Rovch's Avatar
Rovch Rovch is offline
Car: 2011 BMW 135i | UUC Dp |JB4 |COBB CP | KW V2's
Default TMAP QUESTIONS? - 05-23-2016, 09:00 AM
with the stock tmap sensor (135i n55) what's the highest possible boost that can be targeted? Also, with a stage one turbo upgrade from vtt is a 3.5 bar sensor necessary?
E82 n54 135i
On3 Single Turbo
Default 05-23-2016, 09:09 AM
20psi on the factory sensor. The 3.5bar is a good idea for any larger than OEM turbo even a Stage1. As the Stage1 can produce around 21-22psi in the midrange. Why cap it?
Rovch's Avatar
Default 05-23-2016, 09:19 AM
Awesome I totally agree. Also, will the g5 2 step relay for manual transmissions work for n55 or perhaps the antilag system you guys sell?
E82 n54 135i
On3 Single Turbo
Default 05-23-2016, 09:33 AM
No 2STEP or antilag for the N55 yet. Sorry!
crobond crobond is offline
Car: M235i
Default 05-23-2016, 10:09 AM
Fseries can also make 22psi midrange
frefer82 frefer82 is offline
Car: 2011 135i N55 DCT
So terry i ahve the stage 1 pure turbo and all the hardware necesary for it, and i have the sensor laying around my house, i thouht that i cant install it whit out the stage 2 turbo.
if i install it i could get an advantage of performance ???
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 05-23-2016, 10:32 AM
You can install it. I have it installed with the stock turbo. Just gotta change the JB4 software to recognize it.
Mike Levy
2018 Silver Equinox LT 2.0T
Default 05-23-2016, 10:38 AM
mike a question, is there anithing else i need to change or only droped in the engine start the car wait for it and drive nuts jajajaja
Mike_L's Avatar
Anti-Social
Default 05-23-2016, 10:53 AM
You need to make a change in the BMS software so the JB4 knows that you changed the MAP.
Mike Levy
F32Boost F32Boost is offline
Car: 2016 435i coupe
Default 05-23-2016, 11:40 AM
Can stock turbo N55 F32 do 20psi safely on E30 ?
Kaated DP , chargepiped & Intercooled
Mike_L's Avatar
Anti-Social
Default 05-23-2016, 12:06 PM
Not ***ted. Its gonna have a hard time passing 17 or 18. Even without one, my car peaked at just under 15psi on Saturday on the dyno (E30, Map 5).
Mike Levy
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 05-23-2016, 02:14 PM
You will need to put a 1 in this setting for the JB4 to make sense of the sensor.
Name:  TMAP Setting.jpg
You will need to log as you turn up boost to know for sure. I do not know the limits of the HPFP on the F series but with more air, you need more fuel. My guess is that you would be close to the limits of the pump.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
