(#2126)
Beefer's Avatar
Beefer Beefer is offline
Car: Genesis G70 3.3T
Default 05-09-2019, 12:12 PM
Originally Posted by Torqued
I hope so . I want to taste the tears of all the traditional muscle cars out there....
Do we have any good numbers from AWD G70s yet? Given its a a few hundred lbs lighter than the Stinger, I would expect slightly better times....
I have gotten a tiniest of a smidgen over 4 seconds...but it wasn't the best launch. My guess is that I am between 3.9 and 4.0 seconds.
I am running Map 3 with 99 octane (via BOOSTane Pro). No other performance mods.
Maggei82 Maggei82 is offline
Car: Hyundai i30N
Default I30n - 05-09-2019, 12:45 PM
Hi Terry,
can you take a look on my map6!
In the range from 4000-4200 it feels a little bit strange!
File Type: csv 2019-05-09 16_46_06_Map-6 (3. u4. Gang).csv (17.0 KB, 36 views)
File Type: csv 2019-05-09 17_16_01_Map-6 (3. Gang).csv (14.9 KB, 30 views)
Default 05-09-2019, 03:26 PM
Seems OK to me... Funny how much more timing that motor takes compared to the 3.3L Stinger. But no signs of knock here.
psykostevo psykostevo is offline
Car: 2019 Kia Stinger GT1
Default 05-09-2019, 09:06 PM
If we are updating our JB4 firmware, do we only need to upload #9. Or do we need to upload ALL of the firmware updates one at a time? I find it a little confusing since there are so many .hex files listed and I want to make sure I get it right.
Default 05-09-2019, 09:34 PM
Only the latest version.
Mikeroo88 Mikeroo88 is offline
Car: Kia stinger 2.0T
Default 05-10-2019, 12:30 PM
Is the latest one I need to download the one located at the top of the list or the one with the number 9 in it?
Mickey14 Mickey14 is offline
Car: 2019 stinger gt1 awd
Default Map 2 - 05-11-2019, 07:57 AM
I'm new to tuning and trying not to blow up my ride.just installed jb4 and denso plugs car and jb4 preformed great on map1 was thinking about trying map 2 but I'm running 91 octane will this be ok or should I wait till I put 93 octane
NLJ NLJ is offline
Car: G70
Default 05-11-2019, 08:42 AM
Try it and log it. There's a good chance you wouldn't experience a problem if the fuel quality is good!
Default 05-11-2019, 08:54 AM
Thanks ill try it today if I post log what info should I include on log
NLJ NLJ is offline
Car: G70
Default 05-11-2019, 09:36 AM
Export the log and upload the CSV file. As long as the OBD cable is plugged in, you get all the parameters that the JB4 looks at!
Damian1963 Damian1963 is offline
Car: Kia stinger
Default 05-12-2019, 07:19 AM
Hi terry i want to connect fuel wire on my 2.0 t stinger
To control AFR and ...:jb4 not able to delete codes mine is engine light (cause if down pipe)
Default 05-12-2019, 10:09 AM
For the optional fuel control on the 2L the long fuel wire attaches to the white o2 sensor signal wire.
Car: Kia stinger
Default 05-12-2019, 10:44 AM
Can i use the fuel wires in jb4 for my stinger 2.0 t
PBVN PBVN is offline
Car: Veloster N
Default 05-12-2019, 11:53 AM
Have a question regarding maps and use of 91 octane as this is the highest I can get locally. So am I only limited to two maps?
NLJ NLJ is offline
Car: G70
Default 05-12-2019, 12:10 PM
You can try a Custom Map6, log it, and tweak it to your liking.
Torqued Torqued is offline
Car: 2019 G70 Sport AWD
Default 05-13-2019, 03:00 PM
Just got my JB4. I noticed there isnt a resistor on the long fuel wire like before. Did you build the resistor into the board? Just gapped the densos....may dedicate a couple hours to git er dun tonight! Full tank of 93.....
2019 Genesis G70 Sport 3.3T AWD
Default 05-13-2019, 05:14 PM
The resistor is built in to the harness on the short wire.
Default 05-13-2019, 06:56 PM
I got the JB4 today, and got it partially installed (no fuel wires yet). I took it for a spin on the stock plugs, with Map1 and 93 octane. To say I am a bit blown away by the amount of power this car is putting down already would be an understatement. It is night and day different already. for that Kudos guys, this thing is pretty awesome
HOWEVER, I will say while your online docs were helpful, they were lacking in one spot in particular....THE DARN RUBBER GROMMIT! I wish you would have put some more time into showing how that part is done. I wasted a huge amount of time on that....there is even a video out there which suggests putting a hole in the grommit, which i found hard as hell, and eventually i just went to the side of it....wish i did that to start!!!!!!
Lastly, I think it would be worthwhile for you to spend the extra coin on loop plugs like the other wires for the fuel wires/O2 sensors instead of the wire taps. For one, it would make install and removal of the fuel wires 10x easier, but it would also prevent idiots like me from dropping the freggin grey piece into the land of no return....(the reason I didnt install the fuel wires ). Either that, or give us some extras, because those cant be found any where locally that ive found. I did find them on amazon, and thankfully I have 6 more on the way.
Anyway, here are two very short pulls. Please take a gander if you dont mind! Once again, well done, and dont take my criticisms as overly negative, i am just trying to let you know what may help the next guy.
Beefer's Avatar
Default 05-14-2019, 02:32 AM
^ agree 1000%
It took me over an hour to do the grommet part. That OBDII wire is there permanently.
As for the Fuel Wires...complete afterthought. I know they were an extra $30 addition in the beginning. But since they come with the unit now...they have should have proper looping connectors. Especially for the price.
Car: 2019 STINGER GT2
Default 05-14-2019, 04:11 AM
I punctured the grommet all the way through and ran the wire through it. I taped the wire to a long screwdriver and put it through the puncture, then pulled the wire up from the engine side. Didn't have to remove the computer. Pretty easy. I do agree on the plugs vs. the wire taps... especially from the stealth and wire longevity standpoint.
Beefer's Avatar
Default 05-14-2019, 04:40 AM
^ Yeah...I ended up using a coat hanger...and taping the JB4 connector to it with electrical tape...and pulled it through as well (towards engine side).
Problem is...you can very easily damage the existing wires by doing that. If that happens...you are SOL...and would have to go to the dealer most likely. What would you tell them at that point...LOL.
Other than that gommet...I searched around for another spot...even on the passenger side behind the glove compartment. I could not find a single other access point. Frustrating.
Default 05-14-2019, 04:42 AM
Do I need to modify any settings while I dont have the fuel wires connected with the latest firmware? Until my replacement taps arrive tomorrow, i am SOL.
Beefer's Avatar
Default 05-14-2019, 04:47 AM
No...you can just run it as is. I think past v7 it is all automated, etc.
Default 05-14-2019, 07:51 AM
On grommet you just push it out from inside, run wire through, and push it back in. Takes maybe 2 min total and no holes are required. We'll have to make a better video of that soon. Maybe the AWD models have a different grommet?
Two short logs seem fine. We have replacement posi-taps on our site also, should the need arise.
Default 05-14-2019, 08:31 AM
Yeah i discovered pushing the grommet out and going around it is FAR easier.....just didnt realize that i could do that. Going through it is incredibly difficult and as noted risks damaging the existing harness. So doing that is unwise imo. Wish i knew that before spending over an hour lol.
Thx for the reply on the logs. I will try to get some longer ones without getting caught by the popo lol. Holding WOT as you are aware gets you well over 100 in a big hurry lol
