08-02-2018, 05:56 PM
Just posted a new set of JB4 BEF maps.
1) Addressed false alarm under boost fault code in various map versions
2) Minor changes we've made along the way during development
3) Incremented the version of maps within the same family to avoid confusion
any plans for BEF for bigger turbo n55 like pure stg2 or bigger
08-02-2018, 08:45 PM
Right now those are just custom tuned as needed starting with the existing BEF map as a template. Normally, not many changes are needed, other than maybe taking out a degree or two of timing up top.
Car: 2011 535i M-Sport
08-06-2018, 08:32 PM
Terry, thanks for the "Recent changes" and referencing the date in the download URL text. I'll update tomorrow and maybe pull some logs.
2011 535i M-Sport - MHD Stage 2+ BEF w/ JB4 (logging), xHP Stage 3, BMS Intake, FMIC, ER Chargepipe, RM Motors catted d/p, Megan Racing Supremo Exhaust
Car: 435i
08-07-2018, 01:05 PM
Originally Posted by Phataxe
@Spammer to run anymore e85 then you are now you would need a LPFP and a PI setup.
Is there anyway to get more fuel without going WMI or PI? Could just replacing the LPFP or HPFP be enough? Sticking with stock turbos for now until they die which will be a few years hopefully.
Car: F30 335i
08-07-2018, 04:57 PM
can I use bm3 to load the bef for jb4
08-07-2018, 06:07 PM
When using MHD to load the BEF it ports over the changes in our file to match the software version in your car automatically. I don't believe BM3 does that, plus it's a lot more expensive, so I'd sell the BM3 if you have it and use MHD to load them.
Car: 2014 435I
08-07-2018, 06:15 PM
Changing the LPFP might get you a little bit more E85 thru the HPFP but not by much at all.. PI or meth would be your best bet. The problem is the HPFP can't Pump the e85 fast enough even if the LPFP is giving it fuel faster then it can use it
'14 435I RWD MHD "Shoup Custom Tune" ° BigBoost Stage 3 Turbo ° Spool FX-150 ° XHP Trans Tune ° VRSF Race Cooler ° VRSF CP ° BMS Intake ° Borla ATAK Exhaust ° Custom Down-pipe ° Stage 3 LPFP ° BMP4 EKP ° M Performance LSD ° Phoenix Racing PI Intake Manifold ° AIC2-P controller ° e85 ° 3.5 TMAP ° NGK 5992 Plugs "0.020"
Car: 09 E92 SG
08-08-2018, 10:06 AM
I wasn't able to run more than E30 on my stock turbo 2014.
Car: BMWX4 35i
08-10-2018, 05:31 PM
Terry, can I do a backend flash my x4 35i? MHD will not let me flash EWG_PUMP or EWG_RACE. It will only let me flash PWG3 files.
Car: m1235 2013 f20 n55
08-11-2018, 07:55 AM
hi terry
If I upgrade Mhd to STG 2 software
Can still use JB ( PI and maps )
thx
 m135 2013 at-8 PWG STG2 PureTurbo DP-ER CP IC NGK plugs inlet pure tmap 3.5 meth kit cm10
JB4 pump fuel stg2 fuel-it
08-11-2018, 09:49 AM
Why would you buy a MHD map when you can use/modify our BEF map designed specifically to work with the JB4 for free? To answer your question though you can run any map you want. How you set the JB4 depends on the details of the map and what you're trying to do.
Car: Bmw 535i - 2011
08-12-2018, 02:30 AM
Originally Posted by WakeOfDeath
Yes you can but you'll see with BM3 u don't need this
LMAO, you know damn right is the opposite!
BM3 does software match, MHD does not!!!!!
mhd forces all cars to run on the same rom version!!!!!
thats also why it takes ****ing 30 minutes to do first flash!!!!!
I've had both and can't believe Terry is giving misinformation again to gain himself another dollar.
Lets see.. Bm3 $595 + $20 Enet to OBD2 cable same one used for coding etc, works on iPhone/Android/Mac/Windows and can be sold or transferred to your next car one time.
MHD cannot be sold or transferred = Already more expensive!
jb4 799 + mhd license = $1000 + jb4 mobile app $30 + old dkcan cable you use which is like another $50+ c'mon!
Caveat Emptor!
Haha why are you comparing MHD BEF with BM3 flash only ??
MHD only & BM3 only = MHD Cheaper ! And if you go the BEF + BM3 then it will be more expensive
As we are JB4 users BM3 & MHD are only tune *BEF* flashers to us.. so we dont care about both MHD or BM3 tunes or OTS .. we only use them to flash our BEF's
Considering the above the cheapest flasher right now is MHD..
Don't be Biased to a company more than other just find what suites you the best and go for it
08-12-2018, 05:26 AM
i know
just asking
Car: 335i N54 E92
08-17-2018, 12:23 PM
Dear folks,
I'm trying to tune a stage3 with a national turbo with dimensions near to pure stg2 and it is nowaday with 477whp... I'm using 23psi and DME BT and ECU PSI is under 12psi.... when I trying to use more pressure it closes throttle. How can I do to increase it? I'm using jb4 w a custom mhd flash... future use D is on 68 (ff adaptation off)
With kind regards,
Fernando
335i, MHD E65 Custom flash, Intercooler, Chargerpipe, MM Performance inlets, LPFP Walbro 450, HPFP BMW review, full exhaust
08-17-2018, 12:25 PM
Lets see the JB4 log.
Car: 335i N54 E92
08-17-2018, 01:34 PM
You can find on attached dyno log.
Car: 335i N54 E92
08-18-2018, 09:11 AM
Terry,
Could you please help me on it?
08-18-2018, 09:14 AM
Originally Posted by Bomba474
Dear folks,
With kind regards,
Fernando
Do you have log of the throttle issue? DME BT is capped in the BEF, you can raise it if needed by raising "boost ceiling" and "boost limit multpiplier". I think we set them to 1.95 which is 0.95 bar. You could try say 2.05 for 1.05 bar to experiment.
08-18-2018, 10:38 AM
Terry, if I were to change those 2 parameters, would there be anything else I need to change? My car is very healthy at 25psi, but when targeting above that I get closures too. I want to try 26-28 again, so can I just change those 2 and leave all the rest the same in the BEF? Im running the EWG_PI BEF. 2014 PS2, PI, E65, all supporting mods.
08-18-2018, 12:00 PM
I'd have to see the data myself to offer specific advice. To date, no log provided of "throttle closing'.
Car: BMW M135i '15
08-19-2018, 12:17 AM
Hi Guys, im a newbie
Is anybody succesfully running MHD with a JB4 BEF on a M2 with Stock Turbo?
Are there any advantages in power over simply using a MHD OTS Map?
Thanks for reply
08-19-2018, 10:00 AM
Thanks for reply
Yes, many. Works nicely providing a lot of extra features and flexibility over what you can do flash only. Plus, you get our free tuning support.
Car: BMW M135i '15
08-19-2018, 10:25 AM
Thanks for the fast reply.
Car: 2015 F21 BMW M135i EWG
08-22-2018, 11:59 AM
Is there a MHD Jb4 BEF for PS2 on E30?
JB4 on top for PI controll
08-22-2018, 12:14 PM
We're just doing those F N55 larger turbo BEF maps custom as needed for the moment. Load the E85 BEF, post some logs or email them in, and I can help you.
