(#526)
frefer82 frefer82 is offline
Car: 2011 135i N55 DCT
Default 05-26-2016, 05:21 PM
hey guys some help here
i install the 3.5 bar sensor to my 135I N55 pure stage 1and change the 3.5 paramter to 1 in the interface, and now every time i give the car gas and wait to iddle the car shake and goes to 400-500, can some one tell me what its wrong, or if i miss something to do???
loesch's Avatar
loesch loesch is offline
Car: 2011 BMW 135i M Sport
Default 05-26-2016, 05:40 PM
You'll have to capture a log of the event and put it in the support section of this forum. I can't quite make out what is happening based on your description. I'm not clear on what you mean by 400 - 500.
Default 05-27-2016, 06:15 AM
sorry i mean the car goes down to 400-500 rpms shakes and goes up to 700-800 rpms
Lowon's Avatar
Lowon Lowon is offline
Car: Bmw M2
Default 05-27-2016, 07:07 AM
Hey man,
It's hard to tell without a log as we'd be guessing and assuming things without one. If you want an accurate answer as to why your car is shaking and rev hunting you'd have to create a thread in the support section and post a log in the csv format.
Mods: Stock for now
Thumbs up 05-27-2016, 09:32 AM
Originally Posted by Lowon
Hey man,
ok thanks man, i will do the log today and create the thread today and see what wrong with the car.
Lowon's Avatar
Car: Bmw M2
Default 05-27-2016, 11:24 AM
Yeah dude, I just don't wanna say stuff and it be wrong. But so far it kind of sounds like you have unmeasured air leaking past the maf sensor. Check your charge ***** to ensure they're tight, then check intake clamps.
But as of now nothing is for sure until a log is provided, ensure its a csv and not a data zap if you want input from BMS.
Mods: Stock for now
xpilot xpilot is offline
Default Boost issues with Vargas Stage 2 - 06-03-2016, 09:18 AM
Hey everyone
keyap keyap is offline
Car: N55 135i
Default 06-03-2016, 09:22 AM
You need to upload the CSV and should really be posting this in the support section
Luminous Luminous is offline
Car: M235i
Default 06-03-2016, 12:56 PM
Originally Posted by xpilot
Hey everyone
Honestly I'd be surprised if the stock DV wasn't leaking!
2015 BSM M235xi | Enzo Big Turbo Kit | Enzo Flash | JB4 | Garrett GTX3586 | TiAL BOV | TiAL Wastegate | Enzo Manifold | Enzo DP | PDU PI | Fuel-It Stage 2 LPFP | ATM FMIC | ER CP | Tuningwerk Exhaust | HRE FF15s
F Series N55 1/4 Mile World Record: 11.2s @ 127mph (Pure Stage 2)
Default 06-04-2016, 04:58 AM
My bad. Thought this was it. Thanks
Alex711 Alex711 is offline
Car: 2012 135i DCT
Default 06-04-2016, 06:49 PM
Can i run the e85 map with a stock turbo just a few bolt ons? How much E85 do i have to use? minimum/maximum amount of e85 with that map? If i don't have any e85 will it not run right with the 85 map?
(im running the stock lpfp and hpfp)
Ravs_35 Ravs_35 is offline
Default 06-07-2016, 09:47 AM
Hi Ravs here from SA.
Just installed the PS2, but still running the standard OBDII firmware. Car is PWG F30. Need some help. To run the ISO firmware, do I need to do the diode cut? or just load as is?
N20 TMAP and resistor mod will be done later in the week.
Thanks in advance.
Ravs
Sanesh21's Avatar
Sanesh21 Sanesh21 is offline
Car: 2013 F21 M135i MT
Default 06-07-2016, 11:17 PM
Thanks in advance.
Ravs
On the PWG board, you have to physically cut the diode, then upload the firmware.
2013 F21 M135i 6MT
JB4 / PWG / BMS intake / BMS meth kit / FSB / ER CP / Down Pipe / VTT stg1 / Pure inlet / GFB DV+ / AFE air scoop / N20 Tmap / Rev3 Connect / M performance exhaust / ACS springs / H&R Trak spacers / M Performance V2 steering
Default 06-07-2016, 11:50 PM
Thanks Sanesh
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 06-08-2016, 09:03 PM
Yes. Once equipped with the 3.5 bar the JB4 uses a different set of map targets.
What I'll do is add option FUB = 4 to the N55_ISO firmware. Which will trigger the boost additive on map 6 as well as map 3. So you'll setup a map 6 boost curve suitable without meth, then enter an additive that is added on top of that curve as a function of methanol flow.
Originally Posted by Bimmer_Boost
So I just read through all 21 pages. Looking for some clarification. After installing and enabling the 3.5 bar sensor it only increases boost targets for existing maps, still has the stock turbo taper? To combat this my best bet is to run map 6? Then set FUB = 4 to use the meth adder since meth will be my primary fuel supplement?
I use 100 octane at the track but at $12 a gallon I don't use any on the street.
I placed my order for the Pure stage 2 today. Can anyone answer this question?
SonnyD SonnyD is offline
Car: Bmw e92 335
Default 06-19-2016, 01:58 PM
So does this mean no dyno tune necessary?
Lowon's Avatar
Car: Bmw M2
Default 06-19-2016, 02:32 PM
In what context? Its hard to understand what you're asking exactly, and by dyno tune im going to assume you mean custom ecu tune specific to your car.
In terms of just general tuning with the jb4, it uses the ECU's self adapting feature combined with its fail safes and pretty good boost control to tune the car so you do not have to get a custom tune.
If you run a larger turbo timing is a bit too high and doesnt contribute to making extra power so a custom ecu tune or a resistor mod is a good idea to lower that timing to prevent excess motor wear and tear.
~Lowon
Mods: Stock for now
Car: Bmw e92 335
Default 06-19-2016, 04:28 PM
I meant as in after installing the pure stage 2 turbo, do I need to take it to a tuner and let them tune or would my jb4 do the job. I've been contacting a few Bmw tuner and they all said I need to bring it to them for tuning. Even Jesse from pure turbo said that. So I'm tryna figure out if it's true, hell if I could save the extra 600 from not taking to a tuner , that would be awesome
Lowon's Avatar
Car: Bmw M2
Default 06-19-2016, 04:55 PM
I mean you do have to do some adjusting on the jb4 user adjustment page, take logs and submit them for BMS support to review them. Otherwise you shouldn't need to take it to a specific tuner, those BMW specialists are probably referring to a flash tune. Jesse @ pure probably meant you had to adjust a few things on the jb4 to ensure it runs smoothly.
Mods: Stock for now
dannyle27 dannyle27 is offline
Car: 2011 335i e90
Default 06-29-2016, 07:45 PM
What adjustments to the JB4 settings did you guys make when running the backend flash? After 4/2, Do we need to zero out Duty Bias like the n54's? AFAIK, AFR bias is unused in n55? What about FOL?
Default 06-29-2016, 09:41 PM
No adjustments are needed but do plan on having to dial in duty bias for the turbo being used. FOL is generally unchanged also.
Joebeone1 Joebeone1 is offline
Car: 2011 135i white coupe
Default 07-01-2016, 06:00 AM
Terry@BMS is Cobb a must for BEF for n55 or is there another way. What does the n20 t map sensor do? I'm a newbie at this .
Car: N55 135i
Default 07-02-2016, 12:06 PM
The N20 Tmap can read higher pressure than the stock unit. Stock caps out around 21psi whereas the N20 can read to 3.5 bar. You also need a few psi headroom.
For a BEF, as you're an E series, if looking to load a BMS flash then COBB is currently the only way. You do however need a MEVD172 DME and compatable ROM.
There are however rumours that MHD have just hired a new 'flasher' expert.
Herbo94 Herbo94 is offline
Car: M235
Default 07-03-2016, 01:06 PM
i need some help about my M235i with the N55 EWG Engine. I would buy a Stage 1 Turbocharger from Pure. I run the JB4 Map 5 with *******-Pipe, chargepipe and bigger intercooler. Dou you think i have to switch Map 6 or i can use Map 5? I want no E85 Mixture or something.
JETmn JETmn is offline
Car: 2011 335xi
Default 07-05-2016, 09:59 AM
You can run map 5 no problem. Go with the stage 2 instead of the stage 1 (coming from a stage 1 owner).
