Blueberry96's Avatar
Blueberry96 Blueberry96 is offline
Car: Kia Stinger Gt1
Default Stinger problems :( - 09-01-2019, 02:19 PM
Lot of issues with my stinger now. Meth kit will not work for the live of it, been through 2 different company spark plugs, one gapped at .18 and the other at .22 and neither worked to the point i could even log my car, and now my car goes into overboost on MAP 2 and misfires now, really unhappy at the moment because i feel the car is falling apart with its performance, so
1. What kind of spark plugs do i get that are bullet proof, Iím tired of changing them, Iím aboyt to get a set of Lamborghini Spark plugs tjat my buddy has since he said his works perfect with every map.
2. Plz help, Iím getting a little disappointed
3. Any help is appreciated,
Default 09-01-2019, 02:22 PM
Does the problem come up on map0?
Log of what map2 looks like "over boosting" etc?
Default 09-03-2019, 10:00 AM
Your gap size, make sure it's .020"
Default Reply - 09-03-2019, 09:47 PM
As mentioned on the kia page, I now have 2 codes
Overboost happens on map 0 as well
Map 2 is impossible to log because of overboost and misfire
plugs I have are .22 right now, was told not to touch
What plugs do you recommend that can handle methanol set ups as well
Default 09-04-2019, 10:21 AM
The a log of map0 and map4 will do!
Default 09-04-2019, 12:37 PM
No, lol i cant log period, the car won’t log because it just knocks and overboosts
Default 09-04-2019, 03:43 PM
Not much we can do for you remotely then if not even map 0 or map 4 valet mode work. Start taking off mods until it works.
Default 09-04-2019, 04:31 PM
Was able to get one log on map 0 then it went to overboost again after
I sent you the log
Default 09-05-2019, 11:13 AM
Yes I got it, your map0 log looks perfect. Do a similar log on map1 next. The "over boost" fault code is just a false alarm flag the ECU is throwing due to your mods I think. We can come up with a work around when I see more data.
Default 09-05-2019, 02:21 PM
Sent you a map 1 they were breaking up but did the best i could, no overboost afterward
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 09-07-2019, 11:54 AM
Any update on these issues/resolution?
Default 09-07-2019, 04:40 PM
I am not sure what his specific problem is yet.
Default 09-08-2019, 04:43 PM
Sent you a map4 pull after new revision, car hit limp mode again after the pull, no CEL though
bbrillon998 bbrillon998 is offline
Car: Stinger GT AWD
Default 09-12-2019, 08:52 AM
Im going to jump on this train to report that i seem to have something similar going on now. Map 1 runs will sometimes cause the car to go into limp mode. Map two almost certainly will go into limp mode with a misfire. Took The jb4 off completely and ran around for a few days... everything okay no limp mode no misfires. So do i need to do a few runs with map 0 and 4 to log ? When i get a misfire it freezes the JB4 App.
Default 09-12-2019, 03:40 PM
Are you running a meth kit also like OP? If not whatever advice I'm providing in this thread may not all apply.
If not running a WMI kit the most often cause of what you're describing is a cracked plug or failed coil pack. The misfire will also trigger the JB4 to turn off due to electoral over load as the coil sends a ton of power back through the cars grounds.
Car: Stinger GT AWD
Default 09-15-2019, 11:07 AM
I dont have WMI on the car and indeed i did pull the plugs on the passenger side of the car and found no cracks that were visible but i replaced them all anyhow and it did stop the misfire issue entirely.
Replaced them for now and its all running great now.
Good to know about the misfire triggering the JB4 shut offs, that is now working a okay as well now Thanks Terry !
Default 09-15-2019, 12:48 PM
