AWSAWS's Avatar
AWSAWS AWSAWS is offline
Car: 335i MSport DCT
Default JB4 mobile issue - 01-02-2020, 04:06 AM
Hi Guys,
having a strange issue so thought I'd ask here. Has anyone had this problem and if so, how did you resolve it?
I've got a jb4 and jb4 mobile installed. I can connect to the jb4. When I do, all the gauges show up just fine.
However on loading. It says 'unable to verify User/Meth Settings'.
I've tried uninstalling and re-installing the jb4 mobile app. I've tried logging out and logging in.
In the settings tab, advanced. It can't load in my settings when I click on 'User adjustment' as well. I've tried loading saved configs. If I then try to save these it keeps trying to write to the jb4 and failing.
Error reads "unable to retrieve user data"
AWSAWS's Avatar
Default 01-02-2020, 04:15 AM
Sh*t. I meant to put this in the jb4 mobile section.
AWSAWS's Avatar
Default 01-02-2020, 05:56 PM
ok, have connected to the jb4 with a laptop and usb cable.
Works completely as normal. Am able to read and write user settings and meth settings. Can log runs. Everything works.
When I connect with the jb4 mobile connector, the app cannot read or save the user settings. Tried clearing the cache and storage on the app. Reset the bluetooth settings. Uninstalled and reinstalled the app. It just doesn't seem to be happy with the values it's trying to load and save?
x99percent x99percent is offline
Car: 2008 135i
Default 01-03-2020, 02:08 PM
Latest JB4 firmware installed?
Jasonm140i Jasonm140i is offline
Car: M140i
Default 04-28-2020, 10:52 AM
Hi sorry to hijack this post but I have a issue with my bluetooth connection on my jb4 when connecting to my android app the main issue is there anyway you can reset the bluetooth connection code on this or is there a standard code they come with as I don't have instructions TIA
