nissubaru nissubaru is offline
Car: 2009 335i M-Sport
Default Which Clutch Installation Tool for aftermarket non-SAC clutch? - 04-17-2019, 11:26 AM
I'm swapping out my busted ass motor for a used motor which means I have to reinstall the clutch, except I don't have the clutch install tool and I wasn't the one who installed it originally to know which tool was used
I did a bit of research and found it to be 26 splines but the diameter I couldn't find. Then there's also the BMW clutch install tool but I'm like 99% sure it will do me no good because I have an aftermarket clutch. For reference I have a Spec Stage 2 clutch with steel flywheel.
Looking to find one local or order it online so that I can get done sooner than later. Or if anyone has their clutch installation tool leftover from another job please let me know.
Default 04-19-2019, 04:34 AM
Nobody knows?
BMWSwede BMWSwede is offline
Car: 2007 BMW E91 335Xi
Default 04-19-2019, 07:11 AM
I dont't know about Spec cluthes but I used this https://www.ecstuning.com/b-genuine-...l/83300495449/ when I installed my aftermarket clutch with steel flywheel.
2007 E91 335Xi M-Sport MT
FBO W In/outlets
E85 BEF
Stock turbo @ 22psi
E40
430 AWHP
Default 04-23-2019, 02:09 PM
Still looking for one boysss
To the guy above me, your post history looks like you have a 335is clutch which I'm not sure if that uses the same tool or not since its an OEM part
nefariousminion nefariousminion is offline
Car: 08 535i
Default 04-23-2019, 02:18 PM
Did the aftermarket clutch install change the output shaft on the transmission side? I would imagine the aftermarket clutch would have to be manufactured to the same splines / diameter or the clutch wouldn't mount to the trans. Do you have a pic of this aftermarket non sac clutch?
535i E60 6MT: VTT Wastegate Fix / BMS DCI / No name Dpipes & CP / ARM 7" FMIC & Hose Upgrade / VRSF Inlets
C5 A6 2.7T 6MT
Default 04-23-2019, 06:11 PM
I'm not sure. They seem to supply it when you buy the clutch.
Spec Stage 2+ Clutch Kit SB533H-2, BMW 135i / 335i
Default 04-23-2019, 06:21 PM
I looked into this some more, never done a clutch job so I was confused as hell looking at the oem tool which is smooth. I thought there was more importance to the alignment of the splines but I see now that it's more about centering the clutch flywheel and pressure plate while bolting it up.
