Sicmadek Sicmadek is offline
Car: 2013 335i sportline
Default Heating up - 10-01-2017, 03:58 PM
Any of you with drag radials actually do burn outs before racing? Im worried about popping a stock axle?
2013 335i sportline pwg 8at~jb4 iso~e40~bms oil cooler valve~bms intake~wagner c-less~ap catback~phoenix ic~gfb dv+~pure inlet pipe~er tic pipe~vrsf cp~ngk's @ .022~h&r super sports~437m
LessIsMore's Avatar
Inner Circle Member
Car: 2009 535i Sport SAT
Default 10-17-2017, 10:12 AM
if you're AT you have less risk of snapping an axle, just brake-torque and preload driveline. Should only need a quick light spin with drag radials anyway.
2009 535i Sport - 548whp
Software :
Default 10-17-2017, 10:23 AM
At what psi? I still needed a burnout at 17psi in mt ss 275/40-17
LessIsMore's Avatar
Inner Circle Member
Default 10-23-2017, 08:55 AM
can't tell you what psi is best for you.
Software :
