Alex Liu Alex Liu is offline
Car: BMW F36
Icon1 BMS JB4 (wireness) model connection - 08-16-2021, 07:55 PM
I got a second-hand BMS JB4 box(wireness/ewg model)for my N20(28i EWG)with four connector as picture shows.
I was puzzled by the JB N20/N26 Stage 1 & JB4 Install Guide on the http://burgertuning.com/instructions/JB_n20_install.pdf which is not the same with my box. Need I connect the all four connector?Or just connect the two for ‘boost’&'manifold'?
Default 08-17-2021, 08:30 PM
Looks like it has the optional EWG connector installed on the harness. Doesn't need to be attached to the car.
Car: BMW F36
Default 08-17-2021, 10:23 PM
Thanks for your reply.
It is for 2014+ 20i engine,looks like already integrate the the four connectors as follows:
1. Boost turbine pressure sensor
2. Manifold intake pressure sensor
3. Fuel high pressure rail pressure sensor
4. Wastegate turbine bypass valve controller(EWG)
My problem is whether the 3 & 4 connectors is needed for my 28i eng(14+ ewg)?
I think these two are not necessary for 28i,but if 28i eng install all the 4 connector to make the engine compartment looks tidy,will any adverse issues occur?
Default 08-20-2021, 03:03 PM
1 and 2 are needed. 3 and 4 are optional. Should be fine without them to start on map1 or map2.
