(#726)
Joejoe200343 Joejoe200343 is offline
Car: 2020 F150 2.7
Default 07-27-2020, 09:29 PM
You have to get the cable and laptop to switch maps or do anything. Or get the Bluetooth and use you’re phone from what I understand. I just ordered mine today. Did yours come preloaded on map 1 or is it map 0 stock mode??
Wheeliej Wheeliej is offline
Car: 335ix
Default 07-27-2020, 10:07 PM
Feels faster I would imagine it’s on map 1 I had JB4 On my BMW M4 and I remember changing the maps on the steering wheel I thought I was missing something I guess I have to shell out the 150 for the connect kit
Car: 2020 F150 2.7
Default 07-27-2020, 10:28 PM
Bad ass! My laptop won’t be here till next week with slow shipping from amazon going on right now. So was hoping it was already loaded up on map 1 to enjoy till it comes in. I had it on my 335i and the steering wheel to make changes was the best.! Maybe later they’ll get them going for the Ford. What year is yours? 2.7...3.5? Big difference?
Car: 335ix
Default 07-29-2020, 09:06 AM
I have a 2018 Raptor definitely woke the truck up I also put the S&B cold air intake in and doesn't really make mouch more of a difference in sound but looks pretty sick thinking of doing the turbo upgraded flanges and Raptor QTP Aggressor Cutout ***** to get some more sound when I need
Default 07-29-2020, 03:10 PM
Car: 335ix
Default 07-29-2020, 03:29 PM
OK so I finally got my Bluetooth connect kit for the raptor I read the directions fast for pinned and unpinned thinking that pinned was to connect the blue wire to the red wire within the JB4 harness reading it again I figured out that pinned was actually not using the blue wire I cannot connect my phone itís not picking up the Bluetooth at all did I fry it
Car: 335ix
Default 07-29-2020, 03:36 PM
Never mind I got it to connect by going to the app and press and connect I thought I actually had to connect from the Bluetooth on my phone
rhex17F150 rhex17F150 is offline
Car: 2017 F150 Ecoboost 3.5
Default 07-30-2020, 05:19 AM
Terry,
Just checking back in to see if you'll be able to get the Oil Temp monitoring/logging working and if you'll also be able to add in Oil Pressure on the JB4 App for the 2017+ F150 Ecoboost 3.5's.
I see the cvs. log files already show Oil Temp but its flat lined at 0 and seeing oil pressure on the Guages and Datalogs would also be a nice feature since this engine uses a variable pressure/volume oil pump.
A lot of people probably removed various OBD2 devices that showed both of these as well as a lots of other useful and/or useless data, but i think Oil temp (similar to Cylinder head temp) and Oil Pressure are desirable.
Thank you!
Rich
2017 F150 SuperCrew 3.5 Gen II Ecoboost
(AFE Cold Air intake, Stainless Works High flow catted down pipe, SPD Turbo flanges, SPD 3" resonator pipe, Magnaflow 3" Exhaust, Garrett-Honeywell Intercooler, 185F Motorcraft Thermostat, Ford Performance Plugs - 1 step colder)
Default 07-30-2020, 01:49 PM
Most trucks have oil pressure and oil temp in dash already, but one of these days we'll get those added in the JB4 app. No timeframe though. Might be a few months before we have time to get to it.
Car: 2020 F150 2.7
Default 07-30-2020, 09:10 PM
Got my JB4 in today. Super easy install and map 1 definitely gives you a nice kick. And haven’t had issues with codes or anything. So just wanted to clear up maps real quick.
Map 1 - any octane you want to run (self adjust according to octane?)
Map 2 - Any octane as well? Or is this a 91+ type of map?
Map 3 - Stock with 91-93 ok?.....or has to be modified I.E cold air intake and down pipe and have 93?
Map 4 - For when the wife drives
Map 5 - Stock with no mods is ok as long as their E30 in the tank?
Super fast shipping by the way and awesome customer service!
Default 07-30-2020, 09:25 PM
Terry,
The 2017 F150’s with Ecoboost 3.5’s don’t have an actual oil pressure gauge, just a bar without any numbers and also no oil temp guages.
Before the JB4 I relied on my OBD2 OBDLink MX smartphone app to see actual oil pressure and temperature.
This app also showed calculated Horsepower and Torque that was quite useful as you changed things on the motor or tune...
Have you ever considered adding these calcs?
Thanks for looking into add these things when you can.
Rich
Default 07-30-2020, 11:22 PM
Always suggest using 91 octane minimum for stock and map 1.
Joejoe2003 Joejoe2003 is offline
Car: 2008 335i n54 sedan
Default 07-31-2020, 01:06 PM
here is a map 2 pull if anyone can take a peek for me. running 93 octane and drop in filter.
So cant figure out how to upload it here. Keeps asking to put a URL in there. But AFR is around 10.9 top of 3rd gear and trims are around 28. high pressure fuel is stuck at 15.
Default 07-31-2020, 01:32 PM
figured it out! heres a log of 2nd and 3rd gear. on 93 octane and drop in kn filter
Default 08-04-2020, 11:29 AM
Looks normal to me so far. No knock, boost and fueling where they should be.
Car: 2020 F150 2.7
Default 08-04-2020, 03:32 PM
�� Been running strong as hell. Loving map 2. Is map 3 ok to try out with just 93 octane and a drop in filter? Or need modifications to run that map? Anyone run it yet?
mholleman228 mholleman228 is offline
Car: 2019 f150 2.7
Default 08-04-2020, 07:14 PM
I ran map 3 on my 19 2.7 with just a drop in for a while before my inter cooker upgrade and it ran perfectly! So Iíd say your good to go in my book
Car: 2020 F150 2.7
Default Today, 08:24 AM
So been running good on map 2....decided to hook up the laptop and try map 3. I had a safety showing of 2 for lean AFR. That was on map 2. I havenít noticed any misfires or anything so didnít know there was a code.
Does that mean map 2 is too aggressive for my 93/drop in filter set up? Not sure if I should try map 3 now that map 2 is lean on AFR? Any suggestions? Attached is a pic of Safety I got. Think I should go back to map 1?
Car: 335ix
Default Today, 12:48 PM
I put the JB4 in about two weeks ago Iíve had it on map three I have resonator delete and cold air intake Iíve ran it on map five for a couple of pulls and then switch to map three when Iím on the mid load or coming down from High rpm I here a strong rattling from underneath the truck sounds like wastegate has anyone experienced this
