Tsmith42 Tsmith42 is offline
Car: 2014 BMW 550i
Default n63tu not hitting target boost - 05-14-2020, 05:30 PM
i just installed my JB4 and seem to be way under what the target boost is on maps 1, 2, and 5. is there a way to fix this or is it always like that?
Default 05-15-2020, 10:27 AM
Post a JB4 log if you need tuning advice.
Make sure MAF sensors are unplugged and if you really need to drive boost up to target BCM connections installed.
Car: 2014 BMW 550i
Default log - 05-15-2020, 11:09 AM
Here is a log on map 1. i have the MAF Sensors unplugged but i dont have the BCM connections installed.
Car: 2014 BMW 550i
Default log - 05-15-2020, 11:17 AM
this is map 0
Default 05-16-2020, 12:43 PM
On map0 I see a lot of throttle movement, boost is read pre-throttle, so the odd spikes make sense. It smooths out on map1. You can log map2 next for comparison but adding in BCM I think will be next step after that performance wise.
Car: 2014 BMW 550i
Default log - 05-16-2020, 04:00 PM
This one is for map 2. Are there instructions for installing the BCM i looked online and couldnt find them for the N63TU engine.
Default 05-16-2020, 06:50 PM
Looks a lot better on map2.
For N63TU BCM unfortunately we don't have good directions, it's basically the same as the S63TU JB4 BCM connections on our website.
Car: 2014 BMW 550i
Default Map 6 - 05-19-2020, 09:33 PM
How would I go about getting a custom map 6 I donít know what to change or what settings do what I have an upgraded intake and ******* down ***** as well as the 3.5 tmap sensors
