Car: about to purchase 09 335i Xdrive
Which ********* from BMS website fit my 335Xi -
03-01-2014, 08:06 AM
Hi Guys;
I've been trying to make a final decision on which ******* DP to install.
Does anyone know if the BMS 135i 335i 3" Performance ********* will work? I see that CP-e *** list Xi compatibility; but they are twice as expensive.
I see a lot of members using the AR Designs DP, but since I'm running the JB4, i would think that the CMS DP should be designed to work with the JB4 perfectly.
Finally, should be i changing one of the stock O2 sensors to a wide-band O2 sensor??
Going to marrying up with a Magnaflow Catback exhaust.
Thoughts?
2016 335 GT - let the upgrades begin..
2000 Z3M - too many upgrades to mention ... lol
03-01-2014, 10:36 AM
The CPE are the only ones we carry that fit. They are expensive but are very high quality and fit perfectly. No easy feat for an Xi.
03-01-2014, 02:37 PM
Thanks for the response Terry. Anotyher quick question. On the website it indicates they are available with an optional wide-sensor bung, but I dont see an option for selecting that.... How would I go about ordering with the sensor bung?
03-01-2014, 04:29 PM
There is no optional wideband sensor bung. Must be out of date copy.
03-01-2014, 05:26 PM
K. going to pull the trigger....
Could I run the wideband sensor from one of the stock O2 sensor ports? Do I really need it for tuning, if I run Map2 for instance...
Car: BMW 335i N54 E92
03-03-2014, 01:03 AM
We was install BMS DP to 335ix LCI e91.
03-03-2014, 08:05 AM
Thanks... I've read it depends on the ECU date/version. Prior to the date, no DP fix required. After the date. DP Fix required....
Purchased the Bavarian Technic Scanner Cable and intend to install back-end flash which should give me the ability to run map2.... the question now is it really worth the time and $$ to go ******* DP for what would amount to I believe an additional 20hp gains? Given I can run map2 with the back-end flash, what additional gains would I likely see adding ******* DP?
