decided to jump on the dyno today just to see where it stands on pump gas and get my feet wet with it. For those that may have missed it we're using a FFTEC 6466 kit.
I ran it at ~19.5psi with a pump gas flash I've been street tuning and it did pretty well. The car has 3.46 gears so these runs were done in 5th gear as 4th was just too short of a pull to see what was going on with the tuning. The car has midcats in place currently.
Overall, not a bad starting point. Next up we'll be reworking the exhaust a bit and raising the boost/advance for some E85 tuning.
Trickcruiser's Avatar
Default 10-22-2013, 07:19 PM
THIS IS GOING TO BE EPIC!!!
How does the trans seem to be handling this power right now?
infliktyd135i's Avatar
infliktyd135i infliktyd135i is offline
Car: 09 135i
Default 10-22-2013, 07:38 PM
Our 135i was dropped off at FFTEC this morning for top mount treatment.
its already all over social medias
Default 10-22-2013, 08:17 PM
LostMarine's Avatar
LostMarine LostMarine is offline
Car: E92 DCT ///M
Default 10-23-2013, 09:59 AM
just when i was starting to get a little coky you have to pull this out..
sranch335i sranch335i is offline
Car: 2008 335I
Default 10-23-2013, 10:13 AM
:c lap::cla p:
IM IN!!!
Default 10-23-2013, 11:36 AM
Originally Posted by sranch335i
:c lap::cla p:
IM IN!!!
I think the top mount twin scroll using the same turbo is going to be the ideal choice for your car.
335si's Avatar
335si 335si is offline
Default 10-23-2013, 12:44 PM
Now that you are tuning a ST I might have to jump on the wagon...
-2007 335i - All stock
12.3@118+mph
-2007 Suzuki SV650 - Evotech FE, M4 Carbon Slip-on, Solo Seat
Car: 2008 335I
Default 10-23-2013, 01:50 PM
sure!!!! whatever!!!! im in!!!!!
VegasJD's Avatar
VegasJD VegasJD is offline
Car: 2012 bmw 135i
Default 10-23-2013, 04:59 PM
cant wait to see the results
2018 Individual Tanzanite Blue Competition M4
Mactango's Avatar
Mactango Mactango is offline
Default 10-23-2013, 08:06 PM
Subscribed!
'09 135i AT | JB4 G5 | Wedge E85 Flash | Alpina Flash | RB Turbos | Walbro 255 | Evolution Racewerks CP | Forge DV's | ER FMIC | aFe DCI | Macht Schnell DP | Borla Dual Race Exhaust | NGK 5992 | BMS Oil T-Stat Bypass | BMS OCC | BMS Cowl Filter Covers
Default 10-23-2013, 08:10 PM
What's the AR on the exhaust turbine on the 6466. Maybe a little boost ramp would make it easier to handle when boost comes in. If you look when it's about to hit full boost, 4.2k rpm-4.5krpm it shoots over 100whp. In just 300rpm LOL. I can only imagine what a handful it is.
Oilphase Oilphase is offline
Car: 335i sedan
Default 10-23-2013, 11:54 PM
congarts Terry amazing numbers !! btw could you give us cost estimate for top mounted ST setup include all hardware turbo, WG.. etc ?
Default 10-24-2013, 08:08 AM
Including labor, fluids, tax, etc, around $10k installed and out the door.
psmitty95's Avatar
psmitty95 psmitty95 is offline
Car: 09 335i xDrive 6spd
Default 10-24-2013, 01:03 PM
Let's see some vids!!
< Click picture for photoshoot
E90 335i xDrive 6spd, Nav, Prem, Cold Weather, & Sports package - Msport Conversion
Mods: JB4 + MHD, Doc Race ST, Pure 6266, AD-Eng PI/Mounts, Fuel-It st. 3, Custom Exhaust, Tuned by TwistedTuning
More Pictures: Build Thread /// Dyno Soon to Come
2Times's Avatar
2Times 2Times is offline
Car: 08 E92 335xi
Default 10-24-2013, 01:31 PM
Any thoughts of opening a shop in Mass? I'd be in.
Default 10-24-2013, 01:34 PM
We don't do labor so I just shipped our car over to FFTEC.
Default 10-24-2013, 06:51 PM
I wish you did labor... I only trust you LOL
bmw0bsession's Avatar
bmw0bsession bmw0bsession is offline
Car: 2011 135i N55
Default 10-25-2013, 08:50 AM
Anyone want to buy a N55 135i? I need an N54!!
BMW Performance Kidney Grille, CF Lip Spoiler, CF Diffusser, Blackline LCI Tailights, Magnaflow Full Exhaust, BMS Intake, Jb4 w/ E85, Meth Injection, BMS DP, VRSF 5" Intercooler, CP-E Charge Pipe, KW CS Coilover, M3 Subframe Bushings, VMR VB3 Wheels, Stage 2 Fuel Pump, M3 Control Arms, Dinan Camber Plates, Pure Stage 2.
Default 10-25-2013, 02:38 PM
For those interested in the boost solenoid testing we're doing. MAC @ 20hz, 25-70% duty cycle (e.g. its usable range), OEM at 2.4khz, 0-100% duty cycle.
Car: 335i sedan
Default 10-27-2013, 04:09 AM
just to clarify, both of the ST setup are on 135 ? any plans for 335 ?
Default 10-27-2013, 08:27 AM
One on our 135 and the other on our 335.
seroga1986's Avatar
Default 10-29-2013, 09:08 PM
Any progress on this? 600whp yet?
2008 135i Sport 6at
2013 X3 xDrive28i M-package
Montréalman Montréalman is offline
Default 10-30-2013, 08:43 AM
Are there any performance advantages with a top mount turbo ? What are the differences between the two setup ?
Default 10-30-2013, 09:10 AM
The car is up at FFTEC getting a custom exhaust made right now and an install error corrected on the drain line. Hope to get back to work on it in a week or two.
