(#2451)
Talloneus Khan's Avatar
Talloneus Khan Talloneus Khan is offline
Car: 2018 kia stinger
Default 07-29-2019, 08:47 AM
Got my meth kit hooked up. Holy jeebus! Kicks hard! Anyways, got some 'mexican' strip pulles on map8, and a test map2 pull for daily driving, logs attached
BMS Fanboy
Car: 2019 Kia Stinger GT RWD
Default 07-29-2019, 11:35 AM
Iím not sure if this has been covered already, but what are the differences between the current WMI kit available, and the CPI kit coming out?
Metalmania82 Metalmania82 is offline
Car: Stinger GT
Default Tial BOV - 07-29-2019, 11:56 AM
I've capped off the JT intakes, I made sure to re-use the OE gaskets for the base of the flange adapter, I have the smallest skinny hose running from the sensor/solenoid on the left to the top of the BOV...I feel like I have everything right but I'm not getting any movement from the valve.
Default 08-01-2019, 06:46 PM
Bump
Default 08-01-2019, 06:59 PM
What fuel are you using? The WMI log looks good but I think it could use more octane. You can experiment with maybe a 10 lower additive to evaluate if that gets you faster.
Default 08-01-2019, 09:01 PM
CPI is for those with E85 access and is more of a 7th fuel injector sort of arrangement, all managed by the JB4, to get around the high pressure fuel pump limits.
BMS Fanboy
Default 08-01-2019, 09:17 PM
Thank you for the response.
So if I understand this correctly, WMI is for those who DO NOT have access to ethanol, and CPI is for those who DO have access to ethanol?
Also, does CPI require a tank and pump like WMI does? Or does it just feed from the existing fuel system?
Lastly, does one provide more performance gains over the other, or is it negligible?
Default 08-02-2019, 12:46 AM
Will do, I am using canadian shell 91
atr1 atr1 is offline
Car: Stinger GT
Default 08-02-2019, 01:14 AM
Or add some octane booster.
Default 08-02-2019, 01:39 AM
I was thinking that, yes. But, I can mix my own water/meth, and was wondering if I could just mix a 60/40 or 70/30 meth mix, instead of the 50/50 I sm running, and acheive the same results without lowering the additive, since 91 is the best gas I got. Unless I want to buy 110 racing gas at over $200 a tank
Adamdan Adamdan is offline
Car: Stinger
Default 08-02-2019, 05:54 AM
Hey Iím also in Canada and while I have heard of some guys running map 2 with shell 91, in bc this has not been the case for me. I have not found any gas in bc that I would run for map 2. I found the 91 octane that has some Ethanol in it to be better. Right now I run chevron 94 with a E85 mix that seems to have the best logs for timing. Shell 91 and E85 is pretty good too.
Default 08-02-2019, 04:40 PM
Kia OCC back in stock, get them while they're hot!
https://burgertuning.com/products/bm...29391333785715
Car: Stinger GT
Default 08-02-2019, 09:20 PM
Why the Stinger is the only car with this kind of product available?
You guys have a lot of products for BMW cars but I don't any similar OCC design, only regular OCCs.
Tdefrees Tdefrees is offline
Car: G70 3.3t
Default 08-03-2019, 08:13 AM
Terry, thanks for a great product! Installed the JB4 last weekend and installed the plugs I ordered from you, gapped to .022. With 93 octane, i been doing a few small runs with map 1 and 2. See attached. Getting some hiccups at the top end of 3rd gear. Any suggestions?
Default 08-03-2019, 09:11 AM
Timing, boost, and AFR look good here. Did you feel anything in this log? If so I can't see it on the data side.
Default 08-03-2019, 09:13 AM
The layout of the engine determines how parts need to work. BMW uses an internal PCV system inside the intake manifold so it's not possible to intercept the vacuum line and add an air/fuel separator in this way. I wish we could, we'd sell a lot of them.
This is the BMW equivalent: https://www.burgertuning.com/product...m-side-occ-kit
Car: G70 3.3t
Default 08-03-2019, 11:29 AM
Look at the 10:04 Map 2 run. That's when I felt a couple stutters. Thanks again!
lvthundercat lvthundercat is offline
Car: Kia Stinger GT AWD
Default 08-03-2019, 12:03 PM
Can I install the jb4 and not install the obd2 cable?
Default 08-03-2019, 02:56 PM
Sure but performance will be limited relative to running the OBDII cable.
That's the log above. No obvious signs of issues.
Car: G70 3.3t
Default 08-03-2019, 03:22 PM
Thanks for your time Terry. Can't wait to unlock the full potential of your product. Patiently waiting for O2 sensor extensions. Keep up the great work!
BMS Fanboy
Default 08-03-2019, 03:36 PM
Bump, in case you missed it, Terry.
Default 08-03-2019, 04:43 PM
CPI doesn't require a pump or tank, it just tees in to the low fuel pressure system, and then the JB4 runs the CPI injector to control how much extra fuel is injected in to the charge air path. You need to drill/tap or weld a bung to the chargepipe or intercooler to run CPI. It can't work with our plug and play WMI nozzle adapter.
If you don't have E85 access then WMI would be a much better choice. And even if you do some customers prefer WMI, while some don't want to bother with extra tanks, and prefer CPI. Performance is roughly equivalent.
Default 08-03-2019, 08:45 PM
Hi Terry;
Just need a quick review from you of the attached log before I move forward with installing fuel wires.
2019 Kia Stinger GT
91 Octane
Stock Everything
Map1
Thank you
Blueberry96's Avatar
Blueberry96 Blueberry96 is offline
Car: Kia Stinger Gt1
Default 08-03-2019, 10:20 PM
ok so
been doing a little research on the web, but "in your own word" what would you say a back end flash "exactly" is. To my understanding... is it just to monitor fueling/timing? Would I sound crazy to go a tuner friend of mine and ask for a back end flash? Please advise. thanks
