(#2026)
RMM RMM is offline
Car: 120i
Default WMI cut with throttle closure - 03-19-2022, 02:55 AM
Does anyone know how to disable the JB4 WMI cut out on part throttle, form my logs I can see that when I am <60% throttle WMI is disabled.
My issue is that I am getting HPFP crashes and limp mode when running e40 at 12.5 AFR, yes I can run a higher AFR and avoid it, but then I get more timing corrections...
What happens is that when I am trying to modulate the throttle at high boost, like > 25psi at 5000rpm for example during the on off throttle transients the WMI cuts out, then HPFP crashes, and limp mode, its not often but very annoying
Note that under full throttle it is rock steady, not even a dip in the HPFP pressure, event up to 28psi at 5000 RPM
I can get a TU HPFP, but with WMI on the B48 is that really necessary?
One recommendation to JB4 developers would be to have a 2 step cutout, for example lets say 40% throttle cuts all the time, then 40-60% cuts only if <25psi pre throttle, as this is only an issue when running high boost
Mikeym40 Mikeym40 is offline
Car: 2022 M40i
Default 03-30-2022, 07:21 AM
What’s the best way to log? Do I drive regular or do a kickdown, 3 gear pull? Thank you!
Default 03-30-2022, 09:41 AM
To properly evaluate the tuning, we'll need a full throttle JB4 log from 40-90mph on a safe private track.
kinetic kinetic is offline
Car: M135i
Default 04-06-2022, 08:30 PM
Since the V19 Firmware, there is a new feature
LagFix BETA (DWP)
Added in v19 and newer firmware this feature is used to boost pedal response and reduce turbo lag during routine driving. LagFix is enabled using the (mislabeled) DWP setting on the JB4 user adjustment page. A value of 0 disables the feature. A value of 100 is the "maximum effect". Most report values of 60-80 feel best behind the wheel so feel free to play around and see what works for your specific driving style.
My question is, where is that WDP setting?
Is it the Default Wastegate Position?
And what is the default setting for the TMAP on the B48 with the V22 Firmware?
Jesse2667 Jesse2667 is offline
Car: M340
Default M340i b58 jb4 logs review - 04-06-2022, 10:32 PM
Want to make sure everything is running good ******* down pipes jb4 map5 e30
Here is my log.
Default 05-11-2022, 11:32 AM
Fuel-IT came by the office yesterday with their new 2022 240xi development sled for a little JB4 dyno testing.
The car currently has a JB4, BMS intake, exhaust mod, and a Fuel-IT flex fuel sensor kit. Running an E30+91oct mix for all runs.
Best stock tuning run was 383whp / 395whp, best JB4 run was 461whp / 487wtq, running map5 with a peak boost of around 21psi. Impressive gains for such low boost! Dyno and log attached.
Viggo Viggo is offline
Car: BMW 540ix G31
Unhappy very big problems with the JB4 box - 05-23-2022, 11:57 AM
Hello,
I currently have very big problems with the JB4 box. I don't know which map I should drive, so that the engine runs without misfiring.
My car is a 2017 540ix and no OPF. modifications: K&N in-box filter, M-Performance exhaust and 300 cell steel catalytic converter. I always fill up with 98 octane petrol.
I've tried map 1, 2 and 3 but the car jerks every time I drive hard. In Map 4 it doesn't jerk so much but with stop and go traffic, the car smells strongly of petrol.
Now JB4 is off so I drive with Map 0. What else can I try to enjoy the JB4.
thanks for your help!
Slingray Slingray is offline
Car: M4
Default 06-01-2022, 04:10 PM
I've been reviewing my data logs as I'm feeling a dramatic surge under acceleration on MAP2, 98octane, newly installed high flow Active Autowerks catted ******** and cold IATs in an 2022 M240i G42 B58 Xdrive.
After reviewing the logs I have a situation where the Throttle closes rapidly and dramatically (from 100 to 27 - it is at 100% at 3,772RPM, 27% at 3,557RPM then back to 100% at 4,256RPM all in under 2seconds) and causing a surge in acceleration in the car. At the same time the ignition across all three cylinders is dropping from an average of 9 to 1. Boost also drops accordingly from averaging 9 to 5 (50% cut) - but all of this only occurring at that singular timestamp at 3,857RPM.
"40% or more throttle closure normally indicates that boost control adjustment is needed." - I'm seeing a throttle reduction of ~80% and IGN timing reduction of ~70% but only for that split second at 3,857RPM.
See here bolded and highlighted;
Screen-Shot-2022-06-02-at-9-11-23-am — ImgBB
https://ibb.co/V3VX73j
timestamp rpm ecu_psi target boost pedal iat wgdc throttle fp_h ign_1 avg_ign calc_torque trims dme_bt meth fp_l afr gear ff load clock map afr2 ign_2 ign_3 ign_4 ign_5 ign_6
7016.75 2872 3.3 0.6 3.7 40 97 50 52 28 15.8 9.8 19 21 0 0 47 14.3 2 50 6.4 10 2 0 15.9 15.9 15.9 16.8 16.3
7021.75 3425 5.6 4 10.4 100 95 50 100 29 9 8.9 34 47 7.6 0 64 15.8 2 50 11.5 9 2 0 7.9 7.7 6.8 6.5 6.5
7023 3772 8.5 4 13.1 100 95 50 100 29 1.1 7.6 37 49 6.8 0 71 14.4 2 50 13 9 2 0 1.3 0.8 0.8 1.6 1.7
7024.5 3857 8.4 4 12.2 100 95 50 27 29 9.9 7.5 31 44 5.8 0 71 14.4 2 50 13 9 2 0 1.3 0.8 0.8 1.6 1.7
7026.75 4256 8.4 4 12.2 100 95 50 94 29 9.9 7.5 31 44 5.8 0 68 13.4 2 50 9.8 9 2 0 10.9 14.2 16.6 16.6 7.8
7028.75 4647 9 4 13.5 100 94 50 100 28 8.5 8.5 40 42 13.1 0 78 15.2 2 55 13.6 9 2 0 11 14.5 14.5 14.5 14.5
I assume this indicates a momentary detonation control situation? Or could it be some sort of boost spike caused by a leak? Or simply traction control intervention (it doesn't feel like TC and I haven't observed the TC light coming on).
The car is definitely dipping in power momentarily and then surging back onto power, the acceleration is not linear in this scenario and feels problematic.
Default 06-23-2022, 07:49 AM
You'd have to attach a CSV log to the post if you want us to review the tuning.
bbbrrrx1 bbbrrrx1 is offline
Car: q50s
Default Log review - 06-23-2022, 05:42 PM
Hi Terry & Team.
I’ve attached a log I took with a 2020 M340i & e30. Car is stock other than JB4. I recorded this log using your recommended map 6 settings. Can you please review and provide feedback? At the end of the log I’m at 100% throttle from 1st through 3rd gear.
Prior to running this map, I ran map 4 with e30 for 2 years & 20k miles with no issues.
Thanks in advance!
themitigating themitigating is offline
Car: 2018 BMW 340i xdrive
Default Burble and crackle adjustment - 07-01-2022, 09:41 AM
My car currently has the stock ********. I read that burble exhaust tunes may cause issues for the O2 sensors and catalytic converters due to unburnt gas. I currently run map2.
Is there a way to disable the crackle and burble tune but maintain the boost pressure? If not can you reduce it?
Enzo2003 Enzo2003 is offline
Car: 2019 BMW 440i Convertible
Default 07-09-2022, 07:02 PM
Hi everyone.
I'm brand new to this, like the ink hasn't dried yet. Have a 2019 440i Convertible and installed the JB4 last weekend. Since then i have updated to firmware V22 per Terry's recommendations. As I was reading through the previous firmware updates (V18, V19, V20 and V21) I saw this new feature in V19 where the DWP setting could be used to boost the the pedal response and reduce turbo lag during routine driving. If i use this option and set it to i.e. 60, does that also affect the pedal response in all driving modes (comfort, sport, sport+) so when I want to drive more aggressively I should set it back to 0?
Also, inV19 it says there's been an adjustment to the IAT spoofing and it's suggested to turn this on in Options Bit 2. Does this affect performance, or is this just for data logging?
Appreciate all the help i can get.
RMM RMM is offline
Car: 120i
Default 07-09-2022, 10:27 PM
Hi so I hacked, shimmed and repinned a 3.5bar N20 TMAP to my manifold TMAP. So both pre and post throttle can read 3.5bar . Put n20 cal in my BM3 tune and looks to work well so far, BM3 logs look correct reading 30 psi on both MAP as expected.
However the JB4 is still logging and reading the 2.5 calibration, will this case any issues with JB4 operation, meaning is the manifold TMAP used in boost control or wmi?
Also is there an option to update cal to get it to log correctly?
FYI hope this will solve some TC issues and throttle position plausibility codes i am getting. I know its not used for boost control but its definitely important for throttle control as the ECU uses the pressure differential pre and post throttle as part of the throttle control maps.
RMM RMM is offline
Car: 120i
Default 07-15-2022, 10:54 PM
Quick follow up. The JB4 seems to be working just fine with the 3.5 bar manifold mounted N20 TMAP, just the logs show about 11psi lower pressure then actual, but it does not appear to impact the way JB4 works in any way I can tell.
On codes, I still got the throttle plausibility code (101F01) after a few days, and also got a new code related to intake manifold pressure too high, (CDC10C), however after I suppressed these in the BM3 tune they have not reappeared and they do not trigger limp mode so that seems fine.
On TC, it looks like this did solve my main issue with TC code that would appear if I really hit the TC hard, like for more then 1-2 seconds of wheel spin, it would go into limp mode, so that was the main thing I wanted as even if I suppressed this code in BM3 it would still trigger limp mode but just didnt throw check engine light on dash which doesn't help.
Pineconeliquor Pineconeliquor is offline
Default 08-05-2022, 12:24 PM
Is this a more appropriate place to ask for a log review?
2022 b58 supra w/ ***'d dp and mst intake running 93octane
Jeff @ BMS
