Nachos23's Avatar
Nachos23 Nachos23 is offline
Car: about to purchase 09 335i Xdrive
Cool Which ********* from BMS website fit my 335Xi - 03-01-2014, 08:06 AM
Hi Guys;
I've been trying to make a final decision on which ******* DP to install.
Does anyone know if the BMS 135i 335i 3" Performance ********* will work? I see that CP-e *** list Xi compatibility; but they are twice as expensive.
I see a lot of members using the AR Designs DP, but since I'm running the JB4, i would think that the CMS DP should be designed to work with the JB4 perfectly.
Finally, should be i changing one of the stock O2 sensors to a wide-band O2 sensor??
Going to marrying up with a Magnaflow Catback exhaust.
Thoughts?
2016 335 GT - let the upgrades begin..
2000 Z3M - too many upgrades to mention ... lol
Default 03-01-2014, 10:36 AM
The CPE are the only ones we carry that fit. They are expensive but are very high quality and fit perfectly. No easy feat for an Xi.
Nachos23's Avatar
Default 03-01-2014, 02:37 PM
Thanks for the response Terry. Anotyher quick question. On the website it indicates they are available with an optional wide-sensor bung, but I dont see an option for selecting that.... How would I go about ordering with the sensor bung?
Default 03-01-2014, 04:29 PM
There is no optional wideband sensor bung. Must be out of date copy.
Nachos23's Avatar
Default 03-01-2014, 05:26 PM
K. going to pull the trigger....
Could I run the wideband sensor from one of the stock O2 sensor ports? Do I really need it for tuning, if I run Map2 for instance...
IlikeU IlikeU is offline
Car: BMW 335i N54 E92
Default 03-03-2014, 01:03 AM
We was install BMS DP to 335ix LCI e91.
Nachos23's Avatar
Default 03-03-2014, 08:05 AM
Thanks... I've read it depends on the ECU date/version. Prior to the date, no DP fix required. After the date. DP Fix required....
Purchased the Bavarian Technic Scanner Cable and intend to install back-end flash which should give me the ability to run map2.... the question now is it really worth the time and $$ to go ******* DP for what would amount to I believe an additional 20hp gains? Given I can run map2 with the back-end flash, what additional gains would I likely see adding ******* DP?
