albertc albertc is offline
Car: 2007 335i
Default Dyno at 28 PSI - 07-13-2020, 03:43 PM
I am happy, but i thou it was going to make more WHP. Any suggestions?
nyt nyt is online now
Car: 335ix
Default 07-14-2020, 12:32 AM
more boost
2010 335ix - speedtech 6466g2, cams, ported head, built bottom end, 7.5in hd ic, jb4, pi, fuel-it stg3, upgraded 6hp21+cooler, pr coils
brendan's Avatar
brendan brendan is offline
Brendan
Car: 335i 2007 6spdman
Default 07-14-2020, 01:00 AM
Fudge the dyno numbers like everyone else.
Get a mph and you will know.
Dont get hung up on the number.
Car: 2007 335i
Default 07-14-2020, 06:32 AM
Originally Posted by nyt
more boost
This is all the JB4, I have a feeling that maybe I can get 100+ whp with more aggressive timing.
Car: 335ix
Default 07-14-2020, 01:57 PM
JB4 has map 6 where you can set the boost targets, I wouldn't push timing. Add boost.
JMVela's Avatar
JMVela JMVela is offline
Car: 335is
Default 07-25-2020, 09:55 AM
If you don't have a custom tune, get someone to help you with one. You will see the difference. Hope this helps
2012 335is DCT 719.9 WHP MMPs BB turbos 93 oct pump gas + Meth. Trebila tuned.
AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default 08-07-2020, 07:50 PM
Not a bad result. Alot of claims you see online are BS.
Have you measures anything like 60 to 120 or 60 to 130 times?
That's the best indicator of performance
Car: 2007 335i
Default 08-08-2020, 01:02 PM
Did a 7.47 60-130 probably could do a lot better if it wasn't for the trans shift delay my car has ..... I'm probably putting down around 800 whp since I have it 32 psi now
