sheharyar_rr sheharyar_rr is offline
Car: 2014 335i M sport
Default 01-04-2018, 10:10 AM
Finally got a chance to do 1/4 Mile... 0-60 clocked in at 3.78. I was still getting wheel spin here in -15c on winter tires.
Car: 2010 535
Default 01-04-2018, 03:18 PM
Impressive!
Default 01-07-2018, 11:32 PM
Man this car is insane. I knew she had it in her, Just had to get a better launch. I can prolly pull off a better launch but will have to wait till spring for PS4S's to go back on.
(advance apologies on the different sizing of the pics attached)
** EDIT **
A lot of people think these are JB4 results but these are in fact just BMS Stage 1 numbers, on +3 psi, the default setting.
Car: 2010 535
Default 01-08-2018, 03:49 PM
WOW!
Frikiton's Avatar
Frikiton Frikiton is offline
Car: 2016 F25 X4 M40i (N55)
Default 01-08-2018, 05:02 PM
Can you do a stock run ?
F80 ZCP DCT | BM3 Custom F80Paul E85 Tune 62-124mph 6.1s, 60-130mph 7.18s "World Record"
BM3 E40 OTS 62-124mph 6.7s | 60-130mph 7.82s | E30 OTS 60-130mph 8.24s
Pending: CTS Turbo D.P/CP/HE/Midpipe
WR X4 M40i CTSTurbo D.P/FMIC BM3 STG2 93 4.19s 0-60 | 12.4@109mph 1/4 m
$ECA $XRP $XLM $TRX $ADA
Default 01-08-2018, 09:34 PM
My buddy has already ran it stock... 12.19 @ 117 on the drag strip
Default 01-09-2018, 09:45 AM
Wow and up hill too! Moving!
Default 05-18-2018, 02:02 AM
Absolutely blown away by these numbers. Hit my new Personal best with Jb4 on map 2, although my 60-100 and 60-110 times haven't changed from BMS stage 1, so i don't think JB4 helped much.
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Frikiton's Avatar
Default 05-31-2018, 05:04 PM
60-100 and 60-110 are important : (
Did u ever do 100-200 or 62-124
Default 05-31-2018, 08:46 PM
Car is super quick man! 11.3@121 wow
Default 05-31-2018, 11:25 PM
I retract my statement of saying JB4 didn't do much, 100-200km/h number's definitely improved from 9 seconds flat to 8.46. Half a second improvement :D
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Frikiton's Avatar
Default 06-01-2018, 10:23 AM
That's a good improvement
Debating on getting M3 or M550
Default 06-17-2018, 12:51 PM
Interesting to see that Jb4 is requesting 19 psi on map 2. I only see it hit 16 psi, what does that mean? Need bcm or what
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Default 06-17-2018, 02:20 PM
Let's see your log. Map2 is additive based, so might be wrong map guide posted for your firmware.
Default 06-17-2018, 03:31 PM
You gave me 1b firmware. Anyways i've attached the log below
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
Default 06-17-2018, 04:42 PM
Looks solid to me!
Default 07-25-2018, 08:16 AM
Hey guys, working on some firmware updates for the G series n63tu and could use a couple logs. Drop me an email if you have time to test it out.
Lifted07Duramax Lifted07Duramax is offline
Car: bmw 335i
Default 08-09-2018, 01:27 PM
What kind of dyno numbers are these M550 putting down?
And is 11.3 still the record for them with stock turbos?
VRSF 5" FMIC, VRSF *********, BMS DCI, JB4 G5 ISO, RB Turbos, BMS Flash, Muffler Delete
Default 08-14-2018, 12:40 PM
Should be close to 500whp Iíd say. And yes 11.3 is the fastest Iíve seen and done. Iíll try out the new update terry has to offer which may help me slip into 11.2ís. All these runs are on pump gas. With E mix it should be well in 10ís
2018 BMW M550i
BMS JB4
1/4 mile 11.3 @ 121
DJTones DJTones is offline
Car: M550i
Default JB4 installed on M550 but with App issues - 08-21-2018, 11:17 AM
Hi All. Iím new to the forum and new to tuning. I just had the JB4 installed on my 2018 M550i. After more than 1hr of trying to get the firmware installed (while the car was still on the dyno), I finally got it going, however I am having some Mobile App issues which I will get to in a moment. Mustang Dyno shows a nice improvement of 50hp and 50 torque using Map1 and a better sounding exhaust with valves open. I had thought it would a lot louder but maybe I still need to tweak some app settings
As far as the app goes, something is definitely off. First off, the dyno didnít even like Map2 so we just ran specs on Map 1. With Map 1 connected, only Boost and Map gauges seem to work. All other gauges have 0 across the board with no movement. Any help would be greatly appreciated.
Tones
Default 08-21-2018, 02:09 PM
Tones
Make sure your obd is plugged to the molex correctly.
IonutZ's Avatar
IonutZ IonutZ is offline
Master
Car: 2013 E92 335ix
Default 08-24-2018, 10:17 PM
Hey team,
Can we please get a breakdown of the different maps on the 1b firmware (unless the original post is still accurate). Can we also get a latest screenshot with the optimum configured values under the User Adjustment tab of the software / whatever would need to be tweaked in the app?
Also, any luck on a newer firmware than 1b?
much appreciated,
IonutZ
Current: 2018 M550i
Audio: Focal IFBMWv2 (all interior speakers replaced) powered by Zapco Z150.6LX frontstage, 1x JL Audio 13W7AE powered by JL Audio 1200/1v3 substage, DA3, Helix DSP Pro MK2
Mods: None yet
Past: 2013 M6 F12
Audio: Focal Utopia BE 7, 2x JL Audio 8W7 powered by JL Audio 1200/1v3 substage, DA3
Mods: JB4
Past: 2013 335ix E92
Audio: JL Audio 1000/1 powering 2x JL Audio 13TW5
Mods: JB4 Stage 2 (Map 5, 40% E85), BMS Intake, ER Charge Pipe
Default 08-25-2018, 09:08 AM
Sure thing, updated first post. And posted the latest firmware.
JB4_G30_N63TU_2_T1:
1) Expanded map options as outlined above.
2) Enabled map switching in dash using BC button to allow toggling between map1, map2, and map0. See video below.
3) Added logic to start testing EWG control so the JB4 can control higher boost targets. Will require you to add in two "N55 EWG" connectors from our site in to the JB4 harness. Still in the development phase so details to follow when complete.
YoungMulla's Avatar
YoungMulla YoungMulla is offline
Car: 2012 BMW 135i 6mt
Default 08-25-2018, 07:45 PM
Hello everyone! I have a 2016 550i that has the newer n63tu2 motor. Can I use the older n63 jb4 or the new g chassis one
Default 08-25-2018, 08:32 PM
If it's F chassis there is a special JB4 just for it. This is the G chassis thread.
