Rovch's Avatar
Rovch Rovch is offline
Car: 2011 BMW 135i | UUC Dp |JB4 |COBB CP | KW V2's
Default TMAP QUESTIONS? - 05-23-2016, 09:00 AM
with the stock tmap sensor (135i n55) what's the highest possible boost that can be targeted? Also, with a stage one turbo upgrade from vtt is a 3.5 bar sensor necessary?
E82 n54 135i
On3 Single Turbo
Default 05-23-2016, 09:09 AM
20psi on the factory sensor. The 3.5bar is a good idea for any larger than OEM turbo even a Stage1. As the Stage1 can produce around 21-22psi in the midrange. Why cap it?
Rovch's Avatar
Default 05-23-2016, 09:19 AM
Awesome I totally agree. Also, will the g5 2 step relay for manual transmissions work for n55 or perhaps the antilag system you guys sell?
E82 n54 135i
On3 Single Turbo
Default 05-23-2016, 09:33 AM
No 2STEP or antilag for the N55 yet. Sorry!
crobond crobond is offline
Car: M235i
Default 05-23-2016, 10:09 AM
Fseries can also make 22psi midrange
frefer82 frefer82 is offline
Car: 2011 135i N55 DCT
So terry i ahve the stage 1 pure turbo and all the hardware necesary for it, and i have the sensor laying around my house, i thouht that i cant install it whit out the stage 2 turbo.
if i install it i could get an advantage of performance ???
Mike_L's Avatar
Mike_L Mike_L is offline
Anti-Social
Car: 2021 M550i xDrive
Default 05-23-2016, 10:32 AM
You can install it. I have it installed with the stock turbo. Just gotta change the JB4 software to recognize it.
Mike Levy
2021 Tanzanite Blue II M550i xDrive
2018 Silver Equinox LT 2.0T
Default 05-23-2016, 10:38 AM
mike a question, is there anithing else i need to change or only droped in the engine start the car wait for it and drive nuts jajajaja
Mike_L's Avatar
Anti-Social
Default 05-23-2016, 10:53 AM
You need to make a change in the BMS software so the JB4 knows that you changed the MAP.
Mike Levy
F32Boost F32Boost is offline
Car: 2016 435i coupe
Default 05-23-2016, 11:40 AM
Can stock turbo N55 F32 do 20psi safely on E30 ?
Kaated DP , chargepiped & Intercooled
Mike_L's Avatar
Anti-Social
Default 05-23-2016, 12:06 PM
Not ***ted. Its gonna have a hard time passing 17 or 18. Even without one, my car peaked at just under 15psi on Saturday on the dyno (E30, Map 5).
Mike Levy
Bimmer_Boost's Avatar
Car: 2011 e92 335i
Default 05-23-2016, 02:14 PM
You will need to put a 1 in this setting for the JB4 to make sense of the sensor.
Name:  TMAP Setting.jpg
You will need to log as you turn up boost to know for sure. I do not know the limits of the HPFP on the F series but with more air, you need more fuel. My guess is that you would be close to the limits of the pump.
2011 E92 335i Auto Sold
12.0 @ 125MPH JB4
VRSF Chargepipe | BMS Intake | Custom MHD | VRSF 7" Intercooler | ER Turbo Outlet | XHP Stage 2 | AEM Meth Injection | Pure Stage 2 V3 | Pure Inlet | GFB DV+ | AR DP |
