CastleBravo's Avatar
CastleBravo CastleBravo is offline
Car: M135i
Default BMS DCI w/Cowl 135i - 03-12-2021, 03:48 AM
Is it possible to run the BMS DCI WITh the Cowl on the 135i?
Trying to get one fitted in the last few days and it does appear there is enough length on the cable tray to get it back up onto the cowl with the DCIs in place....
I know a lot of folks run the cowl delete and wonder if anybody else has had an issue with the cowl and the DCIs?
Car: M135i
Default 03-14-2021, 12:58 PM
Follow up on this.....so it seems possible to make it all fit...but the order of reassembly is important. I found the only way that works is to fit the cowl and wiring tray FIRST...then the rear Filter can be fitted into place. It's all a bit tight and would be so much better with a cowl delete.
