(#2476)
ecko04 ecko04 is offline
Car: N55 335i
Default 08-04-2019, 12:11 AM
Originally Posted by lvthundercat
Can I install the jb4 and not install the obd2 cable?
Install the OBDII, it takes no time:
Does the JB4 void the manufacturers warranty? | Page 2 | Kia Stinger Forum
CeramicGT2 CeramicGT2 is offline
Car: 2018 Stinger GT2
Default 08-04-2019, 10:46 AM
Is the JB4 compliant with the HKS M45IL plugs? I ask after the recent press release for the GT420, and reports of increased performance from this spark plugs increased ignition characteristics. I would like to change from my current Denso to these, but I want to verify the compatibility. Thank you.
Default 08-04-2019, 10:56 AM
JB4 doesn't care what plugs you use.
Default 08-04-2019, 10:57 AM
Hi Terry;
Just need a quick review from you of the attached log before I move forward with installing fuel wires.
2019 Kia Stinger GT
91 Octane
Stock Everything
Map1
Thank you
Seems fine to me
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 08-04-2019, 02:24 PM
CPI doesn't require a pump or tank, it just tees in to the low fuel pressure system, and then the JB4 runs the CPI injector to control how much extra fuel is injected in to the charge air path. You need to drill/tap or weld a bung to the chargepipe or intercooler to run CPI. It can't work with our plug and play WMI nozzle adapter.
If you don't have E85 access then WMI would be a much better choice. And even if you do some customers prefer WMI, while some don't want to bother with extra tanks, and prefer CPI. Performance is roughly equivalent.
The BMS intercooler will come with a bung, correct?
Does CPI require full e85, or will e30 suffice?
Default 08-04-2019, 02:53 PM
Terry, thank you for the quick reply. If that is the case, why then the suggestion to remove the stock plugs for the Denso? Are the same advantages true when going from the stock to the HKS plugs?
Bratboy90 Bratboy90 is offline
Car: 18' Stinger GT
Default 08-04-2019, 04:52 PM
Terry the JB4 is amazing. I ****ing love it. I been on Map1 then 2 once I did plugs. Well finally I had a big car event. Powercruise #10 at Brainerd Intl Raceway. The car was a beast. I mean nothing compared to my buddies 724whp Audi RS4. But the Stinger hurt a lot of feelings this weekend and surprised a lot of people. So much love for the car. Tons of compliments and questions. I ran Map5 on e30 mix all weekend without a single problem in the slightest. I only have a few videos myself but I'm hoping the car will pop up in some other vids online. We ran mostly 3 to 4 people deep in it and still had way too much fun in a sedan.
Truely an amazing piggyback box. Absolutely love it. Then on the trip home the wife put it back to Map0 with regular 91oct and enjoyed 32mpg back home. Track MPG is about 9mpg on Map5 btw.
Wow already over 500 view on one video I have. This is against a 2017 Maserati V8 of sorts. I believe they are 450hp it was him and 1 passenger. I had 2 passengers. Nicely walked away from him.
Maserati vs Kia Stinger GT - YouTube
Default 08-04-2019, 05:23 PM
Glad to hear!
lvthundercat lvthundercat is offline
Car: Kia Stinger GT AWD
Default 08-04-2019, 07:29 PM
Hi Terry;
Need a quick review of 2 logs.
Stinger GT
JB4 with fuel wires
91 Octane
Stock everything
2000 ft elevation
EHGT2 EHGT2 is offline
Car: 2018 Kia Stinger GT2
Default JB4 Burnout option - 08-04-2019, 07:56 PM
So, what's the status of adding an electronic option to the JB4 for burnouts?
Default 08-04-2019, 08:09 PM
Not currently under development. Just the basic switch DIY for now.
Hi Terry;
Stinger GT
JB4 with fuel wires
91 Octane
Stock everything
2000 ft elevation
Looks fine to me, but drop me an email I have a firmware update I'd like you to test, since you're at 2000' elevation. terry@burgertuning.com
Car: N55 335i
Default 08-05-2019, 06:57 AM
Some of us have been running the M45iL plugs for quite some time already. No issues to report. The only downside is that they cost more than the Denso plugs.
https://www.k8stingerstore.com/produ...7bce2e10&_ss=r
Default 08-05-2019, 10:00 AM
Great, thank you! I just ordered a set. Can you tell me what to gap them at? Doesn't seem to be much information on the inter-webs.
BMS Fanboy
Default 08-05-2019, 01:16 PM
I was reading an informative post by Fuel It regarding their CPI, and they were suggesting e85 or high ethanol blends. With that said, I have some new questions...
1. How high of an ethanol blend can the Stinger safely run without damaging the fuel system?
2. I see most people run around e30; is that a high enough content to benefit from CPI, or should we stick to WMI?
Default 08-05-2019, 02:26 PM
1) With CPI E50 is the current maximum level for tuning reasons. No indication the fuel system hardware would have any issue with straight E85, though.
2) CPI is not needed for E30. It's for people who want to run closer to E50 which is enough octane to max out the factory turbos.
MurlinatoR's Avatar
Kia Efficinato
Car: 2018 Kia Stinger GT AWD
Default 08-06-2019, 04:58 PM
Some of us are still running the factory NGK plugs regapped without any issues as well for free. LOL
-MurlinatoR
Connoisseur of all things Kia
20 year Kia salesperson
30k miles
-JB4 w/bluetooth
-Burger Tuning pedal tuner
-Tork shorty intake
-ADD1 3.3v oil catch can
-Removed factory mufflers
Default 08-06-2019, 11:08 PM
Hi Terry,
I guess I've been using the jb4 without the updates.
I loaded v10 and did a log using launch control and another log just in 5th gear. Kindly check for me before I load the firmware you emailed me to test for you.
Chris
Team Tonka Team Tonka is offline
Car: G70
Default 08-07-2019, 09:22 AM
I live near Minneapolis, I'd love to swing by Brainerd and take my G70 for a spin. You all racing around the track in the Video? I've never been to the raceway there - driven by it 100's of times.
Car: G70
Default 08-07-2019, 09:41 AM
For MAP 3 or MAP 5, how much E85 should be added to the fuel tank assuming I'm running it with 93oct. with up to 10% ethanol?
Map guide as of v5 firmware (selected via JB4 Mobile/laptop interface. Map1 is the default map)
Map 0: JB4 disabled
Map 1: 4psi over stock peak tapering to 2.5psi at high RPM. Default performance map suitable for all 91+ octane fuels.
Map 2: 5psi over stock tapering to 4psi at high RPM. Suggested for 93+ octane fuel.
Map 3: 6psi stock tapering to 5psi at high RPM. Suggested for high quality fuel including unleaded race gas, ethanol mixtures up to 30%, or high quality octane booster like Torco or Boostane.
Map 4: Valet map, runs around half as much boost as stock.
Map 5: Up to 7psi over stock. For use with unleaded race fuel and/or E85 mixtures up to 30%.
Default 08-07-2019, 12:22 PM
Hi Terry,
Chris
You already emailed them, no need to email and post here.
Default 08-07-2019, 12:23 PM
Shoot for around 30% e85. Say 6 gallons to a tank of pump.
Cooshman Cooshman is offline
Car: Kia Stinger GT1
Default 08-08-2019, 10:26 AM
Should be closer to 4.5 of e85 if factoring in filling the tank with 93 and @10% ethanol already.
Used this for awhile on my Golf R until I memorized the amounts.
E85 (Ethanol) Fuel Calculator
TStaino TStaino is offline
Car: 2109 Kia Stinger 2.0T AWD
Default 08-11-2019, 07:57 AM
Kia OCC back in stock, get them while they're hot!
https://burgertuning.com/products/bm...29391333785715
Will this be made for the 2L engine? I know there are not a lot of us out there, but I am sure if you made a small batch they would sell.
Please and thank you!
RUFFSTUFF RUFFSTUFF is offline
Car: 2019 STINGER GT2
Default 08-11-2019, 08:10 AM
There's just too many variables in this to worry about fractions of gallons. It's all ballpark and guesswork, don't believe other wise.
