RadarContact's Avatar
Car: 2006 E46 330cic ZHP
Default Can I install my VRSF 3" ***** using RAMPS? - 02-14-2017, 06:02 PM
Wondering if installing my ***** would be possible using just ramps? I have access to a lift, but the logistics of getting the car there and home are a PITA.
Thoughts? I'm getting impatient wanting to put them on.
// Radar //
ms335i ms335i is offline
Car: 2007 BMW 335i
Default 02-14-2017, 06:14 PM
Hell yea you can. I installed turbos on my car once on ramps and then a single turbo kit on ramps again. It's definitely do able.
Default 02-14-2017, 06:29 PM
How much harder than up over my head on a lift? Can you say??
Car: 2007 BMW 335i
Default 02-14-2017, 06:54 PM
It's gonna be a little bit harder but if you've worked on your back on a car before you'll be fine. Hardest part is the oxygen sensors. You'll need a really short wrench to get at those.
Edson Edson is offline
Car: '08 e90 335i
Default 02-14-2017, 09:47 PM
I replaced turbos and did my clutch on ramps, so yes **'s are definitely doable on ramps.
iminhell1 iminhell1 is online now
Car: 2010 135i
Default 02-14-2017, 10:19 PM
I removed the O2's after i puled the ***.
... and holy crap. did they leave enough lead wire? ... label them.
2010 135i auto,
2020 mods: Speedtech S366, VTT DBBL, PR Coils, dual 450's, etc
Best stock turbo 1/8 mile: 7.469 @ 98.56, 1.769 60'
Best stock turbo 1/4 mile: 11.480 @ 121.79 1.802 60'
N54QC N54QC is offline
Car: 07 BMW 335i
Default 02-14-2017, 10:20 PM
I did/do everything on my car off of ramps or jackstands. It would be nice to have a lift, but it's not a option for some of us, so you do with what you got.
Car: 07 BMW 335i
Default 02-14-2017, 10:22 PM
I just take a bunch of pictures so I have something to reference, comes in handy down the road too in case you run into another situation.
Vogt.ryan's Avatar
Car: 2008 BMW 335i sport
Default 02-15-2017, 06:52 AM
Did mine in ramps the only downside was having to crawl out every time to get a tool, other than that I don't see how a lift would have made it much easier
2008 335i Sport Jb4, MHD BEF, Alpina flash, Uncatted *****, PE Mod, Injen Intake, v710's , Vogtland Springs
Default 02-15-2017, 06:53 AM
Thanks for all the responses!
I'm not a mechanic, but I'm pretty good for a shade tree, so I think I can do it without too many problems.
- I'll probably just cut a wrench down to the right size once I see what's needed, thanks!
- leads...are they extra long or are they too short? Couldn't tell if you were being sarchastic. From what I understand it doesn't matter which lead goes on which O2 sensor. ???
Thanks,
// Radar //
Motolawyer's Avatar
Motolawyer Motolawyer is offline
Car: 2008 335i
Default 02-15-2017, 06:54 AM
I think most people do these on ramps, myself included. It isn't that bad of a job. In short;
1. remove plastic guards
2. unbolt the sway bar
3. unbolt and push up the steering rack (do not have to completely remove)
4. do your thing on the exhaust
If the car has time and mileage on it some of the exhaust bolts suck to take off
2007 e92 335i - fbo (mostly)
Default 02-15-2017, 07:16 AM
I watched "the" video on YouTube on this a few times. Don't remember seeing them unbolt the sway bar. Necessary or just makes things easier once it's done?
Also, does anything HAVE to be torqued to specific values or can I use common sense and the forearm meter for this job? My torque wrench sucks.
2010 / 67,000 miles (garage kept for the first 65,000)
Motolawyer's Avatar
Car: 2008 335i
Default 02-15-2017, 07:18 AM
if memory serves I had to undue the sway bar to move the steering rack forward far enough to get it out of the way. Much easier than removing the steering rack
Default 02-15-2017, 07:21 AM
Gotcha. I appreciate it!
Car: 2007 BMW 335i
Default 02-15-2017, 07:29 AM
Thanks,
// Radar //
WRONG ON THE O2 sensors. They are color coded one is black the other is grey, place them according to how they were when you pulled the ***. Just take pictures of the process.
Default 02-15-2017, 07:38 AM
Wilco! Not a problem putting them back where they came from. Cheers!
Vogt.ryan's Avatar
Default 02-15-2017, 09:20 AM
I had to swing the sway bar out of the way, I still loosened the steering rack and pushed it back on give more space as well it's only two bolts so it wasn't bad
Car: 2010 135i
Default 02-15-2017, 01:39 PM
Double wrong.
I am speaking of the FRONT O2 sensors. They are both black and interchangable.
And I'm not kidding about the length of the leads. They are about 5-6 FEET long. runs from the ** up and around the back side of the head to the front DS near the oil filter housing.
Having the connectors on the PS of the head would have been much easier for replacement, etc.
As it is now, I couldn't see where i puled the leads out of and they are just back there on something. I know I didn't get them routed as stock. And there is no way to get a picture of what is back there.
2010 135i auto,
Car: 07 BMW 335i
Default 02-15-2017, 03:21 PM
Double wrong.
Mine are gray and black. If yours are colored the same for some reason, just put some tape on one. Take pictures as I originally said and you are good to go.
klipseracer klipseracer is offline
Default 02-15-2017, 03:36 PM
I did my **'s on jack stands. Not sure if I'd enjoy doing it on ramps, for those that did, wasn't it tight underneath? Why not just use jack stands?
Vogt.ryan's Avatar
Thumbs up 02-15-2017, 05:06 PM
My ramps are slightly taller than most as they are homemade. But sometimes haveing the car too high in the air can be annoying I prefer to keep things as close as I can do if it falls it doesn't fall as far. And it easier on the arms
Motolawyer's Avatar
Car: 2008 335i
Default 02-15-2017, 06:39 PM
For what ever reason I feel safer working with the ramps than the jack stands. Plus then I don't risk damaging anything underneath when jacking / standing, there was plenty of room for working, I use the ramps from walmart.
blaster3500 blaster3500 is offline
Default 02-15-2017, 09:19 PM
The sway bar needs to be moved only if the front wheels are on the ground. If the car is jack stands just unbolt the steering rack. As far as O2 sensors they are black and grey from the factory. Some people replace with the longer of the 2 (black) because it is cheaper. So yes they are the same part but do not switch them between banks on the install
07 E90 335i 6mt
Default 02-16-2017, 08:09 AM
Lots of great info and tips! I appreciate it, guys!
XM-N54 XM-N54 is offline
Car: 2008 BMW 335xi
Default 02-17-2017, 10:45 AM
Can you still do the **'s on ramps for the xi model? Or no due to having to drop the subframe?
